Newbie Just figured to let you know I have had and loved toyota cars and truckss since 1980
Discussion in 'New Member Introductions' started by realpepperman, Aug 6, 2020.
  1. Aug 6, 2020 at 8:55 PM
    realpepperman
    realpepperman [OP] New Member
    Donald
    2005 Toyota Tundra 4.7 crew cab 4x4
    extra leaf spring to add 1000 ib payload
    Note: I kept my trucks for years
    - 1974 Toyota Hilux "Stick" Long Bed - 4 years.
    - 1984 Toyota SR5 "Stick" 4x4 - 18 years
    - 1987 Toyota Automatic - short bed -7 years
    - 2002 Ford Ranger XLT Automatic 4x4 - 4 years
    - 2005 Toyota Tundra SR5 Crew Cab 4x4 - 3 years
    This is my first Tundra 2009 and I have done a lot to this truck in 3 years.
    but I love the pickup and go this truck has.
    1) Overheated - replaced radiator, stat, and hoses, plus fluid. $250
    2) Replaced the blower fan under dash twice already. $125 and warranty used for
    the 2nd.
    3) Fixed the blender door - it was stuck open for 2 years is why I was not getting
    the heat out of the coil. Thought the coil maybe clogged - it was clear.
    4) New Speakers each door. - not original design. JVC - $85
    5) Installed camera front and back window. - $50
    6) Door lock motor - $25 still did not fix the alarm problem.
    7) Replaced door lock assembly on drivers door, easy to replace. - $235
    8) Replaced both headlight assemblies. - $175
    9) Snapped a caliper mounting bolt - drill/tap out the old one. not easy.
    Taps (2) and drill bits (3) - $80
    10) Replaced the bumper caps and passenger side rubber pad. - $20
    11) New Brakes shoes and pads front and back - $35 and $65
    12) Replaced emergency brake cables one was gone. - $20
    13) New Master Brake booster assembly. - $175
    14) New Drums and rotors. - $250
    15) (2) New Fog Lights. - $85
    16) (4) New Tires - $975
    17) (2) Toyota wheel center caps - $30
    18) Replaced all (8) spark plug ignition packs, boots, and plugs. - $140
    19) Replaced the O2 sensors (Bank 1/ sensor 2)(Bank 2 / sensor 2) - $90
    20) Replaced the exhaust system from the catalytic converter to tail pipe - $381
    21) Replaced the locking latch on the glove box. $14.95
    22) Broke a leaf spring towing 28 foot Hi-Low Camper - Replaced it and installed a
    extra leaf to increase the payload in the bed. $475
    Note: Lifted the back bed 3"
    Still need to fix the following.
    1) Leaking oil around the pan - got to raise engine to replace gasket - $20
    2) Replacing the window assembly on drivers door due to very slow up/down - $65
    3) Replacing the safety belt that is worn out in the drivers seat. - $60
    4) Reaching the 150,000 mile mark and plan on replacing the timing chain,
    sprockets, tensioner puller, and water pump. $250
    5) Boots are gone on the front struts will be replacing the strut soon too. - $350
    6) Calipers are sticking a little but not bad enough to replace yet - cleaned them
    up for now. - $85 each
    7) Replace worn floor mats with "Weathertech" floor mats. $175 front & $125 back
    YardBird, ViktorG and Rex Kramer like this.
  2. Aug 6, 2020 at 10:43 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
    Welcome aboard from The Pacific South West.
  3. Aug 6, 2020 at 11:12 PM
    Dceclipse
    Dceclipse New Member
    NORCAL
    Welcome!
  4. Aug 7, 2020 at 4:54 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  5. Aug 7, 2020 at 5:16 AM
    TokerJoker
    TokerJoker ΜΟΛΩΝ ΛΑΒΕ
    Travis
    Nowhere, Specific
    2014 Black SR5 4.6 Dbl Cab
    None.....yet
    Howdy from DFW and :worthless:
  6. Aug 7, 2020 at 5:17 AM
    Welcome from NY.
