Newbie here, 2000 Tundra, attempting DIY mods and repairs
Discussion in 'New Member Introductions' started by HomeOnTheRoad, Aug 13, 2022.
  1. Aug 13, 2022 at 9:58 AM
    HomeOnTheRoad
    HomeOnTheRoad [OP] New Member
    2000 Tundra manual V6 access cab
    Suspension: front - 2" Rancho lift, JBA UCA rear - HD leaf pack, Icon 3 aal pack, Hellwig helper spring, Rancho 9000xl shocks Brakes: PowerStop truck front disc, rear drum full rebuild Wheels/Tires: Vision Nemesis 17x9-12mm / Kenda Klever R/T 33x12.5 Many other old worn out parts replaced/upgraded
    Hey everyone,
    About Me: My name is Dan, I'm 31 and very new to all of this. I don't really have any experience working on vehicles but I'm trying to change that. I came across this forum a few months ago when I bought my truck and after seeing all the knowledge here and the willingness to help, thought it's about time I join the community.
    I currently live in Eastern Mass but will be hitting the road soon and traveling all over the country, and the plan is to eventually get myself up to Alaska. I thought about many different types of vehicles to live out of while doing this, and eventually went with the old reliable Tundra. I also have an old slide-in popup camper that I'm planning on throwing on there to live out of.
    I may not have a lot of mechanical experience, but I consider myself capable and a quick learner. I'd like to do as much of the work as possible myself and learn about the truck as I do.
    About the Truck: 2000 Tundra SR5 access cab 4WD manual v6 - 130,000 miles
    I bought this baby in March from the original owner in upstate New York. He was a bit of a DIY mechanic so kept it in decent shape. It had the frame replaced by Toyota about 10 years ago so it's solid although it has gathered a bit of its own surface rust at this point. The engine has been great so far (I replaced all spark plugs, coils, and wires immediately and also did the valve cover gasket). The manual transmission shifts smooth and it rides really nice... well if you don't pay attention to the completely shot suspension that is...
    Anyway, I drove the truck for work for about a month after I bought it to get a feel for it before bringing it into my garage, jacking it up, and beginning my rebuild process, which is where I'm at now. I really want to do this right, and hopefully if I treat the truck well, she'll treat me the same. So I'm taking my time, figuring out what I need to do, and just plugging away.
    What I've done and more plans:
    What I've done so far:
    valve cover gasket
    removed rotted bed
    dropped leaking fuel tank
    cleaned off all the rust I could from frame and other components (coating with FluidFilm)
    Replaced leaf springs with HD leafs, added Icon 3 pack (1-1.5" lift), and also have Hellwig helpers for when the camper is on
    Replaced rear shocks with Rancho RS9000xl
    What's planned:
    PowerStop drum brake assemblies for rear, disc brake assembly for front (includes calipers)
    Wheel bearings (currently figuring this out for rear, involves removing axles)
    Front end: Rancho 2" lift coil-overs, JBA uppers, lower ball joints (possibly more)
    Replacing fuel tank and all other fuel components
    New wheels and 33" tires
    Other small things here and there, eventually all brake and fuel lines will be replaced
    Ultimate Goals: Build a beast of a truck, capable of carrying the camper across the country, with some reasonable offroad capability as well but nothing too crazy, and have it last a long time, even after the camper comes off.
    Looking forward to joining this community, continuing to learn from you all, and share my experiences with building out my truck.
    Ely010606, YardBird and texasrho83 like this.
  2. Aug 13, 2022 at 5:48 PM
    RoadtripJim
    RoadtripJim New Member
    Cedar, MN
    2021 Silver SR5 - TRD Double Cab
    Welcome and greetings from Minnesota. Sounds like you have a good start.... how does the V6 handle the camper on hills and mountain roads. There are a few of those on the Al-Can Highway.
  3. Aug 13, 2022 at 5:56 PM
  4. Aug 13, 2022 at 6:02 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    welcome fellow Dan the Man!
  5. Aug 13, 2022 at 6:41 PM
    Welcome from NY.
  6. Aug 13, 2022 at 6:53 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Welcome from TX! You're gonna need a deep wallet joining this place.....lol
  7. Aug 13, 2022 at 7:06 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  8. Aug 13, 2022 at 8:15 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  9. Aug 13, 2022 at 8:18 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Welcome from Nevada
