New to Member
Discussion in 'New Member Introductions' started by Turbo_4runner, Feb 16, 2021.
  1. Feb 16, 2021 at 10:20 AM
    Turbo_4runner
    Turbo_4runner [OP] New Member
    2003 Tundra AC; 1987 4runner; 1971 FJ40; 2015 Golf SW TDI
    New Tundra member here. Been lurking since I stumbled across my 03 AC on the book-face this fall. Found it aimlessly viewing junk for sale that I don't need. I've been trying to justify buying a truck since I sold my last 1st gen Toyota mini to get my 87 4runner. Turns out my wife's limit on just using a utility trailer is about is about 8 years... So as luck would have it she off-hand mentioned that it would sure be nice to have a truck to run around the farm with. My plan has been just to buy like a 2000's Chevy with a 5.3 and 200k miles for a few thousand bucks and just drive it. Well when this Tundra came up in the same price range/mileage and with a better body than any of the Chev's, it was a no-brainer...ish. So I waited a day or so before showing her pics of the truck, because - pro-tip guys, you want it to seem like it was her idea all along. Not that you've been scrounging for a truck all along. She was indifferent except for the miles. Went to look at it with cash after our first cold snap here this fall. Did a once-over and it looked pretty good. Forgot my bore-scope, but did the hammer test on the frame and it sounded solid. Took it for a quick loop. It did truck things, heat worked great 4wd shifted no problem. Wife - still indifferent. Her words "It's a beige 2000's truck". While I was looking the truck over, we found out the seller worked at the local brewery and talked about how nice it would be to have factory reject beer for penny's on the dollar around. We talked about price and I told him my concerns about the timing belt and lack of maintenance. He understood in a way that people who don't know cars understand. We got close on price and I could tell he wasn't going to budge any more so I told him I'd take his last offer if he threw in a case of beer. He gladly obliged. I gave him the cash and he came back out with a huge box full of an assortment of beer - probably $100 worth retail. We both left thinking we got a decent deal. He was mostly glad to have a third vehicle out of his life, I was glad to be gaining a fifth; lol. Drove the truck home and it had a bit of a vibration that I found on the test drive from all the oil from the rear seal mixed with gravel dust - that made the 45 min drive home less fun.
    The good:
    Buying from second owner who drove it for 200k miles commuting across the state
    Body in excellent condition
    LSD
    Interior was complete; no tears, cracks etc.
    Replacement coil packs in the back
    Some rust in the frame, but not bad for where I live
    The bad:
    The state it drove across was in the salt-belt
    270k miles
    No record of timing belt or trans service
    Engine had a random misfire
    O2 sensor codes for both banks
    Interior was gross; like so gross...
    Mis-matched tires
    No record of ball joints being done
    No real service records to speak of....
    Headlights super fogged over
    Rear axle seal had been leaking a long time
    Power steering lines leaking
    Mushy brakes
    Loose steering
    Missing gas cap cover
    Broken tonneau cover
    Things I've done to it:
    Timing belt/water pump
    1/4 ass coolant flush
    Replaced power steering lines
    Swapped coils around till I had all 8 firing
    Drain/fill trans - decided later against doing the filter for now
    Drain/fill differentials and transfer case
    Replace axle seal
    Rear diff vent moved to tail light
    Vacuum
    1/4 ass exterior wash
    Scrape 1/2" of oil and lime stone from the rear rim
    Took each wheel off in the shop since I had to beat the piss out of the first one to get it off
    Anti-seized all the things
    Things I should probably do next:
    New PCV
    See if O2 or Cats are bad
    New brakes all around
    Replace AC Delco spark plugs and Amazon Coil Packs
    Replace steering rack bushings
    Ball Joints/Tie Rods
    Wash frame and KBS rust coat that sucker followed by fluid film
    Replace headlights
    Pulling her in the garage for a first once-over
    I'm going to guess that's an original...
    My families face when you buy a high-mile vehicle, then tear it all apart over thanksgiving was priceless. IMG_2978.jpg
    Prostar 190, YardBird and Darkness like this.
  2. Feb 16, 2021 at 11:45 AM
    Airsavage
    Airsavage New Member
    Butch
    2020 MGM 4X4 4 Dr
    Welcome aboard:hattip:. Good lookin truck:thumbsup:. Here's one to ya:cheers:
  3. Feb 16, 2021 at 11:54 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    Welcome from So Cal
  4. Feb 16, 2021 at 11:58 AM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Welcome from Nevada
  5. Feb 16, 2021 at 12:13 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Good intro and great advice on the wife tip. Please post some of your other vehicles when you can, we like other Toyota too.
    YardBird likes this.
  6. Feb 16, 2021 at 12:14 PM
    Welcome from NY.
  7. Feb 16, 2021 at 12:40 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  8. Feb 16, 2021 at 12:41 PM
    Turbo_4runner
    Meh other babies... Tucked away at our new place.
  9. Feb 16, 2021 at 2:04 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  10. Feb 16, 2021 at 2:51 PM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Welcome you with first post and love the 87 4 Runner...just saying...
  11. Feb 16, 2021 at 5:31 PM
    Welcome from Ohio
  12. Feb 19, 2021 at 8:17 AM
    TXRailRoadBandit73 YOTAS,RAILROADIN',RĂ–KnRĂ–LLN',BEER,MAX/GEMMA
  13. Feb 20, 2021 at 8:38 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Welcome from the wet side of WA.
