New Tundra owner question on leak
Discussion in '2nd Gen Tundras (2007-2013)' started by coastaldesert, May 16, 2021.
  1. May 16, 2021 at 10:19 AM
    coastaldesert
    coastaldesert [OP] New Member
    Oregon Coast
    Hello everyone!
    New Tundra owner here. Picked up a one-owner 07' with the 5.7L. Only has a mere 53K on the clock.
    Anyhow, I was cleaning it yesterday and noticed a drop on the ground, appears to be a slow transmission fluid leak? What do you guys think is going on here?
    Thanks in advance.
    Prostar 190 likes this.
  2. May 16, 2021 at 10:29 AM
    Cg13055
    Cg13055 @yota.parts.distributor
    South Florida
    Mcfly Tundra @yota.parts.distributor
    2012’4.0 Tundra-2004’4.7 crewcab-2021 2.7 Tacoma
    haven't seen this one before, clean it off real good and keep watch for new liquid
    RitcheyRch likes this.
  3. May 16, 2021 at 10:55 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Looks like that may be coolant
  4. May 16, 2021 at 11:34 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! I agree with @Cg13055. That will also give you a clue about the leak rate.
    Cg13055 likes this.
  5. May 16, 2021 at 12:29 PM
    Dr Doobie
    Dr Doobie Growing member
    Talkeetna,Alaska
    '07 RCSB 5.7 SC'd 4x4 SSM
    Like @frichco228 said, looks like coolant
    Get a drop on your finger and taste it.
    If it sweet, it's coolant
    Filthyphil and Cg13055 like this.
  6. May 16, 2021 at 2:17 PM
    coastaldesert
    Oregon Coast
    Thanks fellas for the responses.
    I’ll give it a taste next time I check on this.
    From what I just tried to research real quick, there is no way to check ATF fluid level without taking it to someone?
  7. May 16, 2021 at 2:25 PM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    Welcome from So Cal
  8. May 16, 2021 at 2:27 PM
    mtndds98
    mtndds98 New Member
    2013 Silver Tundra CrewMax
    6" ProComp Stage 1 lift
    Coolant valley leak from the top of the engine? Happened to me.
  9. May 16, 2021 at 2:28 PM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    Yes, there is a procedure to check the ATF level where you jumper some pins no the OBD harness to put the truck into a special diagnostic mode (and lock open the transmission fluid thermostat) and certain lights will flash on the dash when the transmission is up to temp, then you can open the overflow underneath to see if any fluid comes out. You would expect almost nothing to come out of a properly filled truck, but if none comes out then you would need to repeat the test after the tranny has cooled down a bit with the fill plug pulled so you can add fluid when the temp indication flashes and see how much it takes to get some to dribble out.
    99% that is coolant you're seeing though.
  10. May 16, 2021 at 2:31 PM
    coastaldesert
    Oregon Coast
    What was the solution? I looked a little harder and does seem to be coming from further up than I suspected…
  11. May 16, 2021 at 2:34 PM
    mtndds98
    mtndds98 New Member
    Mine was still under warranty so the dealer removed the coolant valley cover, placed a new gasket seal (the old seal was very thin on the rear of the valley), then bolted everything back up. I could have easily done it myself but I had to take advantage of the warranty.
  12. May 16, 2021 at 5:53 PM
    greghoro
    greghoro New Member
    Greg
    2012 Sequoia Limited
    I would expect the trans fluid to be much darker from an internal leak.
    Cg13055 likes this.
  13. May 16, 2021 at 6:01 PM
    Welcome from Ohio
  14. May 17, 2021 at 6:10 PM
    coastaldesert
    Oregon Coast
    Thanks for the welcomes!
    I wiped it down and it did return, not immediately after driving but after it sits for couple hours or overnight. It does appear to be coming from a little further up...
    Taking it in to my local import shop on Wednesday for an all around inspection and for them to take a look. All the digging I've done makes me think it could be the water pump? Not sure but will find out and let you all know!
  15. May 17, 2021 at 6:16 PM
    ARB1977
    ARB1977 New Member
    Anthony
    DFW
    24 Tundra CM SR5 4x4 CSM build date 05/24
    ATF will not crust over, coolant will when it dries.
    Filthyphil likes this.
  16. May 17, 2021 at 6:17 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Its coolant, it crystallizes like that.. you can ask me how I know... my water pump exploded at 25k and my whole engine bay was caked with crystalized pink stuff....
  17. May 18, 2021 at 7:36 AM
    Cg13055
    South Florida
    You can check it but it won't do much good, even taking it to someone all they will do is take the cap off and see if there is anything there lol
  18. May 19, 2021 at 4:40 PM
    coastaldesert
    Oregon Coast
    Update:
    Shop said it is originating from the water pump.
    quote is as follows:
    pump $171, coolant $71, labor $304 (3.5 hrs)
    Total is just shy of $550.
    I said let's do it! From my records from previous owner the coolant has never been changed anyhow so all will get done with this repair.
    They did an inspection on the rest and said all looks good but advised to do diff fluids and ATF fluid...
    Cg13055 and Dr Doobie like this.
  19. May 19, 2021 at 6:35 PM
    Cg13055
    South Florida
    DO NOT FLUSH YOUR TRANS, sorry for screaming just don't want you to fall for something that many others had bad issues with, just my opinion based on my research. just drain the fluid and replace a trans flush has given many members transmission issues it's just not a good idea on these trucks unless you want some specifically annoying issues. But repairs are always good treat your truck well and it will treat you well. I did my trans stuff in my driveway if you're into that, the fluid is expensive as it's specific to toyotas but you can to it with a $13 autozone pump and some patience:yes:
  20. Jun 7, 2021 at 4:42 AM
    Billy Bob Tundra
    Billy Bob Tundra New Member
    Did the shop do a pressure test on the coolant system. My guess it's might be a small, very small leak in the plastic part of the radiator.
  21. Jun 11, 2021 at 9:25 AM
    aelarson
    aelarson New Member
    AZ
    2011 SR5 Tundra (Silver Sky Metallic)
    Coolant leak. My 4.7L 4Runner looked just like that about 2 months ago. Plastic radiator...
  22. Jul 31, 2021 at 8:40 AM
    Belated welcome from NY.
