New to me 16 Tundra, couple questions, tires, leveling, lights....
Discussion in '2.5 Gen Tundras (2014-2021)' started by Glaze22, Nov 15, 2018.
  1. Nov 15, 2018 at 7:41 AM
    Glaze22
    Glaze22 [OP] New Member
    Reed
    2017 CrewMax
    I have a new to me 2016 CrewMax 5.7 Tundra with 17k miles on it. All stock, lights, suspension and 18in tires. I LOVE this thing!!!!! Just a couple of questions. I have looked and read these forums for a little while, but can anyone just point blank answer a couple questions. I am not really a do it your selfer and just flat out dont trust myself to work on my truck myself. Thanks
    Right now lifting the truck is not in the budget, but leveling the front end is. Should I just go with a 2inch spacer and be done? I will have the money to lift it in a little while and will do it the correct way, just not now.
    I am going to have the front end leveled. I have 18in wheels and would like to go with 295/70/18 but dont want to have to do any shimming, should I go with a little smaller tire to be sure? Trimming is fine. Or should I go with 20's?
    I would like to get some Spyder type style headlights. Do I get the plug and play or should I go for a whole upgrade? I dont know what kind of bulbs I have now, but am sure they are not LED.
  2. Nov 15, 2018 at 7:47 AM
    Welcome from Texas, just get the new 2018 led headlights, @iHacker makes the harness, @Roman parts guy, get you headlights, check out toytec.com on lift
    Glaze22[OP] and Roman like this.
  3. Nov 15, 2018 at 7:58 AM
    justfortun
    justfortun New Member
    James
    Boston
    2016 SR5
    Been back and forth with this same question. I’m 95% on the road. What I’m leaning towards is going with the Bilstein 6112 in front. They are hundreds of dollars more than a spacer, but if you are going to have somebody tear apart your front end and put something in, it might as well improve the ride. The beauty of the 6112 is the multiple levels (4) of height adjustment. They need to be removed to relevel them but you will have all you need as far as tire growth.
    I just got 275/70r18 and if I buy these would go with the second setting - the 1.3” rise. The upgrade is supposed to work exceptionally well at this lower level for both on and off-road. It would get the front end up a tad, but still have a touch of rake. If I go with a bigger tire in the future I will still have the right suspension because I can bump them up the level higher.
    Still shopping around for prices and trying to find a way to explain this to my wife, but here’s a good price for the 6112 fronts with the 5160 backs.
    https://www.xkstensiveoffroad.com/s..._&_5160_Package_(Free_Shipping_Lower_48).html
    Anyway, it’s a great question and I’m open to more suggestions!
    -fellow 2016 owner
    panicman likes this.
  4. Nov 19, 2018 at 5:53 AM
    Glaze22
    Reed
    2017 CrewMax
    What do you guys think about Rough Country 3 and 1 lifts with their struts???
  5. Nov 19, 2018 at 5:54 AM
    Welcome from NY.
  6. Nov 19, 2018 at 6:39 AM
    Glaze22
    Reed
    2017 CrewMax
    If I go with a 3/1 lift do I need to add diff spacers?
    Could I also just get bilstein 5100's for front and rear and just go with that? Would I need to buy anything else?
    Rought Country sells a 3/1 lift kit with front struts for $350ish. I could get the 5100's front and rear for roughly the same price. What should I go with?
  7. Nov 19, 2018 at 10:50 PM
    619tundra16
    619tundra16 New Member
    Bilstien 5100 if your on a budget and 6112 if you can fork out a little more.
    Improved ride over stock .
    But there are a million different options.
    Glaze22[OP] and OR18TRD like this.
  8. Nov 21, 2018 at 8:07 AM
    Mwray8909
    Mwray8909 New Member
    Chino Valley
    18 TRD offroad cement CM
    How much better are the TRD offroad bilstiens vs stock shocks?
  9. Nov 21, 2018 at 8:21 AM
    mattyd170
    mattyd170 New Member
    Albuquerque, NM
    2020 Tundra Limited Crewmax with Leer shell. Calvary Blue
    TRD Front Suspension, Bilstein Rear, TRD rear sway bar kit, 35" tires, working on stereo.
    I have a Readylift front leveling spacer kit that I bought and didn't use. 2.4" lift. Sell cheap. $160.00 shipped.
  10. Nov 21, 2018 at 10:58 AM
    alpinepro4
    alpinepro4 What is your MPG Today!
    Pat
    2017 TRD Pro Cement DC
    Baja Designs Squadron Sport Fog lights, ARE CX Series Topper, Alcan Springs , DAP Tune, Coach Builder +1 Shackles, Headlight Revolution Supernova V.4 LED bulbs, HR LED interior bulbs. General Grabber ATX 275/70/R18
    Save your money and go ADS! That what I am doing.
