New trd pro owner needs advice!?!
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by 2DBoyz, Sep 14, 2018.
  1. Sep 14, 2018 at 8:07 PM
    2DBoyz
    2DBoyz [OP] New Member
    Hey guys
    1st time buying a truck so I apologies in advance for my lack of knowledge.
    Just bought a 2019 Tundra Trd Pro that came with fender flares (installed at gulf states Toyota) and had only 2 miles at the dealership. My plan was to add fender flares when I buy a TRDP so lucky for me I found one already installed. On the sticker tag it listed the costs for $695 so not a bad deal, I think..
    Next, I want to add thicker tires but only if they can fit my stock 18' trd pro wheels. I also want to have a bit wider stance so wheels are leveled out with the fender flares rather than how it currently looks now being sucked in..
    I want to avoid any modifications if possible because of my Toyota factory warranty like cutting/trimming, lifting, etc. I also do not want to modify the fox suspension as well. I'm a guy that loves vehicles that are all original and stock and would like to do the same..
    Lastly one other but important note, I absolutely must be able to fit my trdp inside my standard 2 car garage (7ft). Where I live, I do not trust it being parked outside..
    So, with all that being said and based on my newbie research, it looks like I may be able to achieve this with a 1 or 2 inch leveling kit and some spacers??
    I need your help on how I can achieve this thicker tires, wider stance look without lifting up too much that it cannot fit in my 83inch garage and not voiding my factory warranty..LOL
    Any advice would be greatly appreciated!
    740DEC53-F2FC-4C71-A8EA-8133A794142Fremote16400c0f6bcfb99066bc73222b59354b4abd5176-1-original.jpg
  2. Sep 14, 2018 at 8:39 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I wouldn't do anything to the suspension. Those fox set ups are really nice and a spacer will kill your ride quality and downtravel.
    I'd just get wider tires, I think you can fit 285s that are 33" tall without any mods to your stock trd pro. But check it the thread dedicated to that very common question.
    You can maybe even fit a 295 wide and taller if you remove mudflaps, trim a little plastic and do a slight body mount chop. Those things will not void your warranty btw.
    Tierhog, Black Wolf and Sunnier like this.
  3. Sep 14, 2018 at 8:39 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    welcome!
    Great looking truck!!!!!!!
  4. Sep 14, 2018 at 8:52 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Welcome from Washington.
    Your pro should already be about 2" taller than the other models. You should be able to fit 275/70 easily and 295/70 with a little trimming.
    To push your wheels out so it is closer to the fender Flair's and keep stock wheels you will need spacers. Otherwise you will need to get new wheels with a smaller offset.
    How much room do you have now putting it in the garage? Should be able to go up in tire size and only increase 1-2 inches in height depending on tire size increase.
    Good luck!
    Inquiringone, Black Wolf and Pudge like this.
  5. Sep 14, 2018 at 8:58 PM
    Wise advice Pudge! Thicker tires threw me off tho.
    jewsNbrews and Pudge[QUOTED] like this.
  6. Sep 14, 2018 at 9:00 PM
    Damnit...we have great folks here...best Tunny forum....
  7. Sep 14, 2018 at 9:01 PM
    jordanpop1
    jordanpop1 New Member
    Call coachbuilder and talk to David if you want some more height.
    Just got off the phone with him today, and he knows what he’s talking about. Can help you with tires etc.
    I’m having a set sent to my dealership and they are going to install them on my pro. It will be warrantied through Toyota.
    Extra inch in front and 1.75” in the rear.
  8. Sep 14, 2018 at 9:03 PM
    Pudge
    CT
    Definitely a lot going on in the OP.
    Now I see he wants wheels moved out too. But stock wheels. So I guess spacers are only option?
    I'm also wondering now what he means my thicker tires? Wider? Taller? More sidewall?
  9. Sep 14, 2018 at 9:05 PM
    Ace402
    Ace402 New Member
    2011 Tundra 4x4 SR5
    ADS 2.5 RR front and rear. MCM UCA & Shackles
    295/70-18 all the way
  10. Sep 14, 2018 at 9:06 PM
    Ace402
    Ace402 New Member
    2011 Tundra 4x4 SR5
  11. Sep 14, 2018 at 9:09 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    WELCOME!
  12. Sep 14, 2018 at 9:24 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Welcome Lou.
    Black Wolf likes this.
  13. Sep 14, 2018 at 9:42 PM
    Borgs
    Borgs New Member
    PA
    No. Thicker.
  14. Sep 14, 2018 at 9:53 PM
  15. Sep 14, 2018 at 10:30 PM
    War_Wagon312
    War_Wagon312 Puddle Dodger
    Rich
    2016 Pro MGM CM
    Toyo MT 285/70/R18, led's all around, Baja Design squadron sport fogs, spider trax 1.5 spacers, led foot well lighting, interior chrome delete, kc hilites 40inch light bar grill mounted, 20%tint all around, color lugs black lugnut caps, 2019 pro head lights, led lights all around, spyder co tail lights, DMX1057xr, super crew box with kicker 10” sub,jbl door speakers, factory amp bypass trd air flow accelerator with drop in filter, x3 battery, Toyota bed cover, swing case,
    285/70/r18 on stock pro rims no trimming no rub to widen the stance you would need a different rim with a different off set or spacers. This could lead to needing to trim or remove some things though.
  16. Sep 14, 2018 at 10:54 PM
    RoninPro
    RoninPro Abecedarian BASTRD
    East Bay
    17 CM TRD Pro
    I started like you, wanting to keep my TRDP stock. Was convinced by others to get a BMC, shims/shackles from Coachbuilder (as mentioned by someone before) & Spidertrax spacers. With slight trimming will get you into 12.5” wide tires. Running 35” on stock TRDP wheels with very little sticking out.
  17. Sep 14, 2018 at 11:01 PM
    Borgs
    Borgs New Member
    PA
    Yep, that’s it.
    Voyagermike likes this.
  18. Sep 15, 2018 at 7:06 AM
    captain_bij
    captain_bij New Member
    Bijan
    15’ Tundra Crewmax Platinum 4x4
    Welcome! Sweet truck!
    Really don’t think doing a BMC would void any warranty. They have to be able to “prove” your modification is what caused the malfunction. Example: transmission starts acting up, they say it’s from the weight of larger tires, etc.
    But to add to someone else’s post on here, I wouldn’t ever recommend spacers. It’s the cheap way to get leveled, but you will sacrifice ride quality and suspension travel.
    Wheel spacers would be a good idea since stock wheels have a high offset. Then I believe you can get into a 33” tire.
  19. Sep 15, 2018 at 7:49 AM
    cjscinta
    cjscinta New Member
    Nashville TN
    Are you talking about shims or spacers or both? Confused.
  20. Sep 15, 2018 at 9:09 AM
    captain_bij
    Bijan
    Shins should be ok, but spacer on strut is a no go for me. Ruins the ride IMO
  21. Sep 16, 2018 at 6:51 AM
    backinblack
    backinblack New Member
    James
    I just put 285/70 on my 2019 Pro, with flares. No modifications needed (even kept the small front flaps). Not sure if this is the look your wanting:
  22. Sep 16, 2018 at 7:23 AM
    owb2gp
    owb2gp New Member
    ID
    Good looking truck!
    backinblack[QUOTED] likes this.
  23. Sep 16, 2018 at 7:25 AM
    jordanpop1
    Man you have me drooling over my truck, can’t wait to get my order in. That black is sexy AF! Good job man looks great with the tires, and i did verify with my dealer I can get the fender flares with the black rivets.
  24. Sep 16, 2018 at 10:54 AM
    Tierhog
    Tierhog SIG-AHOLIC
    2016 Tundra Crewmax Limited 4WD
    Mostly stock/TRD accessories/Morimoto XBs
    The OPs scenario is flawed. You can't maintain a purist position, fulfilling the engineers intent while striving for aesthetics.
    If you want a lift and large tires, go for it. If Toyota covers ball joints, CVs boots and shafts, drivelines and Ujoints, etc.. More power to you.
    You have almost a foot of clearance... 2 inches are for what exactly? Tires? What will bigger tires do?
    Raise clearance.
    "Improve look"
    Or...
    Change ride quality (subjective)
    Throw suspension and transmission out of spec and increase wear (factual and objective)
    Decrease already low but accepted fuel mileage
    Your truck is a barge from an offroad standpoint. I gave up Jeeps to join the Tundra world. You need light, high clearance, low geared 4.88\5.13 and 4 to 1 to crawl effectively and manage the Tellicos and Moab/Rubicon world. Tundra is designed for towing and longevity.
    So why not keep your mindset and not muck with it? Not criticism, those who modify their Tundra in this manner, expect to spend money upgrading and repairing... So I guess you need to "pick a side" lol... Or maybe make a calculated compromise.
    Good luck.
    Hammy68 and Rica25 like this.
  25. Sep 20, 2018 at 2:43 AM
    NJ Cement TRD Pro
    NJ Cement TRD Pro My Tundra has a Raptor bodykit.
    Ben
    Bergen County, NJ
    2019 Ford Raptor
    Those flares look really good...do the wheels looked pushed in?
    Rica25 likes this.
  26. Sep 20, 2018 at 3:54 AM
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    285/70s BF Goodrich 2KOs would be my vote for tires, Nice Truck !!
    Rica25 likes this.
  27. Sep 20, 2018 at 4:15 AM
    Welcome from NY.
  28. Sep 24, 2018 at 8:09 AM
    Wrongside
    Wrongside New Member
    AB
    2016 Tundra
    I have nothing useful to add here... Just wanted to say, there are some dead sexy trucks in this thread! ;)
    Rica25 and Watt maker like this.
  29. Aug 3, 2019 at 4:34 AM
    ncomeau35
    ncomeau35 New Member
    North of Boston
    2019 White Toyota Tundra TRD PRO
    Nitro Ridge Grappler 285/75/18
    i just went with nitto ridge grappler 285/75/18's had to remove front mud flap, but they really fill out the wheel well
    Laz27, Tierhog and (deleted member) like this.
  30. Aug 3, 2019 at 11:11 AM
    Trunk Monkey
    Trunk Monkey Truck's
    Steph
    2019 Tundra TRD PRO - VooDoo Blue
    Retrax One MX, NFab Predator Pro steps, Husky X-Contour mats
    Fun fact, those little mud flaps are called "Spat" they help with aerodynamics deflecting wind around the tires to help with fuel economy.
