New Tires Causing Poor Fuel Mileage
Discussion in '2nd Gen Tundras (2007-2013)' started by mbrown0772, Oct 30, 2016.
  1. Oct 30, 2016 at 7:21 AM
    mbrown0772
    mbrown0772 [OP] New Member
    2011 Tundra 4x4
    I have a 2011 Tundra 4x4 and when I bought the truck it had factory rims and 285/55/20 BFGoodrich AT's. I bought some Extreme Mudder Rims and capped them with some Toyo's AT 305/55/20's. I also installed a leveling kit. Made the truck look good. The problem is my gas mileage dropped from 16 mpg to 12-13 mpg. A figured the new tires and rims would drop it a little but this seems a little excessive. Is this normal?
  2. Oct 30, 2016 at 8:49 AM
    Relentless
    Relentless Eric @Relentless Fab Vendor
    Eric
    East of the Sierras(Reno), Nevada
    '14 Crewmax TRD 4x4> '15 Duramax SLT
    Just a few, more to come
    Leveling kit impacts MPG too; higher up= pushing more air going down the road. Plus the wider/taller/heavier and more aggressive tire impacts the MPG. I dont think what you're getting is out of line. My Tundra stock got about 13 city 18 hwy like it was rated. Lifted 3" and 35x12.50R18's and I'm 10-12 city and 15-16 highway.
    Law323 likes this.
  3. Oct 30, 2016 at 8:58 AM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    The Toyo AT 2 in 305/55r20 only comes in their "extreme" tread and is also a 10 ply tire. Long story short, you went to a wider, taller and much heavier tire with a more aggressive tread.
    Also lifting the truck and adding wheels with a more positive offset is making you have to push more air going down the road.
    I think a 2-3 mpg drop sounds about what I would expect with that combo
    joonbug and Law323 like this.
  4. Oct 30, 2016 at 9:13 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    ^^^^These guys above me said it all. Really nothing else to add.
    Price we pay to drive a real truck.
    It's worth it brother!! Trust me!
    Relentless likes this.
  5. Oct 30, 2016 at 9:48 AM
    CaptTyler
    CaptTyler Life’s too short to have an ugly boat.
    Tyler
    2018 Ram 2500 Cummins
    Yep sounds normal. Mine dropped even more than that with a 3" lift and 35's.
    But it looks oh so good :)
    Law323 and Relentless like this.
  6. Oct 30, 2016 at 10:17 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Normal and expected
  7. Oct 30, 2016 at 10:57 AM
    Bear
    Bear Fargin' Iceholes
    Bear
    Custer, SD
    2022 GMC Sierra 3500 Dually
    Pulsar Edge V3; MBRP side dump exhaust
    To make yourself feel better, you need to account for larger tire size over stock when computing ACTUAL miles travelled. Larger tire size, without a speedo correction, will log less miles in the OD. Ex: 10% larger tire over stock results in a speedometer error of roughly 10%, and associated OD readings of miles travelled by 10%. So if you drive 300 miles on the odometer, in reality you actually travelled 330 miles. Your numbers may vary, as I have no clue what stock tires/speedo fix came with your ride, but you need to refugees those numbers into your mpg calculations
    Law323, TheBeast and BlueFalconActual like this.
