New with an issue already
Discussion in 'New Member Introductions' started by slowdisco, Jul 26, 2018.
  1. Jul 26, 2018 at 5:50 AM
    slowdisco
    slowdisco [OP] New Member
    2000 Toyota Tundra TRD White
    Hi,
    New to the forum and just bought a 2000 Toyota Tundra TRD. Overall a solid truck with minor rust. I live in central PA and we just had over a foot of rain in 5 days and noticed that the driver side floor was wet. Upon further investigation I found that the headliner was leaking at the top corner where the roof rail meets the windshield are and leaks all the way down to the floor. Any suggestions? Roof Rails? winshield?
    Thanks in advance.
  2. Jul 26, 2018 at 6:01 AM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    WELCOME
  3. Jul 26, 2018 at 6:02 AM
    Welcome from Ohio!
  4. Jul 26, 2018 at 6:02 AM
    nk1794
    nk1794 Always torque to spec
    San Jose, CA
    Welcome from CA
  5. Jul 26, 2018 at 6:08 AM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    WELCOME
  6. Jul 26, 2018 at 6:09 AM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    I would say the easiest and cheapest thing first is to get the windshield checked out but I doubt thats it. Maybe pull back the moulding on the rails and see if you notice any cracks
    Welcome btw!
    T-Rex266 likes this.
  7. Jul 26, 2018 at 6:12 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    welcome from TX!
    Have a body shop look at it. Unless the Wind shield isnt sealed correctly, may have to come out to address some rust issues.
    NewImprovedRon likes this.
  8. Jul 26, 2018 at 6:20 AM
    Welcome. Maybe an expert should check it.
  9. Jul 26, 2018 at 6:53 AM
    nk1794
    San Jose, CA
    Sounds like a bad seal on at the spot where it's leaking or maybe rust thru. My suggestion would be to take out the windshield to inspection and remount the windshield. This is not a DIY type of work.
  10. Jul 26, 2018 at 6:57 AM
    blue16
    blue16 New Member
    steve
    Mesa AZ
    2016 tundra
    Welcome from AZ.
  11. Jul 26, 2018 at 7:01 AM
    Welcome from Texas
  12. Jul 26, 2018 at 7:27 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Welcome from CO. Hope you get your issue fixed soon.
  13. Jul 26, 2018 at 7:32 AM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Bummer and welcome from OK
  14. Jul 26, 2018 at 1:56 PM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    Welcome to the party!!
  15. Jul 26, 2018 at 5:14 PM
    phnominon
    phnominon New Member
    Rich
    Upstate NY
    Blue 2015 SR5 Crewmax
    Welcome from NY, if you have glass coverage, an accident might need to happen to get it replaced. Most likely an incomplete seal between the glass and the hole. If you can find it you can fill it with RTV or something.
  16. Jul 26, 2018 at 5:22 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Welcome from Obx
  17. Jul 26, 2018 at 5:30 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Welcome from TN!
    boostedtrdpro likes this.
  18. Jul 28, 2018 at 5:10 AM
    slowdisco
    Thanks for the welcomes! The issue is rust under the molding so I guess that will have to be addressed asap. Thanks again for all the feed back.
  19. Jul 28, 2018 at 6:07 AM
    Steve6
    Steve6 New Member
    Tucson
    Welcome from Arizona. Good luck with your new truck.
