New Tundra - Few Questions
Discussion in '2.5 Gen Tundras (2014-2021)' started by travistheone, May 3, 2021.
  1. May 3, 2021 at 12:05 PM
    travistheone
    travistheone [OP] New Member
    Hi Everyone,
    after years of 4runners and tacomas I have finally grown up!
    I just picked up a 2021 Tundra.
    Looking to do suspension and tires sooner rather than later.
    Thinking 2" frt 1.5 rear. Icon AAL plus icon shocks.
    Questions are;
    1. will there be maint required with the icons? I have only ever had OME and Bilsteins. I am looking for on road comfort plus ground clearance.
    2. with a 2" lift do these trucks need UCA, diff drops or anything else to avoid any accelerated wear? avoiding prob is very important to me.
    3. thinking 275/65/20 tires. 95% road driving, but daily short stints offroad (construction) sometimes in deep mud, snow or ice. Of course, gravel and dirt. Any suggestions?
    thanks for the advice!
    Metro14536 and ZiaTundra like this.
  2. May 3, 2021 at 1:07 PM
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2024 GMC 2500 AT4
    In progress…
    Welcome!
    1. I believe Icons are rebuildable but I don’t know the interval.
    2. You should be good at 2 inches in front. 3 inches seems to be the tipping point.
    3. Lots of choices for tires. So far I’m very happy with the Trail Grapplers on mine.
    Good luck in your endeavors. We love to see pics of your build progress.
  3. May 3, 2021 at 1:49 PM
    Nowhereman
    Nowhereman New Member
    Al
    Monterey Bay area
    2021 Tundra SR5 / TRD / Cement
    Rough Country shocks, ReTrax cover, Summo springs, black out badging, bed extender, "some other things I can't mention"
    Just did a two inch lift on front and all that was required was an alignment.
    Tires are really complicated as most want beefy knob jobs but when they see that they ride rough, make lots of noise with most of off road designs being horrible on ice and packed snow, they wish they would of gotten something less nasty looking.
    There are lots of "All Terrains" that give the 90% of truckers that stay on asphalt most of the time good road manners in most environments.
    Again your idea of quiet might be different than some others.
    For me, if a tire can give me good rain manners, dry manners, snow / dirt manners as well as Ice, I'm happy.
  4. May 3, 2021 at 2:17 PM
    travistheone
    thanks for the reply.
    1. i dont want to rebuild anything. I would like them to last 75k miles without needing replacement or rebuilding.
    2. cool. good for alignment. i worry about CVs, difs, etc... still
    3. i have used them all and over analyze the options. paralysis by analysis.
  5. May 3, 2021 at 2:19 PM
    travistheone
    yep.... I have DD swampers, BFG AT, Cooper discovery, cooper ST Pro, Duratrac, wrangler, and i dont even know how many others. too many friggin choices! my recent KO2 shook my little tacoma like a rag doll!
  6. May 3, 2021 at 3:00 PM
    Sitting Sideways
    Sitting Sideways Probably stuck somewhere
    Beaverton, Oregon
    2021 White CM Tundra TRD Off Road
    Icon IR Coilovers, Icon Delta Joint tubular upper control arms, Icon PB CDC rear shocks, Icon Expansion Pack, Icon Hydraulic Bump Stops, Durobumps front bump stops, TRD dual exhaust black tips, TRD pro skid plate, TRD cold air intake system, TRD pro shift knob, TRD Pro Wheels, Falken Wildpeak AT3W tires, TRD radiator cap, ESP under seat storage, spray in bed liner, bed rail system, SDHQ abs guards, black tundra letter inserts, center console wireless charger, center console organizer/tray, charcoal filter removal, whistle screen removed, RCI Transmission/Transfer case skid plate, and ICON neoprene shock wraps
    1. The Icon service interval is 40,000 miles for on road driving only. The service interval decreases the more off road driving you do. Be sure to use some white lithium grease on the friction pads on the Icon AAL otherwise it will squeak over smaller bumps.
    2. No you will only need an alignment.
    3. 275/75r20s will probably clear without rubbing. I run 285/75r18 which measure 34.8” tall and you 275/65r18s will measure 34.3”. My tires just barely run on the swaybar at fill steering lock. You will have to remove the front mud flats definitely.
  7. May 3, 2021 at 4:36 PM
    travistheone
    Great info. I want to avoid a service interval, this leads me towards something like OME, Bilstein, Eibach. How about the Fox? I dont want my truck to have downtime.
  8. May 3, 2021 at 4:40 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  9. May 4, 2021 at 7:48 AM
    Sitting Sideways
    Beaverton, Oregon
    Fox has a service interval also but I don’t know it off the top of my head. I only knew the Icon service interval because I have their suspension. All shocks wear out eventually, most auto manufacturers recommend changing the shocks every 50,000 miles but most people blow right by that until the shocks blow out. I would recommend OME or Bilstein if you don’t want to worry about service, basically when the shock goes bad you just replace it. The shocks are “inexpensive” compared to an Icon, Fox, or King shock and perform very well. I had OME on my Tacoma and loved it, sometimes I wish I had gone that direction with my Tundra.
  10. May 4, 2021 at 7:51 AM
    Welcome from NY.
  11. May 4, 2021 at 3:29 PM
    travistheone
    I am with you. I have put a ton of miles on OME for 4runners and tacomas. I wish they had a shorter lift option, don't need 3" on this truck.
    frichco228 likes this.
  12. May 4, 2021 at 3:45 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Dobinsons and OME are good stuff, but do run higher lift wise than advertised. They last really well, have OME suspension on my 06 4runner- about 60k miles on it and it is still in great shape and drives and handles better than a new SUV.
    I also am not into the whole rebuildable shocks thing- cost about $100 per shock to rebuild and your truck will be down for weeks unless you can find someone local or do it yourself. Not to mention that you have to tear it all apart, reinstall and new alignment. rebuild every 40-50k if street only, every 20k if you offroad. No thanks. Id rather just install new stuff that will last for 80k miles and replace it when it is done.
    May want to look at the eibach pro truck suspension- about 2 inches lift and have read some good things about it. Toytec has some options as well, Aluma 2.5.
  13. May 4, 2021 at 3:53 PM
    travistheone
    I agree with you 100%. I like the bilstein option, never had eibachs before. i like shopping headstrongoffroad.com. most things are out of stock everywhere right now though.
  14. May 5, 2021 at 12:04 PM
    travistheone
    Narrowing it down to bilsteins (whenever they get back in stock). Plus SDHQ hidden winch mount and warn platinum.
    revolver bed cover.
    thats pretty much it! Falken wildpeaks are sounding pretty good right now too
  15. May 5, 2021 at 9:22 PM
    OnespeedTRD
    OnespeedTRD New Member
    Don
    San Diego
    2020 Tundra Limited TRD Off-Road
    275/70r18 Cooper AT3 XLT on SCS Ray 10s, Eibach Coilovers, DD 12" Exhaust, AJT Blackout Kit, Truxedo Pro X15, paint match/chrome delete.
    Look at the Eibach Coilover 2.0 setup as well.
  16. May 5, 2021 at 10:47 PM
    cain0725
    cain0725 New Member
    got my bilstein 6112 from shocksurplus in about 2-3 weeks. Just set email to notify u and be ready to buy!
    travistheone[OP] likes this.
  17. May 5, 2021 at 11:55 PM
    Dr Doobie
    Dr Doobie Growing member
    Talkeetna,Alaska
    '07 RCSB 5.7 SC'd 4x4 SSM
    Welcome from Alaska
