New Tundra owner with Keyless Entry (Key Fob) question.
Discussion in 'New Member Introductions' started by HMK2015ToyotaTundra, Apr 2, 2017.
  1. Apr 2, 2017 at 9:31 PM
    HMK2015ToyotaTundra
    HMK2015ToyotaTundra [OP] New Member
    2015 Toyota Tundra
    None
    I just bought a 2015 Tundra this last week. The prior owner bought it with the "Work Truck" package.
    'WORK TRUCK PACKAGE – Adds durable vinyl seating and flooring, and removes wireless door lock feature. On Regular Cab models power windows and the speed- and shift-sensing power door lock features are also removed.' So, my truck didn't come with key fobs and the sales manager was not really willing to help on that issue either. I'm trying to figure out if the truck is already set up to be able to use key fobs or does the truck have to be programmed now to accept key fobs for keyless entry? I have fobs from my prior Tacoma and have set them in the past but I keep getting conflicting information as to if it's possible or not and I know if I go to a Toyota dealership, they WILL charge me an arm and a leg if they can in order to do it.. Any help would be greatly appreciated!
  2. Apr 3, 2017 at 9:00 AM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    The receiver should be located in the passenger side rear pilar. 1st thing to do would be to check there and see if you have the receiver. If not, I'm sure you can order one from @Roman. Once you have the receiver, I think you need to have the feature turned on via TechStream.
    Really, though, your best bet is to just buy a cheap Clifford alarm with its own fobs, and install that.
  3. Apr 3, 2017 at 9:06 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Welcome from CO!
  4. Apr 3, 2017 at 9:27 AM
    HMK2015ToyotaTundra
    2015 Toyota Tundra
    None
    Thank you bobeast, I will check it out. I did see that you could by the software from TechStrram and the cable that plugs into the computer and truck on the internet, so that could be an option also. There is a big possibility that I may just install and aftermarket alarm to make sure I am all set. I appreciate your assistance.
    Law323 likes this.
  5. Apr 3, 2017 at 11:18 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Toyota parts are usually overpriced unless you talk to @Roman
    If it's too much...aftermarket is probably the best way to go
  6. Apr 3, 2017 at 12:28 PM
    HMK2015ToyotaTundra
    2015 Toyota Tundra
    None
    Thank you. I will check into it.
  7. Apr 3, 2017 at 1:25 PM
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab (I call it my Land Yacht)
    I'd recommend going with a Viper system. That'll give you wireless entry and remote start.
  8. Apr 3, 2017 at 1:51 PM
    rockjockey
    rockjockey Per ardua ad astra!
    Spring, TX
    2016 White Tundra TSS
    Welcome from Texas!
  9. Apr 23, 2017 at 4:11 AM
    Tundraplatinum
    Tundraplatinum New Member
    2016 Platinum CM
    It would be almost impossible to add in factory setup and get it working. Aftermarket is gonna be your best option
  10. Apr 23, 2017 at 5:25 AM
    Bienvenidos de Tejas! Pics of your ride?
  11. Apr 23, 2017 at 7:06 AM
    Welcome aboard from CO!
