new wheels and tires - biggest for non Pro w no BMC?
Discussion in '2.5 Gen Tundras (2014-2021)' started by thedonn, Dec 18, 2021.
  1. Dec 18, 2021 at 6:14 PM
    thedonn
    thedonn [OP] New Member
    I have always loved the look of a tundra with oversized tires and blacked out wheels. I agonized over this decision and i love the finished product!i went with Method 305 18x9 +25 mm offset . tires are 295 70 18 falken AT3 e load. to me its the perfect amount of poke and clearance. these pics are on bone stock suspension - almost no rub at all with front and rear mudflaps removed. i think once i push front plastic forward it wont rub at all but I am also adding bumper shims for extra room. i will add my 6112s in the next week or so for an extra couple of inches in the front. Im not sure if i want to raise more than the 1.9 or if i want to do anything to the rear. besides the 5160s. i need to find some wheels locks for this thing and black out the center caps but i love the look of this truck and the size wheels and tires i picked out !
  2. Dec 18, 2021 at 6:17 PM
    Burdturger
    Burdturger New Member
    Nice set up! If center caps aren't available for your wheels you can just spray paint the center hub with the wheels off.
  3. Dec 18, 2021 at 6:19 PM
    thedonn
    the chrome and lights really stick out now. i am working on the bumper caps but will add debadge or rebadge asap. then new rear head lights , center stop and tail lights. i will also probably just remove the bedside stickers
  4. Dec 18, 2021 at 6:20 PM
    thedonn
    it came with centercapa but they have a chrome METHOD on each one . I am gong to paint the center black
  5. Dec 18, 2021 at 6:50 PM
    Pac12AfterDark
    Pac12AfterDark New Member
    Mmm beef bus.
  6. Dec 18, 2021 at 6:59 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Oh my Sir. You're, uh, um, well........you're rather BIG Sir.
  7. Dec 19, 2021 at 5:24 AM
    2mchfun
    Will they clear the fenders with max suspension up travel? Hard to tell by the photos. Wouldn't want you to tear up a fender when you hit a big bump.
    pvn.beluga likes this.
  8. Dec 19, 2021 at 9:37 AM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Reverse full lock? U-turn? Anything rubbing? Taken off road?
  9. Dec 19, 2021 at 9:49 AM
    thedonn
    they do at full turn in reverse but not much ....i dont think they will when i move the plastic or install the bumper shims
    pvn.beluga[QUOTED] likes this.
  10. Dec 19, 2021 at 11:31 AM
    thedonn
    i dont think so. its not a daily driver so it will be gentle only until shocks are added. I am trying to figure out is shocks at 1.9 or 2.3 are enough or if i need to add a little more.
  11. Dec 19, 2021 at 12:37 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    With +25mm offset, I'd think you will need to fold the edge of your skid plate a bit. My tires are narrower, at 275/65/20, and scraped the skid plate with +30mm offset. Good looking setup!
    Pac12AfterDark likes this.
  12. Dec 19, 2021 at 3:14 PM
    rruff
    rruff New Member
    2016 Tundra SR DC Long
    IME the bumpstops keep the wheel from moving that far... even on large bumps mine never hit anyway. No lift.
  13. Dec 19, 2021 at 6:36 PM
    2mchfun
    Just looking out for OP cuz it looks pretty close IMO.
  14. Dec 19, 2021 at 7:34 PM
    thedonn
    I needed to read your post - it is close!
    2mchfun[QUOTED] likes this.
  15. Dec 20, 2021 at 3:00 AM
    tundra121
    tundra121 New Member
    Tire set up makes a huge difference once you lift it will be even that much better!!
    If you it’s lifted 2.3”a you should be ok I still had to fold (or cut) the skid plate slightly. The front plastic I altered just a bit so it won’t rub.
  16. Dec 29, 2021 at 6:30 PM
    thedonn
    before the lift
  17. Dec 29, 2021 at 6:34 PM
    thedonn
    after the lift 6112s set at 1.9" - rear 5160 w no lift
    rruff and AircareTundra like this.
  18. Dec 31, 2021 at 7:44 AM
    thedonn
    i discovered with all of this that I dont hav a skid plate despite having the off road pkg. I was curious if they would rub with the +25 offset
    rruff likes this.
  19. Dec 31, 2021 at 8:15 AM
    rruff
    rruff New Member
    Your truck looks great and has the right amount of lift. :thumbsup:
    The stock skidplates suck, and make changing the oil a bear. I have an RCI on order. If you won't be offroading much you don't need one.
    tweetlessfeags likes this.
  20. Dec 31, 2021 at 8:42 AM
    thedonn
    the pics dont really look different but standing in front of it seems like a HUGE difference lol
  21. Jan 3, 2022 at 4:45 PM
    tweetlessfeags
    tweetlessfeags New Member
    2016 Platinum Tundra
    OME Nitrocharger Dakar Leaf pack+Add a leaf RCI Engine/transmission/differential/gas skid Bash Fabrication Weld-On Sliders Method 703-17" 0 offset ARB Dual compressor Victory 4x4 Engine bay compressor mount Cooper STT PRO 315/70/r17 Decked Drawers Cali Raised Led Ditch Lights WeBoost Reach OTR w/ Rhino Rack Aerial Mount Piaa SuperWhite Headlight bulbs Meso Customs Interior Light Kit Dometic CFX3 55IM Dobinsons Snorkel SnorkelUpgrade Precleaner GFC V1 AluCab Shadow Awn All the Tint
    +1 for the RCI Skids and Methods. I'm running 703s at 0 offset with 315/70/r17. OME lift is slightly larger than yours though. Great looking truck.
  22. Feb 16, 2022 at 4:23 AM
    thedonn
    needs a little rear lift. Roadmaster active suspension ordered
