New Tundra Owner
Discussion in '1st Gen Tundras (2000-2006)' started by tdchester, Jul 27, 2016.
  1. Jul 27, 2016 at 3:30 PM
    tdchester
    tdchester [OP] New Member
    Todd
    2005 Toyota Tundra SR5
    Just purchased my first Tundra a few months ago. 2005 SR5 Crew Cab. Having issues with Cat. Conv. From what I've seen, are there 4 Cats on the exhaust system? 1 prior to O2 sensor and 1 after on each side? Just want to be clear. The two before the O2 sensors don't look like a typical Cat. Any help would be appreciated.
    Yotalover88 and T-Rex266 like this.
  2. Jul 27, 2016 at 4:10 PM
    fuguchan
    fuguchan New Member
    Jeff
    St. Mary's County, MD
    2018 Tundra 1794 Edition Smoked Mesquite
    ARE-Z Cap, Bed Rugs, Husky Mats
  3. Jul 27, 2016 at 7:06 PM
  4. Jul 27, 2016 at 7:27 PM
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    Well you have 4 oxygen sensors. Cats should be between the two sensors on each side. There may be a resonator behind once it collects into one pipe
  5. Jul 27, 2016 at 7:43 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Not much knowledge in my itty bitty brain when it comes to 1st gen
    Welcome all the same!!
    Yotalover88 likes this.
  6. Jul 27, 2016 at 10:02 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Welcome!
  7. Jul 28, 2016 at 5:01 AM
    tdchester
    Todd
    My question is, can I do away with the cats, post O2 sensors? im not too sure on the cats (integrated cat) pre-o2 sensors. Seems like a little overkill to me.
  8. Jul 28, 2016 at 6:24 AM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Those are called "Cleanup cats" they are only there to help it passes emissions. So yes u can get rid of them and not have a light come on
  9. Jul 28, 2016 at 7:19 AM
    tdchester
    Todd
    You are referring to the cats post-o2 sensors, not the cats in between the o2 sensors, correct?
  10. Jul 28, 2016 at 1:50 PM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    correct. each side of the engine has a bank of 4 cylinders. the pre cat sensor for each bank tells the engine how its running lean or rich. then you have a catalytic converter on each side that cleans up the exhaust. then you have a sensor on each side post cat. these sensors tell the engine if the cats did their job or not cleaning the exhaust stream. anything after those last sensors are called cleanup cats. some vehicle come with resonators to change the sound or provide more back pressure to the engine. then lastly you have your muffler.
  11. Jul 28, 2016 at 2:10 PM
    tdchester
    Todd
    Ok, just wanted to be on the same page as you. I put a scanner on it, got the P0402 error (bank 1, passenger side I think). Cat Conv I would presume. What are your thoughts on changing the o2 sensors on the side that is giving the error before changing out the Cat?
  12. Jul 28, 2016 at 2:32 PM
    Yotalover88
    Yotalover88 "If it ain't broke don't fix it"
    James
    2013 white tundra
    Rhino liner, bed mounted tool box "no stripper pole" paracord wrapped oh shit handles, Lowes stair tread door seal protectors, handgun holder for my dedicated truck gun. My list of wants is much longer!
    Welcome from Florida my first tundy was a first gen she was a beauty and a beast!
  13. Jul 28, 2016 at 3:58 PM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    R u sure on that code number? Normally cat codes are p0430 and p0420
  14. Jul 28, 2016 at 4:08 PM
    tdchester
    Todd
    Fat fingers, P0420 is the code.
  15. Jul 28, 2016 at 4:10 PM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Yes bank 1 cat is toast. No oxygen sensors wont help the situation unless you also have codes for sensors.
  16. Jul 29, 2016 at 4:11 AM
    tdchester
    Todd
    Ok, that's what I was leaning towards as well. Just needed an opinion from someone with experience on the Toyota. I appreciate your help.
