Nitto ridge grappler PSI info
Discussion in 'Wheels & Tires' started by Handbanana, Jul 10, 2020.
  1. Jul 10, 2020 at 8:10 AM
    Handbanana
    Handbanana [OP] New Member
    2018 TSS CM 4x4
    Trd sway front Trd sway rear Trd shift knob Nitto ridge grapplers OEM LED FOGS
    I you call nitto tires and tell them what nitto tires you are running and what trim tundra you have they will tell you the exact PSI you need to be running for your specific application. A sr5 tundra 4x4 with 285/55r/20 calls for 40 psi in front and 43 in rear.
  2. Jul 10, 2020 at 8:29 AM
    atrinh15
    atrinh15 New Member
    495-93 area
    2018 PLATNIUM White CM
    Ready lift 3/2 Fuel Mavericks 22x9.5 Nitti Terra Grappler G2 - 285/55/22 K/N air filter TRD sway bar SS Fisher plow Mesh grill painted to match Rear bumper painted white
    Does your tpms sensor kick on?
  3. Jul 10, 2020 at 8:31 AM
    Handbanana
    2018 TSS CM 4x4
    Nope so far so good
  4. Jul 10, 2020 at 9:40 AM
    TheBeast The Beach
    the ridge grapplers are on my short list for my next set of tires...
  5. Jul 10, 2020 at 10:59 AM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    I have mine set at 45 all around, i hadnit at 37 in front and 40, when i was driving it was damn noisy. It feels better at this psi for me. I have 285/70/18. Im probably going with the falkens next.
    Tundra234 likes this.
  6. Jul 10, 2020 at 11:00 AM
    Ely010606
    SPARKS, NV
    Too noisy , just curious.
  7. Jul 10, 2020 at 11:15 AM
    MTRock
    MTRock 1889
    Montana
    2024 Tacoma TRD Off Road
    Mine are super quiet..Tire guy said keep them at 45psi..305/70/17. Was looking at Falken at3w but I spend a lot of time on gravel roads, I tend to avoid A/T tires due to them picking up and throwing rocks all over! M/T tires are too damn loud! Ridge Grapplers have been a perfect fit for me.
    rodm1, MR TRD PRO and Ely010606 like this.
  8. Jul 10, 2020 at 11:17 AM
    Iowa12tundra
    Iowa12tundra New Member
    2012 tundra crew
    Sorry to jump but does the tmps light come on at 40 psi?
  9. Jul 10, 2020 at 11:22 AM
    MTRock
    MTRock 1889
    Montana
    Mine doesn’t..
  10. Jul 10, 2020 at 11:25 AM
    palehorse
    palehorse @grey_ghost_trdpro
    Mount Pleasant, SC
    2020 TRD PRO
    285/70-18 been running at 44psi cold all around currently.
    Nitto advised 36 up front and 38 in the rear when I just spoke with them.
    Ely010606 likes this.
  11. Jul 10, 2020 at 12:12 PM
    Ely010606
    SPARKS, NV
    Mine didn’t
  12. Jul 10, 2020 at 12:14 PM
    AZBoatHauler
    So.Arizona
    You can reprogram the PSI parameters by holding down the button on the dash below the ignition.
    ETA see now your 2nd gen. Not sure if this applies.
    Handbanana[OP] likes this.
  13. Jul 10, 2020 at 12:24 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    For me:
    44 front
    44 rear
  14. Jul 10, 2020 at 2:32 PM
    atrinh15
    atrinh15 New Member
    495-93 area
    This will be my second set of Nitto Trail grapplers AT. Not noisy at all
    In my opinion.
  15. Jul 10, 2020 at 3:23 PM
    Skey44
    Skey44 GreenvilleOverland
    Scott
    Greenville SC
    2018 GX 460
    Lift, tires, wheels, roof rack
    I find that if I run higher pressure in the rear gets very bouncy. I actually run less in back. E rated tires, not nitto though.
    Black Wolf likes this.
  16. Jul 10, 2020 at 5:47 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    That would be because sensors are set for the OEM tires. With OEM KO2s mine comes on below 46
  17. Jul 10, 2020 at 6:09 PM
    I'm running the same size at 44 psi.
    Ely010606[QUOTED] likes this.
  18. Jul 10, 2020 at 6:30 PM
    Ely010606
    SPARKS, NV
    To me it’s seems like the proper psi.
  19. Jul 11, 2020 at 1:41 PM
    Handbanana
    2018 TSS CM 4x4
    This is a good setting not to soft or hard
  20. Jul 11, 2020 at 1:42 PM
    Handbanana
    2018 TSS CM 4x4
    I’m usually running 45 psi bc I tow often also
  21. Jul 11, 2020 at 2:19 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Running 45 on my 295's, as for noise, very little. It's been a great tire :thumbsup:
    MTRock likes this.
  22. Jan 9, 2022 at 7:02 PM
    Tundra2Yak
    Tundra2Yak New Member
    2016 1794 4x4 CM
    Pro Comp 6" Lift Fuel Renegade d263 Nitto Ridge Grappler 35 x 12.5 x 20 Borla cat-back exhaust Volant intake Bakflip MX4
    Anyone else running 35x12.5r20LT F rated in ridge grappler with CM? If so, what psi?
    Dealer had 36 psi all around and it seems pretty low.
  23. Jan 9, 2022 at 7:44 PM
    MTRock
    MTRock 1889
    Montana
    45 PSI
  24. Jan 10, 2022 at 3:29 PM
    Tundra2Yak
    2016 1794 4x4 CM
    For reference, Nitro recommended 34 FR, 36 R when i called them. I'm planning to do a chalk test as well...
  25. Jan 17, 2022 at 9:56 AM
    Sonicbluerider
    Sonicbluerider New Member
    Dennis
    2019 Tundra
    50 in mine but I carry a fwc on back.
  26. Jan 23, 2022 at 8:44 PM
    Okierunner
    Okierunner New Member
    2020 TRD Offroad Crewmax
    Icon UCA Bilstein 6112/5100 Method 17s Ridge Grappler 35x12.50 Trd Dual exhaust
    I’m running 35x12.50x17, ran 32-33 cold for quite awhile, feels good around town, maybe a tad soft in corners, bumped up to 36 and it feels about right. Ran them home 5 hours right after I got them at 40 and they felt too hard, but they were brand new so that could have been it.
  27. Jan 27, 2022 at 7:47 AM
    medic_84
    medic_84 New Member
    2022 GMC Sierra 1500 Duramax 4x4 with a bench!!!!
    I’m running 285/75R18LT Ridge Grapplers at 43 psi all around….. no lights….. minimal noise….. ride is great…… chalk test shows even wear…… had them on for 24k miles at this point and still look new…. Rotate them with every oil change (6k miles)
    AZBoatHauler likes this.
