New to me 2018 bad sound help
Discussion in '2.5 Gen Tundras (2014-2021)' started by Linuxmale, Feb 26, 2020.
  1. Feb 26, 2020 at 4:48 PM
    Linuxmale
    Linuxmale [OP] 2018 Tundra 2003 Tj
    Sault Sainte Marie, MI
    2018 CREWMAX TRD Off Road ( a Canadian import )
    I’ve recently became the proud owner of a 2018 SR5 TRD Off Road. ( about 3 weeks ) The more I drive it the more I like it. I even drove a much more loaded 2020 RAM Laramie and went with this truck.
    The thing is there is a sound almost exactly like I’m driving over a thin layer of crunchy snow when going slowly over a smooth surface. In fact the first several times I heard the noise I WAS on snow so I dismissed it. But The snow is gone and the sound isn’t. It goes away at higher speeds I think. The truck is under warranty, but the dealer is a 3 hour round trip. So I thought I’d see if anyone has experienced this. It almost sounds like a bad needle bearing or something. I got out and walked by it while someone else drove slowly and I couldn’t hear it. The truck has 21,000 miles on it. Any and all ideas are welcome!
  2. Feb 26, 2020 at 5:07 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Congrats and Welcome, someone will chime in, sorry I couldn’t help.
  3. Feb 26, 2020 at 5:09 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    That's a new one for me. From where, specifically, does it sound like it's emanating?
  4. Feb 26, 2020 at 5:10 PM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    Take a video and post here; either way, if you can reproduce it, make sure you keep it as proof. That way, when you take it back to the dealer for warranty work, you have proof. Some dealerships have shady business practices of “we could not reproduce the problem”.
    15whtrd and Sas like this.
  5. Feb 26, 2020 at 6:32 PM
    Linuxmale
    Thanks everyone. It almost sounds like it’s coming from behind the passenger dash or passenger tire area. I was really surprised I couldn’t hear it from outside. I’ll record it tomorrow and post it.
  6. Feb 26, 2020 at 6:34 PM
    Linuxmale
    Tonight was the first time I sat in the passenger side to listen. It’s definitely louder over there. It isn’t related to the fan, as the sound happens when it is off. It sounds like id think a bad needle bearing would in a driveshaft. But not at 21,000 miles.
  7. Feb 26, 2020 at 6:35 PM
    Sas
    OKC, OK
    Hmm, I wonder if there's something blowing around in there? When you turn the vents on do you hear anything? When was the last time you checked the cabin filter?
    Edit: Lol, beat me to the punch. I'd check the filter anyhow just for sanity's sake since it's an easy one.
    15whtrd likes this.
  8. Feb 26, 2020 at 6:38 PM
    Linuxmale
    One thing that’s changed is I took the owners manual out of the glove box. That filter is worth a check.
  9. Feb 26, 2020 at 6:43 PM
    Sas
    OKC, OK
    I'd turn the air on as well while you have it out just to make sure there's nothing rattling around in there. I found a leaf in mine last time I had it out.
    15whtrd likes this.
  10. Feb 27, 2020 at 4:47 AM
    Linuxmale
    I haven’t driven it yet, but this is the filter from last night. Almost heading into work I’ll know soon!
  11. Feb 27, 2020 at 4:52 AM
    15whtrd
    15whtrd Mr. Blonde
    When you take the filter out, reach down and make sure you didn’t drop anything in the fan.
    TXRailRoadBandit73 and Sas like this.
  12. Feb 27, 2020 at 7:04 AM
    Linuxmale
    Sound is still there. I think I might put a gopro under the passenger side somewhere next. I'll also record the sound at lunch and post it.
    I'm sure the TRUCK gods are punishing me for giving my brother and dad a hard time about their 2020 RAMs not being as reliable. :(
  13. Feb 27, 2020 at 7:48 AM
    Sas
    OKC, OK
    Wow, that's dirty. At least you get to put in a nice, new clean one now. Don't go spending 30m vacuuming it out lol.
  14. Feb 27, 2020 at 7:48 AM
    Sas
    OKC, OK
    Bummer. Really curious to hear it.
  15. Feb 27, 2020 at 10:27 AM
    Linuxmale
    This is one recording I just made. Hope it helps.
  16. Feb 27, 2020 at 10:40 AM
    When you put a new one, which way does the filter go? :devil::boink::crapstorm:
  17. Feb 27, 2020 at 10:41 AM
    15whtrd
    15whtrd Mr. Blonde
    Hard to tell in the video. Maybe it’s your tires. I know on crappy roads that are all cracked, any car makes a funny noise driving down them.
  18. Feb 27, 2020 at 10:41 AM
    15whtrd
    15whtrd Mr. Blonde
    The correct way. Best answer!
  19. Feb 27, 2020 at 10:43 AM
    Linuxmale
    The Filter that was in it was labelled "This way up". :monocle:
  20. Feb 27, 2020 at 10:47 AM
    15whtrd
    15whtrd Mr. Blonde
    The next one will say, Airflow this way. LOL
  21. Feb 27, 2020 at 10:47 AM
    Linuxmale
    I think tonight I'll take that tire off and look around. If I figure anything out I'll post it. Still open to opinions if anyone else has any ideas.
  22. Feb 28, 2020 at 3:49 PM
    Sas
    OKC, OK
    Can't hear much in the video. Might be better to have someone else hold the camera where the sound is the loudest. Also have them stand outside and drive by them a few times to see if they can hear it out there.
  23. Feb 28, 2020 at 3:53 PM
    pickeledpigsfeet
    pickeledpigsfeet New Member
    Sierra Foothills, Ca
    2019 Tundra/14 FJ/ 90 SASed xcab
    Kings & Icons
    Hard to tell from the vid, but check the wiring harness in the engine bay on the pass side as it will rattle at the firewall mount and then check the ecu as it is also a known vibrator. People use hose clamps and rubber to silence it. There are posts here about both issues.
