New to tundra towing
Discussion in 'Towing & Hauling' started by newt, Mar 5, 2019.
  1. Mar 5, 2019 at 5:42 PM
    newt
    newt [OP] New Member
    2016 Tundra Dbl 5.7 4x4
    Gibson exhaust
    First time towing with tundra
    2016 double 5.7 sr5 4x4
    16’ v nose 2260lb dry weight with only 1500lb cargo
    Traveling to from Florida and Connecticut I-95 I-75 I-85 I-81 I-84
    Down shifting excessively to third gear I think on grades I would only need to have been as low as fourth. Rpms sometimes approaching 4K and have to back off throttle until road speed drops back to 15mph slower than traffic before up shifting again
    Cruise control impossible to use in the hills and tow haul only seems to make rpms stretch out longer
    Just looking for some feedback here as more trips are planned
    Prostar 190 likes this.
  2. Mar 6, 2019 at 5:41 AM
    Adriver71x
    Adriver71x New Member
    Gerald
    2015 Tundra SR5
    Tow Mirrors
    I just made the trip from Connecticut to South Carolina 3 weeks ago towing a 7500 lb. camper. Didn't use tow haul. No struggles and plenty of power. Didn't have to shift once. I have to go back and get my car trailer 10000 gvw but probably only 8500 lbs. Make sure you have a working brake controller and air bags or helper springs
  3. Mar 6, 2019 at 6:12 AM
    Walleye
    Walleye New Member
    3600 rpm is peak torque I believe, so 4k rpm shift point seems legitimate. Is the torque converter locking up in 5th & 6th and what temp is the tyranny running at? The load weight described should be well within the capacity of the truck. Have you tried driving it in sport / manual mode 6th gear setting to see if it holds higher gear longer?
  4. Mar 6, 2019 at 6:15 AM
    Welcome from Ohio.
  5. Mar 6, 2019 at 6:18 AM
    JH5370
    JH5370 Member
    Josh
    Eastern WA
    2017 White DC TRD PRO
    I agree with no tow haul in the freeway. That seems odd for it to be shifting down that much. Like Walleye says. The manual shift mode may be what you need.
  6. Mar 6, 2019 at 6:29 AM
    OBXTundra
    OBXTundra Member
    Southeast USA
    2018 Nissan Armada, 4x4
    My toyhauler was 9k and my new camper is somewhere around 7k. We pull 2000-4000 miles a year. NC to PA, NC to SC, Eastern NC to Western NC. Lots of different grades, speeds, interstates.
    -I always run in tow/haul, always.
    -I always run in manual shift mode, usually 5, but sometimes 4 if consistent grades.
    -I always run 89 octane or higher.
    -I never use cruise. Toyota says not to when towing and I've never had good results when I tried, constant shifting.
    -I never run over 70 mph.
    I never notice erratic shifting and I feel the Tundra does a great job of managing the weight. My TC will lock up in 5th gear given the right conditions, if I notice that it's not locking I will bump down to 4th gear. Grade and wind have a large effect on your shifting.
  7. Mar 6, 2019 at 2:47 PM
    newt
    Gibson exhaust
    Hey thanks I’ll try using sport mode next time I just wasn’t sure if there was something wrong with our tundra
    I’ve been working on nothing but diesels for the last thirty seven years and didn’t expect the Difference to be that noticeable I was trying to keep rpms too low in a pull
    On a side note I forgot to mention that this truck came with a Gibson dual exhaust on it and I was thinking it may have adverse effected performance as still factory tune and was looking for another opinion on the Gibson system
    Walleye and OBXTundra like this.
  8. Mar 6, 2019 at 2:54 PM
    Alloutdrs1
    Alloutdrs1 New Member
    Andrew
    Virginia Beach, VA
    That's a pretty light load compared to what some of us tow on here, I've pulled 7500lbs up I95 and I81 before and had no issue. You might have lost some low end torque with that Gibson exhaust.
    OBXTundra likes this.
  9. Mar 6, 2019 at 2:54 PM
    newt
    Gibson exhaust
    I do a lot of work on heavy highway and I don’t think drivers could live without cruise control even in a long pull as long as you don’t have to drop more than one gear
  10. Mar 6, 2019 at 2:58 PM
    newt
    Gibson exhaust
    I’m open to some suggestions for exhaust examples to gain the performance loss back as long as we don’t get louder we’ve already been discussing the noise level on this last trip
  11. Mar 6, 2019 at 3:17 PM
    OBXTundra
    OBXTundra Member
    Southeast USA
    I had a dual flowmaster setup on my truck from the PO. Irritating to pull with that. I went back to stock, primarily for quieter towing, and ended up with a bunch more low end power as well.
  12. Mar 6, 2019 at 6:04 PM
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    @dirtydeeds seems to be the forums preferred choice for good sound and power.
  13. Mar 7, 2019 at 4:00 AM
    Walleye
    Walleye New Member
    The difference is very noticeable when pulling with a tundra compared to any diesel. The engine needs to be revving up above 3600 RPM to make peak torque, and even then its only around 400 ft-lb. Everything in the drivetrain is turning much faster. It's crazy. If your TC converter isn't locking up it will limit life on your clutch packs. Dual exhaust will almost always reduce low end power and it will not hold a gear as long when towing. An X or H pipe will help this some, but not a true dual then. Try towing with your stock exhaust. Makes you wonder why the heck automotive media choose a trd pro for tow testing.
  14. Mar 7, 2019 at 5:37 AM
    newt
    Gibson exhaust
    The Gibson dual was already installed when we acquired the truck and at this stage of life loud pipes doesn’t give me the chubby it used to anymore
    I’ll probably redo the system before the next trip
  15. Mar 9, 2019 at 5:18 PM
    CARLHEIZER
    CARLHEIZER New Member
    San Diego
    2019 TUNDRA 1794 EDITION
    LINE-X, BAK MX4 WITH BAK BOX, UPGRAGED SOUND SYSTEM BY OEM AUDIO + AND CERAMIC WINDOW TINT - ALL SIX WINDOWS.
    I have a 2019 1794 with stock exhaust. I also pull 8,000 pounds up a 6% grade. Was thinking of TRD Pro Duals but have read too many complaints about loss of torque, downshifting, etc. Was also looking at the Magnaflow 15306 two pipe in, two pipe out both on right side. Reportedly, there is a crossover in the muffler. Does anyone have this set up and how the noise compare with the TRD Pro duals?
  16. Mar 10, 2019 at 5:43 PM
    JH5370
    JH5370 Member
    Josh
    Eastern WA
    I tow around 6000 lbs on varied terrain, up and down hills and have had no issues with my TRD Pro duals.
  17. Mar 11, 2019 at 4:28 AM
    blaserdude
    blaserdude New Member
    Eugene
    2019 Tundra Limited Double Cab
    none
    Carlheizer,
    Have you monitored the transmission temp on your 2019? I have one and am interested in how the redesigned integrated transmission oil cooling is doing on towing. Mine seems to run hotter than my 2008. (ScanGuage data).
    Thanks,
    bc
  18. Mar 11, 2019 at 4:50 AM
    Welcome from NY.
    What do you haul?
  19. Mar 11, 2019 at 5:45 AM
    blaserdude
    Eugene
    none
    Jim,
    Nothing heavy. A fishing boat (about 2K) and my UTV/trailer (1400#). In my area (East TN, WNC) there are long steep grades on the interstates crossing mountains. My 08 had the big oil cooler. In 2019 they removed auxiliary cooling and replaced with "integrated engine/transmission cooling" with no fitting for oil takeoff for an auxiliary cooler. My old one never got much over 205F. New one will hit 225F and it is not summer yet.
    Thanks,
    bc
  20. Mar 11, 2019 at 8:09 AM
    CARLHEIZER
    San Diego
    I actually have not towed yet. Just bought it. I will monitor tho when we go.
  21. Mar 11, 2019 at 12:55 PM
    CARLHEIZER
    San Diego
    Blaserdude, how to you monitor transmission temps anyway? OBD reader?
  22. Mar 11, 2019 at 1:11 PM
    blaserdude
    Eugene
    none
    I have a ScanGuage II that I used on my 08. Reprogrammed the codes for 2010+ models (have codes, available on their website). That said, it was reading the torque converter output, not the pan. The torque conv. oil heats rapidly when the converter clutch unlocks then cools rapidly when locked. Now it reads the pan which changes slower than the converter. May not be apples to apples. The Ultraguage MX reads both as does the Torque Pro app for android.
  23. Mar 14, 2019 at 12:36 PM
    newt
    Gibson exhaust
    Gibson Performance tells me that the muffler I’m running has a internal louvered cross pipe for the duals
  24. Mar 14, 2019 at 12:50 PM
    Walleye
    Walleye New Member
    That should help with backpressure on the valves. Keep in mind, the 5.7 L gasoline engine still needs to be in that 3500 to 4000 rpm to develop its torque. This is a major difference from pulling weight with a turbocharged diesel. Fuel efficiency is also going to degrade more under load compared to a diesel.
  25. Mar 14, 2019 at 1:32 PM
    newt
    Gibson exhaust
    Ten4
  26. Mar 14, 2019 at 4:33 PM
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    Man 20* swing and not summer yet. I wonder why Toyota changed up the cooler design.
