Nitto Terra Grappler 295/70/18 116s Anyone??
Discussion in 'Wheels & Tires' started by SgtSausage1978, Nov 18, 2018.
  1. Nov 18, 2018 at 5:11 AM
    SgtSausage1978
    SgtSausage1978 [OP] New Member
    Utah
    2023 SR5 crew cab
    going to go with either the ridge grappler 285/70/18 .. almost 60 pound but look great with a lot of good reviews.. if you have them what psi do you run with for daily pavement driver this is 80lb max i believe???
    or...
    295/70/18 nitto terra grappler G2 116s .. 50lb tire not the 10ply version in the same size which is 63lb obviously beefier.. I know nothing about load letters looking for advice
    Just seeing if anyone has them ? pic would be great
    I do mostly pavement driving and tow a 22ft boat around occasionally ( sometimes over 1000 miles to the keys)..
    on my 2011 tundra i had the terra grappler G2 305/55/20 116s and thought they were really good.. I got 70k miles out of the set which were quiet and smooth .. so yes i’ve had the same tire and liked them but figured i’d ask about this size specifically .. cheers thanks
    Blueknights75 likes this.
  2. Nov 20, 2018 at 10:38 AM
    Tuckerman048
    Tuckerman048 New Member
    Western Pennsylvania
    2014 CM 4x4
    I will tell you this, I have the ridge Grapplers in 295/70/18 on my 4x4 crew Max. They were great for a while but have worn quick! I drive mostly pavement and occasionally dirt and hunting trails. I installed at 29,500 and am now at almost 50k. They were run at 40psi (recommend by nitto) and rotated every 3k religiously. They are now very loud on pavement and hoping I can get through winter without replacement. I'll be under 25k miles on the tire before they need replacing regardless. It was a lot of money for the little mileage I've got from them
    OR18TRD likes this.
  3. Nov 20, 2018 at 7:34 PM
    SgtSausage1978
    Utah
    2023 SR5 crew cab
    yikes.. i’m literally hours away from ordering 285/70/18 ridge grapplers for black friday that is not what i want to hear.. 25k miles is ridiculous ..
    Rica25 likes this.
  4. Nov 21, 2018 at 5:26 AM
    parker44
    parker44 New Member
    2008 Tundra - Desert Sand Mica
    I have the ridge grapplers in 275/70/18, and I have been pretty pleased. They might have worn slightly quicker than I was expecting according to the tire gauge, but I only have 10k miles on them. Looking at them, they still look really new.
  5. Nov 21, 2018 at 5:40 AM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
  6. Nov 21, 2018 at 5:50 AM
    NjPro
    NjPro New Member
    Tom
    Nj
    2017 Trd Pro Tundra cement
    Magnuson supercharger, Sprint booster, CB TRD PRO kit, 295/70/10 terra grapple G2, Black TRD shift knob, Rhino shackle hitch, Lund Tri-fold bed cover, 1.25 Spidertrax wheel spacers. TRD rear sway bar. Bud Built cross member. Arb Diff breather. Grab handle installed. 2012 DC SR5 TRD Supercharged, Gone but not forgotten.
    I have the 285/70/18 and really like the tire, the looks, on/off road handling and the road noise is minimal for such an aggressive tread. I can not speak on longevity yet as I have only had them for a couple thousand miles. I’m thinking as long as they are rotated every 5k they should last a while, I’m hoping. They are on the softer side of the compound rating, so they may were a bit faster ? As of now, I do not regret my purchase.
  7. Nov 21, 2018 at 6:26 AM
    Tuckerman048
    2014 CM 4x4
    I will add that when I first purchased them I really liked them. They rode well, were quiet, and had great traction in rain and snow. They seemed to be wearing really well then all of a sudden it took a drastic turn. They've started wearing quickly and with that came a very loud road hum. I'd estimate this started around 16k miles.
    I'm not sure what tire I want to go with in the spring as I was thinking about going with the Terra grapplers but I'm afraid of getting burned again. I had also got the ridge grapplers during Black Friday sales and got a good deal but $1000 in tires should last longer than what Im getting
  8. Nov 21, 2018 at 6:29 AM
    Faht Nocker
    Faht Nocker Platinum Member
    Woody
    Milky Way
    2016 Super Fast White Platinum 4x4 Faux PRO Tundra
    Anybody heard good or bad for the Toyo RT? I was looking into possibly getting a set of those. I love the way they look.
