Nitrous kit?!
Discussion in 'Performance and Tuning' started by Tundraloves, Jun 16, 2018.
  1. Jun 16, 2018 at 9:31 PM
    Tundraloves
    Tundraloves [OP] New Member
    2015 Tundra Platinum
    Anyone know of a good kit for the tundra? Looking to put a shot on it but undecided on a wet or dry shot and how much really to put through it. Anyone have experience with this?
  2. Jun 16, 2018 at 9:39 PM
    Steve6
    Steve6 New Member
    Tucson
    I can't answer your question but I think that a Nitrous kit would be awesome. I'll be following this thread and good luck with your project.
  3. Jun 16, 2018 at 9:41 PM
    Tundraloves
    Thank you bud, I'll keep you updated!
  4. Jun 16, 2018 at 11:09 PM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    Direct port wet shot did well for me in my Honda. Probably the most consistent power I ever got from nitrous. First setup I did dry through the intake sprays were inconsistent going in. Closest cylinder to the throttle body took most of the spray.
    831Tun likes this.
  5. Jun 17, 2018 at 12:50 AM
    Nick T
    Nick T New Member
    Nick
    Curious what your ultimate goal is? Plan to use a WOT only switch? How many stages? Or a progressive throttle switch?
    Easiest would be a dry system, your manifold is not designed to flow fuel. Do a single dry nozzle with fuel enrichment by the factory injectors or a direct system with supplemental fuel handled by the nozzles themselves.
    Single dry nozzle risks inconsistant distribution as dcsleeper said. Direct port costs a whole lot more for installation, both systems do not work well with a progressive switch, so it's a WOT switch. You will probably want more then 50hp so now you need a 2 or 3 stage kit, and you will run out of RPMs with a 2 or 3 stage kit in first or second gear. The 3urfe is not designed for high RPM, nitrous is a power adder designed for high RPM use.
    Advise on what you want the system to do for a more definitive answer.
    dcsleeper408 likes this.
  6. Jun 17, 2018 at 8:00 AM
    Tundraloves
    Thank you for your insight, I’ll definitely have to keep researching on this and find out what will be the safest kit. I’ve got a buddy doing a 150 dry shot on his going through his intake box and he’s has it on there spraying the crap out of it for about 60000 miles with no problem. I’m just not sure if it’s a time bomb or what.
  7. Jun 17, 2018 at 8:02 AM
    Tundraloves
    I’m looking to use a WOT only switch for sure to keep the RPMs higher when it’s in use. I wanted to just use a button that way I can spray it on and off when I please. Which is usually letting off between shifts and then getting back on it
  8. Jun 17, 2018 at 8:24 AM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
  9. Jun 17, 2018 at 8:27 AM
  10. Jun 17, 2018 at 9:41 AM
    dirtydeeds
    Keith
    USA
    more than I can list here
    Use an rpm window switch. And a I’ll throttle switch. Call the guys at nitrous express. They are open to helping even if it’s not a oremade kit that they have.
    Keep it wet. And keep it below 100hp and you’re stock reliability. Go up to 200 and you’re on the edge. But run it rich and you’ll be safe. (10/1 afr)
    Make sure to install an afr gauge, colder heat range spark plugs, and bigger fuel pump. And only spray with 91+ in the fuel tank.
    Black Wolf, Pudge and dcsleeper408 like this.
  11. Jun 17, 2018 at 9:48 AM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    I say stay away from wot switches.
    I had a boost by gear-so only certain rpms delivered the shot. Best power gain and consistent just as long as the bottle was warm. I had a kill so if I was just driving around boost by gear never kicked in.
  12. Jun 17, 2018 at 3:47 PM
    Tundraloves
    I’ll look into that for sure, thank you all for chiming in! Huge help for my project!
  13. Jun 17, 2018 at 3:48 PM
    Tundraloves
    I’ll keep you guys updated!
  14. Jun 18, 2018 at 6:01 PM
    Tundraloves
    Any recommendations on the bigger fuel pump? As in what brand to go with?
  15. Jun 19, 2018 at 10:15 AM
    dirtydeeds
    Keith
    USA
    Walbro. Or dealership and get a flex fuel pump.
  16. Jun 19, 2018 at 10:22 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    I need nos
    RIP paul walker
    dirtydeeds likes this.
  17. Jun 19, 2018 at 1:31 PM
    Tundraloves
    RIP..
    Miss that dude
  18. Jun 19, 2018 at 1:31 PM
    Tundraloves
    Ganna call dealer today and see if I cant grab a pump! Thank you @dirtydeeds
  19. Feb 6, 2019 at 6:36 PM
    OBXTundra
    OBXTundra Member
    Southeast USA
    2018 Nissan Armada, 4x4
    Did this nitrous setup ever come to fruition?
    Interested, somewhat for entertainment. But I do already have a flex-fuel, so the fuel side is taken care of.:)
