New to toyota tundra from NC tundra 4x4 help
Discussion in 'New Member Introductions' started by 4x4crewmax, Mar 23, 2022.
  1. Mar 23, 2022 at 7:34 AM
    4x4crewmax
    4x4crewmax [OP] New Member
    2007 5.7l 4x4 black crewmax
    3/2 readylift bronze fuel rims 35" bfg
    2007 toyota tundra 5.7l 4x4 hi or lo not working I found this forum looking help. I changed out transfer case shift motors. And front diff actuator and now. Vsc trac light stays on abs light brake light and 4lo. I had no check engine light on. Ran diagnostics found abs communication errors. I noticed that when the truck is in the accessory key on i hear the transfer case actuators constantly running. Not sure if this is normal or have I screwed up the gear timing. Truck still drives normally in 2wd no grinding or mechanical noises from in the transfer case. Took to toyota and they told me $6,600 for a new transfer case. I call bs I feel I may have timing issues please help.
    Thanks
  2. Mar 23, 2022 at 8:50 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! You will get a LOT better response if you post this question to the Ask The Toyota Mechanic thread, but from what I've read, Toyota's take on any 4x4 issue is to replace the transfer case. There are likely much more cost effective ways to deal with it.
    Ask The Toyota Mechanic thread:
    https://www.tundras.com/threads/ask-the-toyota-mechanic.2404/
  3. Mar 23, 2022 at 9:05 AM
    Blueknights75
    Ron
    Clayton, NC
    Welcome from NC!
  4. Mar 23, 2022 at 10:27 AM
    4x4crewmax
    Thanks I'm from goldsboro your not to far from me. Any trouble with your 4x4 working on your tundra?
  5. Mar 23, 2022 at 11:32 AM
    Welcome from NY.
