New Tundra owner need help with lift
Discussion in 'Suspension' started by KaneDog, Jun 21, 2020.
  1. Jun 21, 2020 at 3:21 PM
    KaneDog
    KaneDog [OP] New Member
    2012 Black SR5 TRD FFV
    Hi guys, new Tundra owner here! I just purchased a 2012 Black Tundra CM SR5 TRD FFV 4x4 and I am super stoked on it! I have read through a bunch of the posts on here and I'm a little confused as what to do when it comes to lifting it. I'm not going to be doing a lot of off roading but will occasionally go for a stroll and cut loose and I currently have nothing to tow. I'm almost dead set on the toytec/eibach 3" lift kit, with the coachbuilder 1" shackles and bumpstop kit, and jba uca. I would like have the truck sitting level after it's all said and done, but the question I'm stuck on is the use of the rear shackles if I just want a level ride. After doing some measurements I have found that the front is almost dead on at 36.5" with the LF sitting just a tad lower. The rear is what is really puzzling to me. The LR is at 38 7/8" (gas tank is half full) and the RR is at 40 1/4" from the ground, does the gas tank really cause that big of difference in ride heights from one side to the other. So my question is will I need shims on the front, (I have seen that the factory springs come at different heights to counteract the lean) and will the use of the 1" shackles cause me to keep the rake it currently has? Once I have the lift on and the truck is sitting level my plan is go with the same size rim and put 35s on it. Thanks in advance for any input or advice and sorry for the formatting first time user here.
  2. Jun 21, 2020 at 5:37 PM
    Johnders2586
    Johnders2586 New Member
    2017 Tundra SR5 W/TRD pkg
    Toytec Performance Aluma 3" Lift- Toytec rear shackle, Fuel Vector Wheels, Toyo Open Country C/T 295/70/18 Tires
    Well I think your on the right track with what you have in mind. Toytec/eibach makes good products for the price point. If you don't go with an adjustable coilovers I would plan to have atleast a shim for the drivers side front. Rear shackle is a good option. Personally I felt 1" out back with 3" front was to nose high. But lots of guys run it that way. I prefer a little rake so I went 2" in back. It's odd your rear was sitting off, however I have noticed at times my rear is sitting unlevel. I feel like it's just how it settles sometimes when parked becuase other times it's fine..
    KaneDog[OP] likes this.
  3. Jun 21, 2020 at 5:38 PM
    Welcome from NY.
  4. Jun 21, 2020 at 5:59 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Welcome from Nevada
    KaneDog[OP] and Pinay like this.
  5. Jun 21, 2020 at 6:31 PM
    I have a 13 DC 4.6 and I am dead level. I have Toytec Aluma 2.5's with SPC UCA's up front and Toytec shackles set at 1.5 along with 1/2 inch axle shims for the rear. Every Tundra sits differently. I would do the coilovers up front along with the shackles in the rear and see how it sits after a day or two. Your 5.7 will be a little heavier in the front compared to mine. After that then you can add axle shims if you need to bring the rear up just a bit. If you do need shims, replace the ubolts as well. Not recommended to reuse them. The 7.5 inch ubolts from Toytec is what I used. Let me know if you need pics of the axle shims that I am referring to.
    MTRock and KaneDog[QUOTED][OP] like this.
  6. Jun 25, 2020 at 2:36 PM
    KaneDog
    Thank you for input and advice. I never knew about the axle shims, but will definitely keep in mind once I get the lift put on and see where I'm sitting. I actually changed my mind and went with the bilstein 6112/5100 option, paired with jba uca's and coachbuilder shackles and shims. Hopefully everything will be here by next week and I can get it installed. And if you wouldn't mind, I would like to see some pics of your axle shims. Thank you again for the response.
  7. Jun 25, 2020 at 2:36 PM
    RobertD
    Robert
    DFW, Texas
    Welcome from Texas
  8. Jun 25, 2020 at 2:38 PM
    Dc2015
    Dc2015 New Member
    Danny
    2020 limited
    Welcome from NORCAL
  9. Jun 25, 2020 at 3:18 PM
    MTRock
    MTRock 1889
    Montana
    2024 Tacoma TRD Off Road
    I have the ToyTec boss with ToyTec shackles 3/1.5 fully adjustable so no driver side lean. The Shackles can also be set at 1inch. F3E64F50-CE04-4815-8C62-B3BF436CCA0F.jpg looks level but measures slightly higher in the rear. This pic has about extra 550 lbs on the rear!
  10. Jun 25, 2020 at 3:25 PM
    Every truck is different. Mine is a 4.6 so my front end would be a tad higher than a 5.7 would be. That's why I had to do the rear shims along with the 1.5 setting on the shackles.
    MTRock[QUOTED] likes this.
  11. Jul 21, 2020 at 6:53 PM
    KaneDog
    Hey guys! Just wanted to give an update on my progress. So, I got done with the install this past weekend now just need to get an alignment and will be good to go! As I mentioned I did go with the bilstein 6112/5100 on highest setting, 2 shims on driver 1 shim on passenger, jba ucas and coachbuilder +1 shackles. I am pretty much level, front is sitting about 1/2 inch higher than rear but hoping it will settle after awhile. Unfortunately dont have any good pics, havent moved it out of the driveway yet. Should I have done a diff drop or CB drop??
  12. Jul 21, 2020 at 6:59 PM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    Diff drop not necessary and welcome from SOCAL :thumbsup:
  13. Jul 21, 2020 at 7:01 PM
    KaneDog
    Also, did have one mishap.. as I was adding the bumpstop extensions, the back passenger side just all of a sudden snapped off on me while I was unscrewing it. Most likely due to the rust, live in Nebraska, but I did spray on pb blaster beforehand. Question is, is it a big deal missing one or do I need this fixed asap? Thanks for any suggestions
  14. Jul 21, 2020 at 7:04 PM
    KaneDog
    Awesome, thanks for the reply! And thanks for the welcome! :thumbsup:
  15. Jul 21, 2020 at 7:12 PM
    saybng
    Gary
    Ventura CA
    I would repair the bumsptops soon.
