New to Me 2010, needs some upgrades
Discussion in 'New Member Introductions' started by KeepOnTruckin, Feb 3, 2023.
  1. Feb 3, 2023 at 1:47 PM
    KeepOnTruckin
    KeepOnTruckin [OP] New Member
    Randy
    2010 4.6 4x4 Bare Bones
    Howdy,
    2021-07 I picked up a 2010 4.6, 4x4 double cab, Grade edition w 103k mi. Black on Black.
    I've had Yoda's since the 90's, and do all of my own work. Two things I'd like to change up are the addition of fog lights and hands free calling.
    I thought the addition of an SR5 radio w Bluetooth would be a drop but that appears to get expensive with the addition of an air bag potentially, so this may lead to an aftermarket HU w out steering wheel controls... I'm still looking at options...
    That's all I have for now...
    Bob likes this.
  2. Feb 3, 2023 at 1:58 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Congrats and Welcome Aboard!
    Definately go aftermarket over factory. Wireless android auto/carplay is absolutely amazing!
    1lowlife likes this.
  3. Feb 3, 2023 at 2:12 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Welcome to the forum.
    I agree with @Danimal86
    Aftermarket with wireless android auto/carplay would be the way to go.
    I'd suggest Pioneer or Kenwood.
    If you buy from Crutchfield they have the option to prewire your wiring harness making it a plug-and-play install.
    If you don't have steering wheel controls that makes it cheaper and easier.
    If you do have steering wheel controls an iDatalink Maestro will help you retain them...:thumbsup:
    ACDC2ZZTop likes this.
  4. Feb 3, 2023 at 2:28 PM
    Welcome from NY.
  5. Feb 3, 2023 at 3:39 PM
    KeepOnTruckin
    Randy
    Thanks Gentlemen. Much appreciated.
    The Grade series has no steering wheel controls but that shouldn't slow down an aftermarket HU.
    I see the prices from $ 200 to 600. I was trying to keep this under 3oo. My concern with aftermarket HU is someone might want it more than me wreck my stuff taking it.
    It would be nice to add OBD Fusion App and monitor stuff, with that. Anyone know if the mic is there in the overhead console?
    Truck has the tow package and is rust free but has its share of door dings. So far I've changed all the fluids to synthetic except the poor trans. It's next! My IS-350 has the same A760 trans, so it will get a pan drop, filter, dump and repeat a couple times, refilling with Amsoil. This likely isn't uncommon but in 11 years and 105k, no one ever greased the drive shafts! :eek2: poor thing! lol
    Last summer the AC compressor seized solid nearly stalling the engine, thankfully the ECM realized it's fate and disengaged the clutch.
    I was cursing the engineers that didn't make it possible to remove the condenser from the front. Maybe the studs on the compressor a little too! lol
    There seems to be plenty Fog light DIY, I have some Morimoto LEDs but need to buy the mounts for them. Plan is to add a switch that comes on with ignition AND running lights so they can't be left on and basically come on whenever the running lights and switch are on. Ya, I could add the OEM stalk, but it seems a waste as I have to mod it to run the fogs. I generally drive with running lights on always.... I'm assuming that dropping in the relay gets me power to the lights but planned on installing them if I go looking under the apron...
    Thanks for the welcome and any input on HUs that A, won't break the bank.
    B, don't pop out of the dash.
    C, Android OS....
    Kind regards...
  6. Feb 3, 2023 at 3:56 PM
    Try www.crutchfield.com they will have everything for plug and play. Probably take you less then 30 minutes to install. Just put in all of the vehicle information.
    1lowlife and JLS in WA like this.
  7. Feb 3, 2023 at 8:51 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  8. Feb 3, 2023 at 9:22 PM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    I used crutchfield when I upgraded the head unit on my 08 Limited. Mine took more than a half hour, but it wasn’t bad at all.
  9. Feb 4, 2023 at 7:42 PM
  10. Feb 4, 2023 at 7:51 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Welcome from Nevada
  11. Feb 5, 2023 at 12:23 AM
    dondino
    dondino New Member
    don
    2007 Tunda Crewmax
    Welcome from the rust belt, Pennsylvania.
  12. Feb 5, 2023 at 6:11 AM
    Musicmasterd12
    Musicmasterd12 New Member
    Southern Louisiana
    2011 4.6 Silver Sky Metallic DC
    I didn’t have steering wheel controls and followed one of the how tos on here. It ended up costing me about $300 for an airbag, $50 for controls, and $50 for the swc radio adapter. But now I have steering wheel controls and find in quite nice!!
    mine had fogs already, but you should be prewired for fogs and if so I think you can add the oem stalk (might need a relay too) and that should give you control of the fogs
    and if you’re gonna go oem fogs I’d buy the auto headlight stalk and while you’re at it add the auto headlight feature as well!!!
  13. Feb 5, 2023 at 9:02 AM
    KeepOnTruckin
    Randy
    This is enlightening! Thanks!
    Did you have to replace the clock spring too or did the stock oem unit have all the connections for the wheel controls?
    Did you install an OEM or aftermarket HU?
  14. Feb 5, 2023 at 9:21 AM
    Musicmasterd12
    Southern Louisiana
    No clock spring replacement needed. You unbolt the airbag then when you remove it you can see where steering controls are suppose to go. I bought the steering wheel cutout airbag and the controls and they all bolted up nicely, easy job. On a different forum a member posted how he cut the plastic around his nonsteering control airbag to allow steering controls to fit. I tried that and we’ll you can see how that ended lol
    I went with an aftermarket pioneer with CarPlay.
  15. Feb 7, 2023 at 3:50 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    Welcome from So Cal
