New twist on a stuck tundra tailgate - will need a pro to help me on this
Discussion in '2nd Gen Tundras (2007-2013)' started by ejonco, May 27, 2021.
  1. May 27, 2021 at 5:20 PM
    ejonco
    ejonco [OP] New Member
    Hello.
    2007 that has a stuck tailgate. WAIT! This is not like all the other posts. I was trying to replace the plastic holders on the metal rods that go to the latch in the corner. Somehow on both latches I ended up turning the 90 degree latch and now they are sprung. Now the 90 degree thing just turns.
    Is there a way to release the latches on the tundra tailgate without the metal rods pulling on the 90 degree thingy? Is there a release point you can stick a screw driver in that will release the latch?
    Thanks for any insight.
  2. May 27, 2021 at 5:56 PM
    jbrnigan
    jbrnigan New Member
    Midwest
    2007, 5.7L, 4x4, Crewmax,
    If I understand your dilemma, you will need to remove the tailgate cover from the inside of the bed. This will let you access the rods that trip the latches on either side.
    joseph_womack, Terndrerrr and D4x4TRD like this.
  3. May 27, 2021 at 6:50 PM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    3/1 Lift, 35s, Front Bumper, etc etc
    @jbrnigan is right, while the tailgate is closed, open the cover while you're standing/sitting inside the bed, if you pull on the two rods, it should release the latches on either side causing the tailgate to fall down
    Zero One Actual likes this.
