Newbie with an “issue,” but no codes
Discussion in '1st Gen Tundras (2000-2006)' started by Ckat, Aug 19, 2020.
  1. Aug 19, 2020 at 6:59 AM
    Ckat
    Ckat [OP] New Member
    Long time lurker, but first time poster. Just added a 2006 Sequoia to the all Toyota fleet. This is my first experience with the 1st Gen. Tundra/Sequoia, so my “issue” may be normal, but it sure is stressful...
    130K on it. Seems mechanically sound. One-owner vehicle from Central Texas (no rust) that was hailed out.
    No issues on idling, acceleration, changing gears, etc. The problem comes when cruising, maintaining a steady speed. When cruising above 40mph or so, it feels like there are slight, but noticeable, changes in momentum. At first, it feels like a slight transmission slip, but closely watching the instrument panel reveals absolutely NO change in RPMs or speed. My second thought was that it feels like brakes being applied then quickly released, which would explain the no visible or audible change in RPMs that comes with transmission slippage.
    Again, this sensation is ever so slight, but noticeable. Using cruise control certainly minimizes the “issue,” but doesn’t alleviate it. No codes or lights of any kind.
    Any thoughts or ideas? Any insight would be greatly appreciated!!!
    YardBird likes this.
  2. Aug 19, 2020 at 7:07 AM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
    Welcome aboard from The Pacific South West.
  3. Aug 19, 2020 at 7:08 AM
    Ckat
    Thanks!
  4. Aug 19, 2020 at 8:52 AM
    Pucks18
    Pucks18 Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    Is it continuous or does it only happen once?
  5. Aug 19, 2020 at 9:13 AM
    Ckat
    Continuous as cruising... every 30sec to 1 min.
  6. Aug 19, 2020 at 11:00 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Clean your throttle body and see what happens. Then check for vaccuum leaks. It probably wouldn't hurt to check your plugs and coils either.
  7. Aug 19, 2020 at 1:56 PM
    Professional Hand Model
    Hand Protectors
  8. Aug 19, 2020 at 2:12 PM
    Backcountry_explorer
    Backcountry_explorer New Member
    2006 White Tundra TRD
    2.5” lift w/33’s
    Not sure it’s the same. Trans feels solid. Honestly it just feels like mine is constantly towing a load
  9. Aug 19, 2020 at 2:34 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    And it's likely the fuel filter has never been changed.
  10. Aug 19, 2020 at 2:51 PM
    ezdog
    ezdog New Member
    Gateway To The West
    I have felt something sort of like this when a Coil Pack was going bad but I also always get a code thrown with it too.
  11. Aug 19, 2020 at 3:58 PM
    I've definitely felt similar on my truck but it happens randomly for a short period, then goes away and may not happen again for the entire ride.
  12. Aug 19, 2020 at 4:15 PM
    Ckat
    I will clean the TB. Toyotas seem to be sensitive to carboned air intakes/TB.
    I also plan on doing maintenance stuff (change all fluids, plugs, fuel filter, check front end, etc.) for a clean slate and because it is time.
    I will report back, and keep the ideas coming. Thanks!
    bmf4069 likes this.
  13. Aug 19, 2020 at 4:16 PM
    Ckat
    Also planning on changing transmission fluid to rule out fluid/level problems.
    Pucks18 and bmf4069 like this.
  14. Aug 19, 2020 at 4:59 PM
    I guess I should clarify what my problem feels like. And this is relatively new for me, too, or I've only recently noticed it happening.
    Imagine driving on the highway at a cruising speed, then suddenly having the feeling or sensation your vehicle is decelerating, but you haven't let off the gas, and it doesn't visibly look like you're RPM'ing down or anything. I felt it a couple times recently while dropping off some bike parts to a fellow enthusiast from Clemson.
    @Ckat is that sort of what you have going on?
  15. Aug 19, 2020 at 5:18 PM
    ezdog
    ezdog New Member
    Gateway To The West
    Exactly what a coil going out feels like to me.
    I imagine it could be anything else that makes a cylinder go in and out too?
    shifty`[QUOTED] likes this.
  16. Aug 19, 2020 at 8:02 PM
    Stuck in the '00s
    Stuck in the '00s Experienced member
    Mikey
    SE Wisconsin
    2004 Phantom Gray DC 4X4 Limited Tundra
    Western plow, custom bed
    Sounds EGR-valve-ishy.
  17. Aug 19, 2020 at 8:18 PM
    Grumpy74
    Grumpy74 New Member
    2005 White Tundra SR5
    Run a scan for any codes or wonky data. How's the exhaust flow out the pipe? If your catalytic converter is plugged, it could bog the engine down. The next thing I would do is check the gear oil level in the rear or the fluid levels in the trans and transfer case. The other thing you could look at it the U-joints to see if they're binding up.
  18. Aug 19, 2020 at 11:59 PM
    Ckat
    Yes, but immediate. As soon as you notice it, you are back to “full power.”
  19. Aug 20, 2020 at 9:46 AM
    Mine lasted 1-2 seconds. When I noticed it, by the time I looked down at my gauge cluster to see if anything was hinky, it went away. But I noticed no flux in the gauges. I'm also not throwing any codes.
  20. Aug 20, 2020 at 12:30 PM
    jamess28
    jamess28 New Member
    Tulsa, OK
    2005 DC SR5 TRD Off-road 4x4
    Are you experiencing this with the AC on? My 2005 DC Tundra does this when the AC is on (compressor engaging/disengaging).
  21. Aug 20, 2020 at 12:43 PM
    773_eddie
    773_eddie Trd Pro
    Eddie
    Chicago
    Tundra Trd Pro
    12volt remote start, weathertec accessories, Trd Pro decals, Toyota console safe,VLEDS Puddle Lights,Frac Harness,TRD PRO front and Rear Sway Bar,NSV Hood Light Bar,ESP long box,AJT accessories,Thinkware U1000 dashcam, coachbuilder 1/3 Lift, HR LED’s,Pro comp Traction bars, JL complete System wit 2 10” subs, Kenwood DDX9907XR HU
    Anything cruising in D4 your Torque converter is going to engage and disengage when needed most of the time you will see about a 200 RPM change Sometimes noticeable and sometimes not elevation change temperature change touching your brake pedal will disengage your torque converter then it will apply again when computer commands it.
    You can test it by driving in D3 at this point 4th and TC will be off and see if you feel any hesitation at that cruising speed check your Transmission fluid that it’s filled to the right level
  22. Aug 20, 2020 at 2:39 PM
    Not sure about OP, but I was driving w/o A/C at the time.
  23. Aug 21, 2020 at 5:53 AM
    Pucks18
    Might aswell. Super easy on my 01, drain it out and put exactly 4 quarts and your perfect. Love how toyota made it so simple for the drain and fill
  24. Aug 21, 2020 at 6:58 AM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    I agree. Could be a torque converter "shutter" issue.
  25. Aug 21, 2020 at 9:08 AM
    Ckat
    Well, early indications are pointing to jamess28 nailing it. I can’t imagine this, but the problems have not shown themselves with the A/C off. Yesterday, I left the compressor off for several miles - no symptoms. Turned it back on, and the “issue” started immediately.
    I just can’t imagine a compressor robbing that much power. It isn’t nearly that noticeable in my Gen 3 4Runner with the gutless 2.7!!!
    I hope this is the “fix,” as it is certainly the cheapest option!
    I still plan on replacing the wear/maintenance items in a the spirit of best practices. Thanks to all for the insight!
  26. Aug 21, 2020 at 10:57 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    It could be the compressor or the clutch on it going out.
  27. Aug 21, 2020 at 10:59 AM
    Hand Protectors
    Check all your ground wires. The battery to fender, battery to firewall, and the little one on top of the A/C Compressor. Might need to clean all of them up and retighten.
  28. Aug 21, 2020 at 11:11 AM
    Actually, after reading this, I went for a drive to get lunch to test. Sure enough, put on the A/C on the way out, drive about 10 miles on the interstate, felt it twice. Drove the same distance back, didn't feel it once.
    Maybe I'm smoking crack. I swear I just had the vents on while I was driving and noticed it last. I just haven't been driving much lately.
    So mine is apparently A/C related too. My truck has the original compressor & clutch in it. Guess I should expect that to go out soon too eh...
    bmf4069 likes this.
  29. Aug 21, 2020 at 11:27 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Well shit. I guess I have something to check too.
  30. Aug 21, 2020 at 11:44 AM
    Hand Protectors
    Early 1st Gen hasn’t this problem. :yes:
