New UCA/LCA instead of leveling kit or spacer??
Discussion in 'Suspension' started by kevine0001, Sep 24, 2019.
  1. Sep 24, 2019 at 8:52 AM
    kevine0001
    kevine0001 [OP] New Member
    Kevin
    I have a 2017 CM TRD OR. Was going to do spacer or leveling kit, simply to level it and give me about an inch or two of additional clearance. Not intending to go bigger than 285s.
    Anyone ever go with new UCA/LCA instead of spacer, to level the truck? I'm assuming this would maintain the suspension travel and once aligned, would not affect geometry (meaning it won't cause unnecessary wear on other front end parts [CV, bj, etc.])
    thanks for any input
  2. Sep 24, 2019 at 2:17 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    A new upper or lower control arm isn’t going to affect the ride height of your front suspension. Ride height is dictated by the spring and shock.
    619Tundra likes this.
  3. Sep 24, 2019 at 2:21 PM
    six7zero
    six7zero New Member
    Pacific Northfresh 503
    15 SR5 Crewmax
    If your talking about spindle lift it only apply to 2wd
  4. Sep 24, 2019 at 2:24 PM
    kevine0001
    Kevin
    4WD, just trying to figure out better way to level truck with slight lift other than spacers or expensive lift kit.
  5. Sep 24, 2019 at 2:47 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
  6. Sep 24, 2019 at 2:49 PM
    kevine0001
    Kevin
    Scuba, thx. will those work for 4wd?
  7. Sep 24, 2019 at 3:46 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    Yes they will.
  8. Sep 24, 2019 at 5:29 PM
    619Tundra
    619Tundra New Member
    San Diego, Caifornia
    2017 Black Tundra Double Cab SR5
    Bilstein 5100s.
    kevine0001[OP] likes this.
