New to tundra 285/70 questions..
Discussion in 'Wheels & Tires' started by Js18tundra, Nov 26, 2017.
  1. Nov 26, 2017 at 8:05 PM
    Js18tundra
    Js18tundra [OP] New Member
    18 Tundra sr5 TRD 4x4
    Diamondback se tonneau
    hey all, new to tundras, not new to Toyota’s! So I just purchased a 2018 cement trd 4x4, and I’m about to pull the trigger on a 2.5” leveling kit a set of 1” bora spacers, and 285/70 Nitto Ridge Grapplers. I plan on mounting on the stock wheels, I know I’ll probanly have to stretch the fender liner and take off the front flap. My question is has anyone needed a zero point calibration issue with a small lift and slightly bigger tires??? Thanks in advance!
    Eclipsed & Floating likes this.
  2. Nov 26, 2017 at 8:18 PM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    You won’t notice any difference with 285s
  3. Nov 26, 2017 at 8:19 PM
    Js18tundra
    Okay thank you, I just wanted to plan accordingly if it needed to get a calibration through my local dealer
  4. Nov 26, 2017 at 8:20 PM
    Eclipsed & Floating
    Voluptuous Whitey
    You’re only really going up 1 size
    I went up to 35s and it was only about 4mph difference. You’ll be fine :thumbsup:
  5. Nov 26, 2017 at 8:21 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    My old 2010 had issues but it's the only Tundra that I bought used and I'm not sure what was going on with that one. I seriously doubt you'll have any issues.
  6. Nov 26, 2017 at 8:26 PM
    Js18tundra
    I was thinking as far as abs issues, I’ve heard quite a few problems with gen 2 tundras, so I wasn’t sure if the gen 3’s were as finicky
  7. Dec 17, 2017 at 10:27 PM
    moorectundra18
    moorectundra18 New Member
    2018 Tundra SR5 XP
    New to the Forum and new to the Tundra. I just purchased the SR5 XP. Came with the Nitto Grapplers 275/55/20 Wanted to do a 2.5 procomp leveling kit but not wanting to do any kind of trimming. For the rear I was going to leave it alone because I don't do a lot of hauling, if I do it's very little. Have seen where a 285/60x20 will work without rubbing. Everything I saw about running a 33 said that it would rub if I didn't do trim work. Any input on offset, tire size would be helpful.
    Thanks!
