New Truck
Discussion in 'Wheels & Tires' started by Erocaho, May 14, 2019.
  1. May 14, 2019 at 8:11 PM
    Erocaho
    Erocaho [OP] New Member
    Eric
    I buying a new truck tomorrow and want to throw some 20x9 Fuel wheels and 35 Toyo AT2 tires on it. I don't want it change the ride to much and I don't want the tires sticking outside the wheel flare with no rubbing. Do I just need a leveling kit or suspension lift? Tell me what I need please?
  2. May 15, 2019 at 6:38 AM
    TwistedTad
    TwistedTad TRUCK GANG “T”
    Tad
    Canyon Lake, CA
    2019 Cement Limited CM 4x4
    Welcome from California. To do 35’s you will at least need to do a 3/1 lift. A leveling kit might be pushing it. There are plenty of options out there. Bilstien, Toytec, Fox, Icon...... Check out the suspension forum and the “will it fit” thread. In regards to the wheels not sticking out +25 offset or higher would be good. Hopefully this helps.
  3. May 15, 2019 at 6:55 AM
    Welcome from NY.
    Post up pictures when you get it.
  4. May 15, 2019 at 6:57 AM
    Welcome From Ohio
  5. May 15, 2019 at 7:06 AM
    Welcome from Texas
  6. May 15, 2019 at 7:09 AM
    seniramsu
    seniramsu Pro Runnin
    Nate
    VA
    2017 TRD Pro Tundra Wht
    Welcome from NC!! If only there was a sticky on tire sizes.....:cheers:
    Black Wolf and TXMiamiFan like this.
  7. May 15, 2019 at 7:14 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Welcome from TX!
    More "Fuel" will be required with the 35's..... :D
  8. May 15, 2019 at 7:20 AM
    Welcome from Colorado.
  9. May 15, 2019 at 7:56 AM
    Midnite72
    Midnite72 Anything DIRT !!
    Bill
    Northern MD
    18 SR 5.7 4x4
    2” level P&P sliders
    Welcome from northern Maryland :hattip:
    Plenty of help spending your money around here- 3/1 lift + 25 offset as already mentioned
    Good luck
  10. May 15, 2019 at 7:58 AM
    00Tyler10
    00Tyler10 WETT Expeditions
    Tyler
    Bowling Green, Ky
    2020 MGM Tundra Plat 4x4
    PTM Mirror Caps Spray in Bed Liner Window Tint XD Buck 20x9 Wheels 275/65/20 BFG K02s Bamf 10" exhaust
    Welcome from Kentucky
  11. May 15, 2019 at 8:10 AM
    Midway
    Midway New Member
    To clear the 35s, you'll probably need a BMC (Body Mount chop), with some slight trimming of the fender liner; you'll definitely get some rubbing if you don't.
    If you go with a leveling kit, I'd only go up to a 295 tire.
  12. May 15, 2019 at 10:13 AM
    Fishman57
    Fishman57 New Member
    Wayne
    Bucks County, PA
    Welcome from SE PA!
