Newbie Brake Question
Discussion in '2.5 Gen Tundras (2014-2021)' started by excavator78, Apr 16, 2019.
  1. Apr 16, 2019 at 8:32 AM
    excavator78
    excavator78 [OP] New Member
    2015Tundra CM Limited
    DAP Tuned
    Sorry if this has been addressed, searched the forum and didn't see anything. Need to replace brakes on my 15 4x4 CM. I am looking for a little more stopping power and was considering going with the PowerStop kit with drilled/slotted rotors. Thoughts, experiences?
    Second, when compressing caliper piston I always used to use a C-clamp and go. I have see where some are recommending cracking the bleed screw, compressing the piston and then topping off the brake fluid. Which method is preferred on these trucks or does it even matter?
    KickupTruck likes this.
  2. Apr 16, 2019 at 8:44 AM
    KickupTruck
    KickupTruck New Member
    Brooks
    2015 Limited Bronze Crew Max
    +100k miles = new to me.
  3. Apr 16, 2019 at 9:20 AM
    CrunchTimeHD
    CrunchTimeHD New Member
    Louis
    Easton Pa
    2011 tundra limited CrewMax
    I have them on my truck definitely can tell a difference in braking when towing. Yes definetly crack the bleeder open when compressing the piston you dont want that old fluid going back up. I didn't crack my and the pedal was horrible ended up doing a complete flush a week after I put them on. Make sure to follow the break in procedure.
  4. Apr 16, 2019 at 10:11 AM
    BWinter
    BWinter New Member
    Central California
    2018 White 1794, TRD Off Road, 4x4
    I used the PowerStop kit with drilled/slotted rotors on my 1999 Jeep Cherokee with a lift and bigger tires. I only installed it on the front as the rear is still drum brakes. I noticed an increase in stopping ability. It brought the brake pedal pressure that I had to apply back to the stock feel. I would buy it again.
