Newbie
Discussion in 'New Member Introductions' started by kcpilot1, Sep 11, 2020.
  1. Sep 11, 2020 at 12:54 PM
    kcpilot1
    kcpilot1 [OP] New Member
    2013 tundra crewmax 4x4 TRD
    ARE bed topper
    Hey,
    I’m Kevin, thanks for allowing me to join your group, I’m suffering from covid cabin fever in the mountains of Colorado and am considering up building my 2013 crewmax 4x4 TRD with an ARE bed cap, into an over lander, I want to be able to travel around without using hotels etc and thought I’d add a Roof rack and rooftop tent, I want to keep the bed topper for protection of bed contents and want to know if anyone has installed a rooftop tent on the cab of a crewmax? The topper came with the truck and isn’t strong enough to support a roof rack and tent. Having real problems finding any info about roof weight limits on line, Thanks!
    Prostar 190 and YardBird like this.
  2. Sep 11, 2020 at 2:33 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
    Welcome aboard from The Pacific South West.
  3. Sep 11, 2020 at 4:02 PM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    Welcome from So Cal
  4. Sep 11, 2020 at 5:06 PM
    Welcome from NY.
  5. Sep 11, 2020 at 5:27 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Welcome from Nevada
  6. Sep 12, 2020 at 4:25 AM
    Welcome from Ohio
  7. Sep 12, 2020 at 5:00 AM
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    Welcome from Florida/PEI!
    Depending on how handy you are and not worried about getting your hands dirty and don't mind working with fiberglass. You can re-enforce the area where the rail are going to be mounted on with 3/4 plywood strip. Tailor your rail and pre-drill it first. Use a step-bit for less chances of chipping the gel coat. I used the bed rail system as my topper track. It's beefier than most aftermarket rails and did a custom cross bar to carry loads. Use a topper clamp to secure the topper on the bed instead of the bed rail mount. Temporarily secure the plywood with screws and with fender washes for the plywood to contour to the shape of the topper. You can use a hi-bonding adhesive or fiberglass resin to bond the plywood to the bottom of the topper. After it cures, remove the screws and lay some fiberglass to encapsulate the plywood. Then, drill through the plywood from your pre-drilled holes, 3M double sided tape, mount your rail, (used an aluminium flat bar running the length of the rail instead of a fender washer with my application). Fab at least 3 bars to even the weight distribution.
    If you want more support. You can add and encapsulate EMT tubing like a roll bar, base to base of the topper to help carry the load even better. (I will be doing this with my next topper)
    Hope that that helps.
  8. Sep 12, 2020 at 10:23 AM
  9. Sep 13, 2020 at 12:34 PM
    Rgross2112
    Rush
    2020 Silver TRD Limited
    Welcome from Pennsylvania
  10. Sep 13, 2020 at 12:35 PM
    Rgross2112
    Rush
    :popcorn:
  11. Sep 13, 2020 at 12:35 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
