New to me ‘21 Tundra 15k miles
Discussion in '2.5 Gen Tundras (2014-2021)' started by Trey G, Mar 3, 2025.
  1. Mar 3, 2025 at 9:15 AM
    Trey G
    Trey G [OP] New Member
    Trey
    2005 Tundra Limited
    Purchased a “new” 2021 tundra with TRD Sport package over the weekend. Only had 15000 miles. Seat covers were on it since brand new, inside and out the truck is basically new. Down the road when I wear out these tires I want to switch to the slate gray colored TRD wheels if anyone has them in Texas.
    Any tips on caring for this thing or anything I need to know? Feel like I did good on this one!
  2. Mar 3, 2025 at 10:03 AM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler
    :thumbsup: Welcome and good looking truck!
    What I stick to:
    F/R Differential: 30k (OE or aftermarket). -- 75w-90 Amsoil Severe Gear
    Transfer Case: 30k (OE or aftermarket) -- 75w Ravenoil
    Oil & Filter: 5k miles or 6mo. -- Pennzoil Ultra Platinum 5w-30
    Transmission Fluid (drain/fill): 30k or 6yrs. -- OE Toyota Brand.
    Coolant: 50k miles or 5yrs. -- OE Toyota Brand.
    Power Steering Fluid (OE or aftermarket Fluid) -- OE Toyota Brand.
    Brake Fluid DOT 3, inspect at 3 years (aftermarket)
    Sparks Plugs: 120k (OE)
  3. Mar 3, 2025 at 11:59 AM
    00h2itr
    00h2itr New Member
    Carolina's
    21 Limited CM TRD-OR
    Welcome and great starting platform.
    Tons covered around maintenance but I'll warn you, hide your wallet and CC. You'll constantly find things you didn't know you needed posted around these parts.
    As for the truck, it's likely to he highly reliable and not need much other than routine maintenance.
    Henry1jg and Trey G[OP] like this.
  4. Mar 3, 2025 at 12:08 PM
    D1S7N
    D1S7N New Member
    2021 Limited AG
    That thing is mint with only 15k miles!
    ATV25 likes this.
  5. Mar 3, 2025 at 12:09 PM
    nchapa
    nchapa New Member
    Congrats, I just got a 21 tundra with just under 15k as well last week in Texas too, Dallas to be exact. I really wanted a quicksand or white but couldnt pass up the deal on this one.
    ATV25, FabioXc, camron1039 and 4 others like this.
  6. Mar 3, 2025 at 12:25 PM
    OHwendTrd
    Josh
    21 SR5 3UR-FE
    ATF Cooler
    I was a stock truck person until I joined here.
  7. Mar 3, 2025 at 12:33 PM
    Trey G
    Trey
    2005 Tundra Limited
    I actually was eyeing this same one too, haha
    nchapa[QUOTED] likes this.
  8. Mar 3, 2025 at 12:34 PM
    Trey G
    Trey
    2005 Tundra Limited
    I'm gonna do what I can to keep it stock, I do want to change to the trail edition wheels at some point with a little more meatier tire.
  9. Mar 3, 2025 at 12:39 PM
    OHwendTrd
    Josh
    21 SR5 3UR-FE
    ATF Cooler
    Bought a set of OE 18s, refurbished to gloss black, 285/75/18 is my next setup. Deciding between KO3 and AT4W.
  10. Mar 3, 2025 at 12:40 PM
    Ebrperk
    Ebrperk Old member
    South Central Kansas
    2018 1794 MGM
    Tinted windows, go rhino D6 side steps and shorty antenna, Bilstein 5100's rears, 6112's fonts set to 2.5" Rocktrix RT111 18x9 -12offset NItto Terra Grapplers G3's 275/70 R18's. Amp from James @ Tech12volts FRAC Harness
    X2,
    Do this and the truck should last for several years with minimum problems. onward and upwards. mods shall begin
    nchapa and OHwendTrd[QUOTED] like this.
  11. Mar 3, 2025 at 2:05 PM
    nchapa
    nchapa New Member
    Well thank you for leaving it for me :thumbsup:
  12. Mar 3, 2025 at 2:08 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! Awesome find!
  13. Mar 3, 2025 at 5:14 PM
    Tundra@AZ
    Tundra@AZ New Member
    2021 MG Tundra
    Congratulations, welcome to the club
  14. Mar 7, 2025 at 3:01 PM
    SAGE63
    San Diego County
    Then do not look st my build page....lol
    Welcome aboard
  15. Mar 7, 2025 at 3:09 PM
    Beach Toy
    Beach Toy New Member
    David
    SE NC
    2017 White SR5 4x4
    Lomax cover, TRD PRO headlight conversion...so far anyway
    Good luck if you hang out on here
  16. Mar 7, 2025 at 3:17 PM
    OHwendTrd
    Josh
    21 SR5 3UR-FE
    ATF Cooler
    LEAVE NOW! A fair warning... money pit in progress
    Panda21MGMcMax, 1UP and SAGE63 like this.
  17. Mar 7, 2025 at 3:30 PM
    Panda21MGMcMax
    Panda21MGMcMax New Member
    San Diego
    2021 MGM 4x4 CrewMax Limited
