New to the page looking for advice on leveling kit
Discussion in 'Suspension' started by Smith23, Mar 29, 2020.
  1. Mar 29, 2020 at 10:17 PM
    Smith23
    Smith23 [OP] New Member
    2002 Black Toyota Tundra SR5
    3.4L V6
    I am looking for some suggestions on the best way to level my truck. Spacers seem like a cheap option but I’m not sure how reliable they will be. Any thoughts?
  2. Mar 30, 2020 at 5:17 AM
    Professional Hand Model
    Hand Protectors
    Three 80lb bags of Quikcrete loaded all the way towards the rear of your bed will be the least expensive way to achieve this. :D
    Seriously, there are many threads on this topic here. Try to do a search and then come back with a budget you are willing to spend. You are on a slippery slope in terms of balancing budget and doing it the wrong way. You’ll get tons of opinions here.
    Darkness, Smith23[OP] and revtune like this.
  3. Mar 30, 2020 at 6:41 AM
    Welcome from NY.
    Maybe Bilstein 5100's on the middle setting.
    Smith23[OP] likes this.
  4. Mar 30, 2020 at 8:03 AM
    Lovetrucks
    Lovetrucks Member
    2019 Ram Rebel
    Welcome from Ontario Canada
  5. Mar 30, 2020 at 8:58 AM
    Smith23
    3.4L V6
    I like the idea of Bilstein 5100 and I have done a bit of research on them. What would be the ballpark for installing those? Is it something that could be done at home with a good set of tools?
  6. Mar 30, 2020 at 10:43 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    If you're comfortable with doing basic things yourself like oil changes and rotating tires, a cost effective way to go is remove your stock strut assemblies and bring them with your 5100s to a shop to have the coils and that's swapped over. Then go home and put the new assemblies in.
    Otherwise you're probably in the ballpark of 2 hours labor, hopefully less if a competent shop.
  7. Mar 30, 2020 at 11:59 AM
    Smith23
    3.4L V6
    With a 2” lift in the front would I be able to fit 285/75 16 on without any rub?
