Nitto Ridge Grapplers vs Cooper ST MAXX
Discussion in 'Wheels & Tires' started by Dustydirt19, Mar 4, 2017.
  1. Mar 4, 2017 at 9:53 AM
    Dustydirt19
    Dustydirt19 [OP] Hoghead
    Dustin
    Duluth, MN
    2015 Blue Ribbon Metallic 5.7L 4WD SR5 TRD DC
    ProComp 6" stage 2 lift 18x9 Fuel Vapor -12 offset 35x12.5 Nitto Ridge Grapplers BullyDog Tuner Gibson Metal Mulisha cat-back exhaust, S&B cold air intake, Color matched TRD PRO Grille, Compustar Remote Start N-Fab Hooped Nerf Bars, AMI Big stick antenna, Salex organizer and tray, Weathertech laser cut floor mats, Weathertech window deflectors Black out badge Black out front and rear bumper Black out flags 24/7 black out TRD Off-road decals Spray in Line-X Bedliner Scosche phone mount Soft rolling tonneau cover TRD pedals and footrest
    Gonna be ordering my tires soon and i was curious on people's thoughts on the ridge grapplers vs the ST MAXX? Pros Cons? I know some are going to say go with a more aggressive MT tire but I live in northern minnesota where we get dumped on with snow so unless someone has good experience in snow with an MT not gonna work for me.... I'm going with 295 70 18. On a 3in toytec boss lift with UCA's and shackles in the back Let me know your thoughts.
  2. Mar 6, 2019 at 12:16 PM
    fajita123
    fajita123 New Member
    '16 TRD CM
    295/70 R17 Cooper ST MAXX on Icon Rebound Air Design flares
    Which way did you end up going on this? I'm having the same debate currently.
    I live in Sask, Canada so see a lot of ice, slush and snowpack in the winter. Also drive a ton of gravel in the summer.
  3. Mar 6, 2019 at 12:23 PM
    BOBONTUESDAY
    BOBONTUESDAY Grocery Getter
    2016 Limited Trd
    I'm about to pull the trigger on some cooper st maxx tires. I'm currently running my second set of bfg ko2s I'm also curious how you made it through this great winter we've had in Minnesota this year with either of those tire choices.
    Rica25 and Black Wolf like this.
  4. Mar 6, 2019 at 12:33 PM
    fajita123
    '16 TRD CM
    Just read his build thread and it looks like he went with the Ridge Grapplers. I was also leaning towards the Coopers based on other reviews, so hoping we can get a first-hand account from @Dustydirt19
    BOBONTUESDAY[QUOTED] likes this.
  5. Mar 6, 2019 at 4:47 PM
    Hams
    Hams New Member
    Joel
    Fort Myers, FL
    16- Pro
    Camburg uniball UCA, Cooper AT3 XLT 295, Coachbuilder shims, shackles, and steering kit, SCS Ray 10, Undercover Flex Cover Ultra, GTR Lighting LED headlight and fog.
    Check out Cooper AT3 XLT. Similar look and specs compared to RG but 9lbs lighter each corner. Recently had a set installed, very happy.
    Rica25, BOBONTUESDAY and Black Wolf like this.
  6. Mar 6, 2019 at 4:52 PM
    My ST Maxx's do quite well with all the snow we've been getting...
  7. Mar 6, 2019 at 5:13 PM
    redryder
    redryder New Member
    Ryder
    Louisiana
    2018 Limited Cement CM
    Are the coopers on the right? I'm currently considering a set of them.
    Rica25 likes this.
  8. Mar 6, 2019 at 5:22 PM
    On the right.
    Rica25 likes this.
  9. Mar 6, 2019 at 6:23 PM
    acsubie
    acsubie New Member
    Jose
    2018 Trd Sport
    How’s road noise?
    Rica25 likes this.
  10. Mar 6, 2019 at 6:36 PM
    Not bad at all for a AT. Hybrid tread design to minimize road noise.
    Eclipsed & Floating and Rica25 like this.
  11. Mar 6, 2019 at 7:52 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    I can’t speak to the Nittos but I had S/T Maxx on my Tacoma and now BFG AT’s on my Tundra. I realize they are different trucks with different handling and tracking, but here is a general impression.
    The BFG’s are better than I expected for ice and snow road driving. Generally better on-road skills. Decent on gravel, meh in mud. Better traction on the commute for a Canadian winter than the Cooper. Great blend of for a weekend warrior.
    The Coopers are better off-road in mud and rocks. A step closer to being a mud tire than a road tire. Much better in the winter compared to a Mud, not as good as the BFG for everyday winter driving and storms. Also excellent on gravel fire roads. Much more confident to go deeper offroad with them. Little more noise than the BFG but only really noticable while cornering.
    So for a truck that is 90% city life and 10% overlanding or play, the BFG feels like a better choice. But if you’re going to be closer to 50/50 or pushing deeper down the trail is important, the Cooper is better.
  12. Mar 6, 2019 at 8:58 PM
    pickeledpigsfeet
    pickeledpigsfeet New Member
    Sierra Foothills, Ca
    2019 Tundra/14 FJ/ 90 SASed xcab
    Kings & Icons
    How many miles on the Coopers and how many on the BFGs? I have only had one set of each and the Cooper seemed to give consistent traction over 40k whereas the BFG seemed to loose its traction after maybe 20k and ended up worse than the Cooper. But these were both ran on a 2014 4runner, so I am not sure if it will be the same on my Tundra.
    Rica25 likes this.
  13. Mar 7, 2019 at 5:23 AM
    mountainpete
    I can’t comment well regarding longevity for either. I don’t have enough miles on the BFGs yet as the truck is a 2018.
    The Coopers I ran for a while before I sold the Tacoma. I don’t remember exact numbers other than I was surprised at how little tread wear there was and how evenly they wore.
    Sorry I can’t give you more specific numbers.
  14. Mar 7, 2019 at 5:26 AM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    I don’t like me STT pros
  15. Mar 10, 2019 at 11:51 AM
    I've noticed my Maxx's do quite well in wet conditions. Not prone to hydroplaning. Not a lot of siping but tread is designed to evacuate water and it does it quite well.
  16. Mar 11, 2019 at 9:47 AM
    BOBONTUESDAY
    2016 Limited Trd
    I pulled the trigger on the st maxx. I'm getting them put on tomorrow. We'll see how they do in minnesnowta.
  17. Mar 11, 2019 at 10:24 AM
    They can be studded but winter sort of over. We're supposed to be getting 5 to 10" in Denver on Wednesday.
    Watt maker likes this.
  18. Mar 11, 2019 at 12:18 PM
    BOBONTUESDAY
    2016 Limited Trd
    Yeah we can't run studs or chains like you guys can in Colorado. We're hopefully done here but the snow won't melt away for a while so I gotta be prepared so I don't end up like this again lol.
  19. Mar 12, 2019 at 1:17 PM
    BOBONTUESDAY
    2016 Limited Trd
    Got them put on today had to take front fender liner out and the mud flap I'll trim and modify them to work later but besides that 0 rubbing with 1.9 inches of lift from 6112s probably less now with the sso bumper. No rubbing at all and plenty of room for the body mount.
    Black Wolf, Watt maker and fajita123 like this.
  20. Mar 12, 2019 at 1:27 PM
    fajita123
    '16 TRD CM
    What size did you go with and what offset are your wheels? Thanks!
  21. Mar 12, 2019 at 1:33 PM
    BOBONTUESDAY
    2016 Limited Trd
    295/70r18
    Method double stanards +25 still alot of room between the tire and uca.
    One thing is i feel like i loss some braking power but that is a given with 40 pounds more of tire.
    Also speedo is off around 2 mph at 55mph. I'm gonna order a hypertech to fix that. The truck is a little slower the shift points have changed a little but its not bad I can deal with it I don't think I'd go any bigger than this. The real test is to see how she tows.
    The truck does ride buttery smooth though and quiet.
  22. Mar 12, 2019 at 1:59 PM
    mountainpete
    Nice boots!
