Newbie Tundra Questions
Discussion in 'General Tundra Discussion' started by stelio84, Jan 4, 2015.
  1. Jan 4, 2015 at 2:32 AM
    stelio84
    stelio84 [OP] New Member
    hey group.
    09 alpha h3 owner here having some problems, looking to possibly sell my h3 and buy a 2008 and up tundra crewmax. my primary concern is the length of the Tundra. it's a huge truck i know and i like how my h3 turns on a dime. i already know about the reputation of h3 owners. what ya'll recommend i look at? what year is best? i may or may not sell the h3; but my old man owns a 08 Tundra and he never had any issues since new and he abuses his truck big time. starts every time and i can't say that about my h3. my concern is the lenght of the tundra. i think crewmax is best for me? please advise ya'll.
    much appreciated :)
  2. Jan 4, 2015 at 4:20 AM
    Jack Burton
    Jack Burton New Member
    Little China
    2013 DC 5.7L TRD/OR
    Tires, Diamondback HD Tonneau w/ ATV Carrier
    The Tundra regular cab w/ 8' box, double cab w/ 6-1/2' box and the crewmax w/ 5-1/2' box are all on the same chassis, so are all 228.7" long. They all have the same 44' turning circle too, so the choice is really in whether you want max cargo, max interior or a balance between the two. The only variations to these specs are with a regular cab w/ 6-1/2' box that was available for a while, and with the double cab w/ 8' box, which I believe is still around with the current models. While the turning circle is definitely not great for off-roading, I think it's very good for a full-size truck.
    As far as which year(s) are best, I couldn't say. I have a '13 and love it, but I've never dealt with earlier years.
  3. Jan 4, 2015 at 12:01 PM
    stelio84
    thanks
  4. Jan 4, 2015 at 6:48 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    @Jack Burton is very much correct. The 07-13 are basically exactly the same with minor tweeks with front grill/hood, interior and options.
    You will have a choice between SR5, limited and Platinum. Options in each package increase as cost increases. Depends on the options you want.
    You will also have choices of add on packages like TRD Offroad, TRD Rock Warrior, TRD TSS and a few others I'm forgetting. All add on options/features.
    There is also a choice in engine. 4.6L or 5.7L V8. Unless money holds you back the 5.7L is the best choice.
    If your concern is only length then as Jack said all the standard production ones are the same length. Check the length vs garage space etc.
    You will be very happy with the Tundra. Great Truck.
    T-Rex266 likes this.
  5. Jan 5, 2015 at 9:29 PM
    stelio84
  6. Jan 5, 2015 at 11:08 PM
    csuviper
    Broomfield, CO
    With the sunroof and TRD I would assume that it is a Limited TRD Offroad.
    The wheels are a bit large in my opinion.
    The wheels also stick out pretty far. I would see if there are wheel spacers on there. If so you could remove them. Nothing wrong with wheel spacers (i use them), it just appears that the wheels are too far out which could cause uneven tire wear and premature wheel bearing failure.
    Mileage is over the average, roughly 15,250 per year if purchased in Jan 09. Should be ok though.
    I would check carfax but looks like a decent deal.
    Looks like a nice clean truck and worth atleast checking out. Look for oil leaks and coolant leaks. The 07-10 trucks are known to have leaking water pumps. Not a big deal except it will cost you ~$800 to get it replaced with labor. Ask if it has already been replaced or if it is leaking then push to reduce the cost ~$1000 to cover it.
  7. Jan 5, 2015 at 11:33 PM
    stelio84
    Thanks. Looking at it tomorrow.
  8. Jan 6, 2015 at 6:20 AM
    Are you looking for a 2WD or 4WD? Idk what your plans are, but keep in mind, this appears to be a 2WD.
  9. Jan 6, 2015 at 7:00 AM
    csuviper
    Broomfield, CO
    It is a 2WD in Florida. I assume OP is from Florida where 4WD is not needed and hard to find.
