New Tundra Owner - 35x12.5x18 tires rub with Rancho Quick Lift Shocks
Discussion in 'Wheels & Tires' started by jonaz_439, Dec 8, 2021.
  1. Dec 8, 2021 at 8:54 PM
    jonaz_439
    jonaz_439 [OP] New Member
    Jonathan
    2018 Tundra TRD Crewmax 4x4
    Hey Guys,
    Just got a used 2018 Tundra TRD 4x4. It looks like it has the Rancho Quick Lift shocks installed on the front but the 35.x12.5x18 tires rub when I turn to the right in reverse.
    Question, do you know if I can put a 2 inch spacer lift on the Rancho Quick Lift shocks?
    I live in Big Bear CA and we get tons of snow in the winter. I am worried about snow build-up on the tires during the winter tearing apart the plastic guards and bumper.
    Need more lift Scoootttty!
    Thanks in Advance. So far, I really love the Tundra. Havnt figured out if it has the 38 gallon tank yet. I was only able to fill up 23 gallons when I had a quarter of a tank left.
    Jonaz
  2. Dec 8, 2021 at 9:16 PM
    EagleClaw972
    EagleClaw972 New Member
    2008 Tundra Crewmax
    Straight Pipe, A/T on stock 20s, towing mirrors, kickers pro comp subs and amp
    you can use a 2” spacer since it will sit above the strut assembly.
  3. Dec 8, 2021 at 9:54 PM
    jonaz_439
    Jonathan
    I had 2.5" inch spacers on my 2007 Dodge Ram Hemi 4x4 and I ran that thing out to Death Valleys Race Track. For those of you who don't know, to get the Race Track ( basically a dry lake bed with rocks with trail lines behind them), you have to drive across a 30-mile washboard road. My Ram ate that road up and I was able to do 50mph. Hope to get the same performance out of my Tundra. I don't want to spend a ton of money on the lift because I need new tires.
  4. Dec 9, 2021 at 4:03 AM
    thedonn
    thedonn New Member
    is it rubbing front or rear? i am putting coachbuilder bumper shims on mine to push the bumper forward some. i think I want the minimum lift to clear my 295 70 18s but we will see how that turns out when my shocks arrive
  5. Dec 9, 2021 at 4:12 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    No. This is bad advice. You can’t just slap a 2” spacer on top of a shock that has already provided lift.
  6. Dec 9, 2021 at 4:25 AM
    thedonn
    thedonn New Member
    from most of what I have read the rubbing doesnt get helped much by extra lift above What you have ? spacers or wheel offset in the +18 to 26 range, plastic heating pushing, bumper spacer, alignment caster or maybe body mount chop
  7. Dec 25, 2021 at 10:15 PM
    rruff
    rruff New Member
    2016 Tundra SR DC Long
    I found this thread while searching "rancho"... just wanted to say that this is the right answer. :thumbsup:
    Also, does anyone know if the Rancho is longer than a stock strut? If not, you should be able to add a 1/2" spacer to the top if you want more lift, but I wouldn't do more than that if you'll be offroading.
  8. Dec 26, 2021 at 2:57 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Official welcome....Any pics?
  9. Dec 26, 2021 at 3:12 AM
    Wahayes
    Wahayes Older I get the wiser I realize my dad was
    Will
    2017 tundra limited
    325/60r20 falken at3w, 2.25 dobinsons ,20x9 +20 fuel torque wheels, leer xr100, bmc
    Just because you can doesn't mean you should comes to mind.....
    Seafury likes this.
  10. Dec 26, 2021 at 5:53 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    Welcome from So Cal
  11. Dec 26, 2021 at 6:07 AM
    Welcome from NY.
  12. Dec 26, 2021 at 7:53 AM
    georgiey22
    georgiey22 Moving to Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    Welcome from Redlands.
  13. Dec 27, 2021 at 2:43 PM
    Seafury
    Seafury Kickin names, and takin ass!
    Agent K
    SC Low Country
    2014 White 1794 "SnowWhite aka the Frost Queen"
    Bilstein 6112/5160, 3 CB front shims, SPC UCA's, CB +3 rear Shackles, total 3/2 lift, Dif drop, CB Carrier bearing drop, Fortin Evo One remote start from Tech12volts PnP, AMP research Powersteps PnP, Vent shades, Tinted windows, Black/Red lined cupholder inserts, Proclip USA dash phone mount with Scosche Magic Mount wireless magnetic phone charger, Stock wheels/tires for now.
    It's bad to add spacers to a lift kit.
    Spacers are bad in general for good suspension performance.
    Spacers on your lift kit will probably cause alignment problems.
    Do you have adjustable or aftermarket UCA's?
    If not, you will need them for sure with spacers on top of a lift kit.
    Any lift 3in or higher you really should have new UCA designed for the lift, or adjustable ones like my SPC UCA's.
    If you had a Qtr tank, and put in 23 gallons, you have the bigger fuel tank, lucky you!
    When I am at E on the gauge, it's about 20 gallons to fill up.
    I have the 26-gallon tank, with 6-gallon reserve.
    It sucks lol.
    alb1k likes this.
  14. Dec 27, 2021 at 4:27 PM
    rruff
    rruff New Member
    Not with the Ranchos... they are shorter than most aftermarket struts; probably stock length.
    Should be able to put a 1/2-3/4" spacer on top (1-1.5" lift), no worries. I'd add bigger bumpstops as well though.
    Seafury[QUOTED] likes this.
  15. Dec 27, 2021 at 5:21 PM
    Seafury
    Agent K
    SC Low Country
    You may be right, I am not familiar enough with that part to know, but that sounds good.
  16. Dec 27, 2021 at 5:30 PM
    rruff
    rruff New Member
    I just looked up a bunch of info today on strut dimensions... :D Thinking about getting the 9000s.
  17. Dec 27, 2021 at 5:38 PM
    Seafury
    Agent K
    SC Low Country
    Righton.
    I put some ranchos on my 3rd gen 4Runner years ago.
    They were low end from Advance Auto I think.
    They were ok, nothing special.
    I have enjoyed my Bilstein's.
