New to the group
Discussion in 'New Member Introductions' started by Tcarr901, Aug 3, 2020.
  1. Aug 3, 2020 at 2:06 PM
    Tcarr901
    Tcarr901 [OP] New Member
    Hi group!!
    I recently bought a 2015 platinum tundra and I am trying to figure out if I can add power folding mirrors. It does not have a switch on the dash and it has these huge tow mirrors on the side. Is it possible to take those off and add power folding to it?
    Prostar 190 and YardBird like this.
  2. Aug 3, 2020 at 2:11 PM
    Doctor Flex
    Doctor Flex Just browsing...
    Utah
    2020 White 1794 TRD
    TRD Pro skid, Line-X, Tonneau, drivers grab handle, wireless charger, RB 20's, TRD Pro wheels, Gator Liners.
    Is there a button on the spot where you adjust the mirrors inside the truck that looks like the top right button here?
    EDIT: If yes, then it is wired and you would need to swap back to the OE mirrors. If not, then wiring I think may be able to be done, but it isn't plug and play. There are threads on here showing the process.
    EDIT 2: I know you said there is no switch on the dash. Just wanted to make sure there isn't a button like this on the area you adjust the mirrors. Could easily be overlooked.
    Tcarr901[OP] likes this.
  3. Aug 3, 2020 at 2:16 PM
    RobertD
    Robert
    DFW, Texas
    You can add power folding mirrors but you will have to add a harness to enable the power fold feature. There are a couple different harnesses out there. If you are asking if you can add the motor to the mirror assembly to make your existing mirrors power fold enabled, that I do not know.
  4. Aug 3, 2020 at 2:17 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
    Welcome aboard from SoCal.
  5. Aug 3, 2020 at 2:21 PM
    Tcarr901
    It does not have the small button at the top right
  6. Aug 3, 2020 at 2:26 PM
    Doctor Flex
    Utah
    2020 White 1794 TRD
    Ok. You would have to wire it then. Search around here, there are some threads going through the process. As a side, I have them, and haven't used the feature. Not at this point at least. I guess I like knowing I have it though.
    Tcarr901[QUOTED][OP] likes this.
  7. Aug 3, 2020 at 2:27 PM
    Tcarr901
  8. Aug 3, 2020 at 2:28 PM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    Welcome from So Cal
  9. Aug 3, 2020 at 2:48 PM
    GaFFLe
    GaFFLe New Member
    Atlanta, GA
    2020 Toyota Tundra Platinum
    Undercover bed sway cases
    Hi Tundrans,
    New guy here. Just got my '20 Tundra Platinum a week ago. I debated between the Tundra, Sierra AT4, Tacoma, Gladiator, and F150 but decided on the Tundra for reliability and potential re$ale value.
    Here she goes:
  10. Aug 3, 2020 at 2:48 PM
    Welcome from NY.
  11. Aug 3, 2020 at 2:49 PM
    :threadjacked:
    You should start your own thread.
    GaFFLe[QUOTED] likes this.
  12. Aug 3, 2020 at 2:52 PM
    Welcome
    GaFFLe likes this.
  13. Aug 3, 2020 at 2:54 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Welcome from Nevada
    GaFFLe and Tcarr901[OP] like this.
  14. Aug 3, 2020 at 8:43 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  15. Aug 4, 2020 at 3:40 AM
    Welcome from Ohio
