Newbie Tundra owner
Discussion in 'New Member Introductions' started by daver11, Aug 3, 2025.
  1. Aug 3, 2025 at 1:26 PM
    daver11
    daver11 [OP] New Member
    Ice Cap 2014 CrewMac Limited 5.7L V8
    It always happens this way. I was looking for a used extended cab Chevrolet Silverado or Ford F-150 with a rear door that closed to the front of the truck. Chevy quit making them but Ford still does. Found a 2013 Silverado 1500 LT so all the bells and whistles. Saw it online at a Chevy dealer on Thursday, the Fourth of July. I drove to the dealer on Friday morning but it had already been sold. Significant other suggested we try the next sales lot for a used Silverado. It happened to be an AutoNationUSA. They didn’t have any Silverados or F-150s in the style I wanted. The salesman pulled up on his computer a white 2014 Crewmax Tundra that was in our budget. He went to retrieve the truck I went to retrieve my better-half. The salesman pulls the truck up. I’m not really interested other than figuring out if I can fit in it. I’m 6’6” 305 lbs. My acid test is to put the driver’s seat all the way back and then try to squeeze myself into the back seat. I fit with room to spare. After a test drive and a very long discussion, we bought it. We’re “Un-Tricking Our Ride” to better suit our needs. Having front and rear lift kits removed as well as replacing the 20” Fuel wheels and 35”x12.50”x20” tires with stock Toyota 20” alloy rims and a quieter set of tires. So far so good but I have learned that if you need lug nuts to get them at Costco. $2.76/ vs. $20/ at the dealer. So I gave up the barn door 6 foot bed for a shorter box and a much much bigger cab as well as Toyota reliability.
  2. Aug 4, 2025 at 4:30 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! Be careful to check those cheap lug nuts often. There's a reason they're so cheap.
  3. Aug 4, 2025 at 5:56 AM
    Welcome from NY.
  4. Aug 4, 2025 at 9:04 AM
    Tundra2n3
    Tundra2n3 2.5 Gen
    2015 Tundra DC SR5 TSS Off Road V8 5.7L 4x4
    Welcome and congrats!
  5. Aug 5, 2025 at 4:56 AM
    daver11
    Thanks for the Welcome! greetings and the advice about the lug nut. I’ve had good success with Costco lug nuts. The last time my 2013 Highlander had the tites balanced and rotated they noticed stock lug nut were starting to swell. I had them replace all except one on the right rear wheel. The chrome lug nut cover had broken loose from the underlying nut and would just spin. The were not equipped to remove it. I drilled several holes in the center of the cover, cut and peeled it back over itself and then jammed the next size larger impact socket on it. Viola, lug nut off. Picked up a new lug nut at the dealer and dropped the car off at Costco to get the last of the new tires installed. My brother-in-law told me about Costco having lug nuts at a better price than the dealer after the fact.
  6. Aug 5, 2025 at 6:48 AM
    Sean492
    Sean492 New Member
    Winston Salem, NC
    2018 MGM Tundra Sport
    Welcome from Winston Salem, NC. If you are 6'6" my suggestion for an initial mod is to look into Seat Jackers for the driver seat on desertdoesit.com. These are a great adjustment to the comfort of the front seat for taller drivers.
