New wheels...lug and TPMS questions
Discussion in 'Wheels & Tires' started by randomZERO, Jan 19, 2019.
  1. Jan 19, 2019 at 10:10 PM
    randomZERO
    randomZERO [OP] New Member
    I currently have the first set of wheels on my truck. I purchased a set of the wheels in the second pic with tps and tires mounted.
    Will the old lugs fit the new wheels? Do I need to take the new tps sensors to a tire shop to get the truck to recognize them?
  2. Jan 19, 2019 at 11:01 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Tpms does need to be programmed by either a tire shop or the dealer.
    joonbug likes this.
  3. Jan 19, 2019 at 11:03 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
  4. Jan 19, 2019 at 11:36 PM
    kgb4187
    kgb4187 New Member
    I put 2016 Limited wheels on my 2007 SR5 and the included TPMS sensors were fine.
  5. Jan 20, 2019 at 12:03 AM
    randomZERO
    Thanks for the replys
  6. Jan 20, 2019 at 12:11 AM
    randomZERO
    One more. Do I need m12 or m14?
  7. Jan 20, 2019 at 12:54 AM
    randomZERO
    I figured it out. Thanks again
    gosolo likes this.
  8. Jan 25, 2019 at 5:54 PM
    dml996
    dml996 New Member
    david
    I'm in exactly the same boat with the same rim dilemma... Which nut did you use? Thanks and was is 14x1.5?
    randomZERO[OP] likes this.
  9. Jan 25, 2019 at 6:11 PM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    The 07+ Tundras use 14mm studs
  10. Jan 25, 2019 at 6:13 PM
    dml996
    dml996 New Member
    david
  11. Jan 25, 2019 at 10:33 PM
    randomZERO
    You got the correct ones
  12. Jan 27, 2019 at 9:50 AM
    dml996
    dml996 New Member
    david
    I'm installing these at they go on great but the washer doesn't sit flush against the surface of the rim, its slightly loose and wont go on any tighter. Is this normal?
