New transmission extension housing still leaking
Discussion in 'General Tundra Discussion' started by Godaddy2, Jul 27, 2021.
  1. Jul 27, 2021 at 5:00 AM
    Godaddy2
    Godaddy2 [OP] New Member
    2014 Tundra 2 wheel drive
    I have recently had a complete new transmission extension housing fitted to my 2015 Tundra with 65,000 miles on it but there is still a leak coming from where the shaft enters the housing. Does anyone know what causes this. The new housing was fitted by my garage? Thanks any help is appreciated.
  2. Jul 27, 2021 at 5:26 AM
    TechWrench
    TechWrench New Member
    Gary
    Hawley, PA
    '08 Tundra White, DC SR5 5.7, TRD Off Road Pkg
    Toyota Bedliner, Under Cover Bed cover, Oem back-up camera system.
    If you can see the leak coming from where the driveshaft yoke fits into the extension housing, the likely culprit is a damaged rear housing seal. (I am assuming you have a 2wd Tundra)
