New user and leveling kit
Discussion in 'New Member Introductions' started by Shadowfax_, Apr 29, 2022.
  1. Apr 29, 2022 at 9:08 PM
    Shadowfax_
    Shadowfax_ [OP] New Member
    Sam
    2018 White Limited Tundra
    None.. yet
    Hello all, I'm new to the group as I recently picked up a white 2018 Tundra after owning a Tacoma. I'm almost certain there is a thread about leveling the front end. But let me be more specific about what I want from the leveling kit. I would obviously want the front lifted, but not so much that there will be rake in the rear if I'm hauling a heavy load.
  2. Apr 29, 2022 at 9:13 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Welcome from Nevada.
  3. Apr 29, 2022 at 9:53 PM
    Booney
    Booney New Member
    Northern Colorado Mountains
    Smoked Mesquite 2021 1794 Off Road TRD
    Best to start out with a budget then see if that budget will meet your goals as far as ride, off road capabilities, tow capacities and handling. For instance if youa re going to add a custom bumper later on then you should make sure you get springs that will handle the weight of the new bumper. Just one example of the planning that should go into your build if you don't want to spend money two or three times for the same item, such as front coilovers.
    Here is a good place to start:
    https://www.tundras.com/threads/official-tundra-wheel-and-tire-setups-pics-and-info.95/
    Welcome from northern Colorado.
    1lowlife likes this.
  4. Apr 30, 2022 at 4:48 AM
    Welcome from NY.
  5. Apr 30, 2022 at 6:42 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  6. Apr 30, 2022 at 7:07 AM
    RoadtripJim
    RoadtripJim New Member
    Cedar, MN
    2021 Silver SR5 - TRD Double Cab
    Welcome and greetings from Minnesota. You’re supposed to establish a budget? I thought the goal was see it, buy it. Anyway, enjoy your new truck.
    WFD473 likes this.
  7. Apr 30, 2022 at 7:24 AM
    WFD473
    WFD473 Long Live The V8
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    Welcome from IL! I'm interested in this as well.
  8. May 2, 2022 at 12:15 PM
    2017_Tundra_AZ
    2017_Tundra_AZ New Member
    Welcome from AZ! I would suggest keeping a positive rack if you plan on towing, but level kits are nice and cheap.
  9. May 6, 2022 at 11:46 PM
