New Wheel and Tire Bumpy Ride Issue
Discussion in '3rd Gen Tundras (2022+)' started by TheDryEraser, Feb 15, 2024.
  1. Feb 15, 2024 at 1:25 PM
    TheDryEraser
    TheDryEraser [OP] New Member
    2023 Platinum
    I just purchased a set of Method MR316s in an 18x9 with a +18 offset and some General Grabber A/TXs in a 275/70/R18 from Tire Rack for my '23 Platinum that has no modifications done to it. I had them installed at a reputable local tire warehouse. When they got put on the ride was bumpy, took them back and had them rebalanced and Tire Warehouse said that Tire Rack messed up the balance. A couple of days go by and they are still a bumpy ride. I took my truck to the Toyota Dealership for a rebalance and an alignment. I've done the chalk test and thoroughly investigated the tires for any anomalies. I still have a bumpy ride and I'm almost at a loss as to what is causing it. I also run the tires at 32 PSI, they were put on at 36 PSI, as I live in New England. Has anyone had any of the same issues?
  2. Feb 15, 2024 at 1:39 PM
    NickBrewer
    NickBrewer New Member
    2023 Toyota Tundra 1794 Edition Magnetic Gray Metallic
    Did you purchase the E rated General Grabber A/TX tires? If so, that is probably the source of your bumpy ride. If you do have the E rated tires, you probably need to run higher tire pressure than 32 psi.
    raylo and KNABORES like this.
  3. Feb 15, 2024 at 1:45 PM
    TheDryEraser
    2023 Platinum
    I just double checked and they are S rated.
  4. Feb 15, 2024 at 1:58 PM
    NickBrewer
    When I switched from the 20" wheels/tires that came stock on my 1794 to Method 318's (+40mm offset) with Continental TerrainContact A/T 265/70-18 tires, the ride improved dramatically over the stock combination. I got my wheels/tires from TireRack mounted and balanced. Maybe one of your tires is out of round, not an unheard of issue.
    Oey12 likes this.
  5. Feb 15, 2024 at 2:03 PM
    TheDryEraser
    2023 Platinum
    Ill see if I can figure out if this is the problem. I googled it and feeling the vibration in my seat should indicate that one of the rear tires is out of round.
  6. Feb 15, 2024 at 2:05 PM
    Hank Hill
    Hank Hill New Member
    Someone correct me if im wrong, but i think thats a speed rating and not a load rating.
    landphil and Hella Krusty like this.
  7. Feb 15, 2024 at 2:05 PM
    Hella Krusty
    Hella Krusty New Member
    If the tire was out of round it would have surfaced in the 3 wheel balances. If it’s out of round on a balancing machine you would have to be blind not to notice it
    Do these wheels you bought need spacers to center them? I put after markets on my daughters Venza and after 4 attempts to stop the horrid ride, they figured out it needed a spacer. ( I am not sure if spacer is the right word)
  8. Feb 15, 2024 at 2:11 PM
    I’ve not seen a 275/70/18 available in a P or C rating. All E’s. It’s a combo of stiffer, less forgiving sidewall (a plus and in this case a minus) and the additional weight for which the shock and spring were not tuned for.
  9. Feb 15, 2024 at 2:13 PM
    NickBrewer
    KNABORES likes this.
  10. Feb 15, 2024 at 2:18 PM
    TheDryEraser
    2023 Platinum
    I did the math on the OEM wheels and tires, the new wheels and tires come in about 2lbs less than the OEM.
    Hank Hill[QUOTED] likes this.
  11. Feb 15, 2024 at 2:18 PM
    NickBrewer
    According to the TireRack website the General Grabber AT/X is available in a non E-rated version which is designated 116s
    KNABORES[QUOTED] likes this.
  12. Feb 15, 2024 at 2:20 PM
    That’s awesome! OP, did you get these?
  13. Feb 15, 2024 at 2:21 PM
    TheDryEraser
    2023 Platinum
    Yes, these are the exact ones I got.
  14. Feb 15, 2024 at 2:24 PM
    NickBrewer
    Probably worth verifying that the hubcentric rings that came with your Method wheels are in fact still there...
  15. Feb 15, 2024 at 2:24 PM
    Factory platinum wheel and tire setup is around 74-75#, so your pretty much a wash there. Is it bumpy when you hit bumps? Or when your driving down a smooth road?
  16. Feb 15, 2024 at 2:24 PM
    Hank Hill
    Well then, i am surprised these yield a bumpy ride.
    I have same tire/size in E load rating, and its evident that they are stiff, but no different than any other E load rated tired. I do have Bilsteins 5100's to help cope with added unsprung weight.
  17. Feb 15, 2024 at 2:25 PM
    TheDryEraser
    2023 Platinum
    Will do, I am going back to the dealership on Saturday and I will mention it to them.
  18. Feb 15, 2024 at 2:25 PM
    bornxbackwards
    bornxbackwards New Member
    Bruno
    QC, Canada
    2024 Blueprint Tundra SR5 CrewCab
    Cooper Discoverer AT3 XLT, Bison Soft Tri-Fold Tonneau Cover, Debadged..
  19. Feb 15, 2024 at 2:28 PM
    TheDryEraser
    2023 Platinum
  20. Feb 15, 2024 at 2:57 PM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    The ol hub centric vs. lug centric. I had the same issue with my Methods, I had the tire shop torque them in the air and not on the ground. That seem to do the trick, haven't had an issue since.
  21. Feb 15, 2024 at 3:32 PM
    jeffcoseo
    jeffcoseo New Member
    Jeff
    And Lug nuts - Did you get the extended reach threads that burrow down inside the lug holes?
  22. Feb 15, 2024 at 3:48 PM
    TheDryEraser
    2023 Platinum
    Yes I did and I make sure the lugs are torqued to proper spec. I think it might be the hub centric issue.
  23. Feb 15, 2024 at 7:14 PM
    Cassidy1866
    Cassidy1866 New Member
    2023 Tundra Limited TRD Off-Road
    ^^^ THIS ^^^
    Exact same story with my Methods. Even with Method’s lug nuts and hubcentric rings, it was having the lug nuts torqued in the air that solved it for me.
  24. Feb 23, 2024 at 6:04 AM
    arrampico
    arrampico New Member
    2023 SR5 CM 4X4 SB Silver Tundra
    Op do you have a pic? I’m going almost the same set-up (exact tires) but different wheels with a +20 offset. Curious on how it looks!!! My wheels are on the way now.
  25. Feb 23, 2024 at 7:31 AM
    lukedias00
    lukedias00 New Member
    2014 Tundra 4x4 Off-Road Limited
    Make sure the shop didn't put balancing beads in them, that happened to me and for a year I couldn't figure out why the ride was rough sometimes and smooth others. Finally had the beads taken out and weights put on and it made the world of difference.
    You said it vibrates? Could be the front diff drivers side needle bearing, bushing is installed to replace that.
  26. Feb 23, 2024 at 7:57 AM
    myfirsttundra1
    myfirsttundra1 New Member
    2023 Platinum crewmax
    Wow I didn’t realize the 3rd gen has the same issue! My 2016 definitely needed that done
  27. Feb 23, 2024 at 8:02 AM
    lukedias00
    Ope I didn't see 2023. Not sure on that one.
