Newbie Lift Question (Shackles)
Discussion in 'Suspension' started by markiemark9, Oct 4, 2016.
  1. Oct 4, 2016 at 12:09 PM
    markiemark9
    markiemark9 [OP] New Member
    Mark
    Omaha, NE
    2016 SR5 TRD Crewmax
    RC 3/1 Leveling Kit, Blacked-out badges, stubby antenna, Husky floor liners, spray bedliner, low-profile toolbox, paracord wrapped grab handles, 33" Toyo Open Country M/T Tires,TRD Pro Headlights w/ LED Conversion,TRD Pro Grill, BAM TRD Replacement exhaust, TRD Shift Knob, TRD Rear Swayback bar
    I have a 2011 4wd Double Cab with a 3" Rough Country leveling kit (front lifted only). I can get a set of shackles that allow for 1"-2" lift heights in the rear.
    My questions are this:
    • If I'm only going up 1", can I still use stock shocks?
    • These are coming off a 2wd pickup. Are they safe for a 4wd also?
    Thanks!
  2. Oct 4, 2016 at 12:57 PM
    Toytec and coach builder make the shackles you want.
    Toytec shackles are adjustable and are a pretty good buy if you ask me.
    I went with a little longer shock when installing my 1.25" shackle lift. You can get away with factory for a bit if you are not cycling the suspension (off-roading).
  3. Oct 4, 2016 at 1:02 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Yes on all of the above questions.
    markiemark9[OP] likes this.
  4. Oct 4, 2016 at 3:36 PM
    markiemark9
    Mark
    Omaha, NE
    Thanks guys!
    ColoradoTJ likes this.
  5. Oct 4, 2016 at 3:39 PM
    Hope that helps.
    We just like to give good vibrations here at Tundras.com
    zcarpenter92 likes this.
  6. Oct 5, 2016 at 10:19 PM
    I can't believe nobody picked up on that little piece of awesomeness....guys are slipping.
  7. Oct 5, 2016 at 10:23 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
  8. Oct 6, 2016 at 5:57 AM
    ToyTec shackles should be just fine and still on sale at ToyTec.
  9. Oct 13, 2016 at 11:15 AM
    LiftMeUp
    LiftMeUp New Member
    I must admit I was set on a rear block, especially since I'm only going 1". I know most if not all say go with shackles and after reading all the post today, I think I'm going with the Toytec shackles. Seems like nothing bad is ever mentioned regarding shackle versus block. Plus, I like the option of either going 1" or 1.5".
    I know with CB, you must order the bushings but with Toytec it's an option. Is it necessary?
    Also, I really do plan on going 1" and staying with stock shocks. If I did decide for a little more lift and set them at 1.5", can I still get away with stock for the forseeable future?
    I'm assuming install is just as easy as blocks?
    Thanks in advance.
    jwl019 and Black Wolf like this.
  10. Oct 13, 2016 at 11:19 AM
    Get the bushings.
  11. Oct 13, 2016 at 11:32 AM
    csuviper
    Broomfield, CO
    I believe the bushings are $15. Allows better movement than with the stiff stock ones.
  12. Oct 13, 2016 at 12:11 PM
    LiftMeUp
    LiftMeUp New Member
    what about shocks (1" vs 1.5")?
    And installation?
  13. Oct 13, 2016 at 3:57 PM
    TheBeast The Beach
  14. Oct 13, 2016 at 4:00 PM
    csuviper
    Broomfield, CO
    I have the Toytec Boss shocks that come in the kit.
    TT-207R- Toytec BOSS Rear Shocks for 07+ Tundra 1-3"
    • Toytec Boss Zinc plated extended length rear shocks. Designed for a comfortable ride on and off road.
    • Heavy duty Nitro steel 1/2" shaft
    • Fits 2007 - current Tundra
    • Works with 1-3" rear lift
    • Priced as a pair
    • OEM style stem - Reuses factory bushings.
  15. Oct 13, 2016 at 4:03 PM
    csuviper
    Broomfield, CO
    The hardest part is to press out the old bushings from the leaf spring. Need to rent a bearing press tool from an auto parts store if you dont have one. Typically a deposit that you get back when you return.
  16. Oct 14, 2016 at 5:47 AM
    LiftMeUp
    LiftMeUp New Member
    That's a bummer. Trying to stay inexpensive as possible, hence, installing myself. Decided the shackle would be better than block but now it sounds like with rentals and cost difference the price keeps going up. Back to the drawing board.
    Thanks though.
  17. Oct 14, 2016 at 6:15 AM
    Cfincke
    San Antonio
    All the auto parts stores I have rented specialty tools from charge a deposit fee, but you get the full amount back when you return the tool. So the tool rental really costs you $0 if you return the tool.
  18. Oct 14, 2016 at 9:21 AM
    LiftMeUp
    LiftMeUp New Member
    Ok, that makes it better. I was thinking pay a price and the deposit. Weill definitely call on it and go with the shackles.
    Thanks.
  19. Oct 23, 2016 at 9:15 PM
    Joeshaker
    Joeshaker New Member
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Bilstein 6112/5160 trd sway bar and ride rite bags. Black and burnt orange wet okole seat covers.
    I installed the bushings yesterday. I made my own press for about 10 bucks. Get a 1.5 inch iron tee and a plug. Drill a 1/2 inch hole in the center of the plug. A one ft piece of all thread, nuts and washers big enough to fit the outer sleeve of the bushing. Double up the washers. Double nut that end, line up the iron tee with the spring eye and start wrenching. Safe and easy.
  20. Oct 24, 2016 at 8:29 PM
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Didn't come up with the press idea myself, saw it on the ol interweb someplace.
