newbie purchase 2000 Tundra using oil
Discussion in '1st Gen Tundras (2000-2006)' started by Steel68, Jul 22, 2018.
  1. Jul 22, 2018 at 9:55 PM
    Steel68
    Steel68 [OP] New Member
    2000 Tundra
    Newbie here, looking for help. We picked up a real nice 1st gen 2000 Tundra 4x4 with a 4.7, 283k miles runs and drives out great, but seems to be using an alarming amount of oil. No spots in driveway, records show oil was changed 500 miles ago, but is already a quart and a half low. Is this normal for a high mile 4.7 V8? I have other Toyota vans and cars with higher miles but none are using oil like this. Thanks in advance for your help!
  2. Jul 22, 2018 at 10:04 PM
    Ryooo
    Ryooo New Member
    Boynton Beach FL
    2014 CM SC Platinum
    TRD Supercharger 4.5 BDS lift 20” Method Standards sitting on 35 Nitto Grapplers Rigid grill top and bottom with lights AMP running boards Fender flares Magnum rear bumper Rear LED bar Air bags with onboard compressor Brake controller Alpine Navi Alpine amps x 2 Focal Separates front and rear 2 x JL 13s in a stealth box behind the back seat LTE cellular booster Rear seat under locked storage Dynamat from ceiling to floor LEDs all over Bed liner Bed rails Paint protector covering nearly the entire front end and more
    I think that’s common in many high mileage vehicles. My buddy runs Liqui Moli (high mileage lube) in his 200k+ Sequoia and it runs much better and burns less.
  3. Jul 22, 2018 at 10:25 PM
    Casper421
    In the woods
    06 DC
    Welcome! Is it possible whoever did the oil change didn’t fill to max? Does the service record show the amount used and if the filter was replaced? Fill her up and see if the oil level continues to drop.
  4. Jul 23, 2018 at 4:42 AM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    +1 .
    Top it off and verify consumption
    HBTundra likes this.
  5. Jul 23, 2018 at 5:34 AM
    Welcome from Texas
  6. Jul 23, 2018 at 5:39 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    I'm guessing they never checked it. Manual calls for 6.5 quarts but mine takes 7 with a stock filter.
  7. Aug 2, 2021 at 12:53 AM
    Gen1tom
    Gen1tom New Member
    Wisconsin
    2013 Tundra 5.7 4WD crew cab
    I'm having the same issue at 157000 mi. 2006 tundra v8.
  8. Aug 2, 2021 at 1:17 AM
    81 TOY
    81 TOY New Member
    Larry
    Vermont
    2008 Limited Crew Max
    Welcome!
  9. Aug 2, 2021 at 7:58 AM
    Desert Dog
    Desert Dog Nobody rides for free
    2001 SR5 AC 2WD 4.7l
    Bilstein 5100's, SPC UCA's, ATS HD leaves
    Welcome Tom. Some oil consumption is not uncommon or something to be overly concerned about. How much is the motor consuming? If it's consuming a couple of qts or more every 1,000 miles I would be concerned. If it's less than that, I wouldn't necessarily be concerned depending on the conditions the vehicle is driven under. You could do a dry compression test and then a wet one and verify what the differences are, if any, then go from there. That's what I would do if it were consuming abnormal amounts of oil. If it wasn't, I would just drive it as I always had and check the oil at every fill-up and top-off as necessary.
  10. Aug 2, 2021 at 8:01 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Dang, eat more oil then my rotary…
    Welcome from da Bay Area
  11. Aug 2, 2021 at 8:23 AM
    chunk
    chunk New Member
    110 miles north of Los Angeles, Ca.
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
    Did you verify the level when you got the truck? If not, how do you know if it was correctly filled when last changed. My go to with new to me vehicles, is to do a basic service, or oil and filter at the very least so you have a known baseline. Then you know. Good luck going forward.
    I'll just add this: when I bought a new car in 2012, It had 4 miles on the ODO, before I left the lot, I checked the oil level to make sure it was at the proper level. Cause, you never know without checking.
  12. Aug 2, 2021 at 8:35 AM
    Mine does not use oil. 10k miles between oil changes, never leaves the top mark. I would take the above suggestion and top off and monitor consumption. Even then, another oil change with the verified right oil and filter would be the final test to make sure the right weight
    chunk likes this.
