New Tundra making a funny noise.
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Rangers, Dec 30, 2016.
  1. Dec 30, 2016 at 2:37 PM
    Rangers
    Rangers [OP] New Member
    Joe
    Oklahoma
    2017 Bad Barcelona TRD Pro
    TRD sway bar
    My Tundra is making a weird sound.
    I start the truck and about 10 to 15 seconds after driving forward, (leaving neighborhood) it makes a weird grind sound from front end. It's real similar to the sound it makes engaging to 4wd just not as loud.
    Any ideas?
  2. Dec 30, 2016 at 2:39 PM
    ABS self check
  3. Dec 30, 2016 at 2:41 PM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    What Sean said. Totally normal.
    Rangers[QUOTED][OP] likes this.
  4. Dec 30, 2016 at 2:42 PM
    Rangers
    Joe
    Oklahoma
    TRD sway bar
    It does it once after the trucks started and doesn't seem to do it again until truck is turned off and then re started.
  5. Dec 30, 2016 at 2:43 PM
    Yep
    Rangers[OP] likes this.
  6. Dec 30, 2016 at 2:44 PM
    Rangers
    Joe
    Oklahoma
    TRD sway bar
    Thank you guys I'm way down in south Texas and was getting concerned.
    Is this something new on the 17's?
    My buddy's 16 doesn't do this.
  7. Dec 30, 2016 at 2:47 PM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    From what Ive heard and read, some are louder than others. Mine is very audible but Ive just gotten used to it. Nothing is wrong with your truck though. It's just the ABS pressurizing itself.
  8. Dec 30, 2016 at 2:48 PM
  9. Dec 30, 2016 at 2:51 PM
    Rangers
    Joe
    Oklahoma
    TRD sway bar
    Thanks for the link I was freaking out lol
    T-Rex266 likes this.
  10. Dec 30, 2016 at 2:52 PM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    It's no coincidence that they program the ABS to do the self check and the doors to lock themselves at the same time. Most people will never hear it because most people will never get into their settings and turn off the auto door lock function.
  11. Dec 30, 2016 at 2:57 PM
    Rangers
    Joe
    Oklahoma
    TRD sway bar
    Good to know and makes sense. I have been in quite a few new tundras and test drove 3 or 4 and never heard this.
    I sure feel better, Thanks.
  12. Dec 31, 2016 at 6:56 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
    yup, normal. it happens at about 15mph. my Tundra does it and my old Tacoma did it too.
  13. Jan 3, 2017 at 10:53 PM
    UsmcPro86
    UsmcPro86 New Member
    Hey rangers you have a TRD pro right?? U say your truck is making like a popping sound here and there? How many miles do you have on it? Well i have a trd pro my self 2016 mine did it a few weeks after i bought it. Its the aluminum skid plate i un bolted it placed some naylon and rubber washers and it went away. Which if you take the skid plate off it wont make any noises after i put some rubber and naylon washers it stopped making the popping noise from under.
    Rangers[OP] and Tundracollector like this.
  14. Jan 3, 2017 at 10:54 PM
    UsmcPro86
    I added the naylon and rubber washers on each bolt.
  15. Jan 4, 2017 at 4:17 PM
    Rangers
    Joe
    Oklahoma
    TRD sway bar
    Yes I have a Pro,I got 2500 miles on it now, its making the anti lock brake noise at 15 mph. I haven't noticed any noise from the skip plate. But if I do ill add the nylon washers, thanks for the tip.
  16. Jan 4, 2017 at 4:31 PM
    bsavoir
    bsavoir New Member
    Killeen, TX
    2016 Tundra Limited CM 4x4
    Gibson Metal Mulisha Exhaust, Replaced bulbs w/ LED's, AFe intake, Bullydog Tuner, Aftermarket Audio system, Rhino Bed Light sports bar, Tonneau Cover, Spyder Auto Headlights and Taillights, Recon 3rd Brake Light, Kensun HID's, Fender Flares, Custom Leather Interior, Heated Seats, 5% Tint on the Rear Windows, Pod light Foglights, 31" light bar behind the grille, linex spray bedliner, linex sprayed grille, ditch lights w/ dual 3in LED pods, 60" Tailgate LED strip.
    My '14 does this too, always noticed this when I first got it but now I don't even mind it.
  17. Jan 4, 2017 at 4:35 PM
    Rangers
    Joe
    Oklahoma
    TRD sway bar
    I don't mind it now, but before I posted here and was told what it was, I was freaking out. I was almost 700 miles from home and thought my 4x4 system was making weird sounds.
  18. Jan 4, 2017 at 8:50 PM
    How far south? Donde parte? (What part?)
  19. Jan 5, 2017 at 9:42 AM
    Rangers
    Joe
    Oklahoma
    TRD sway bar
    Zapata
