New tie rods make clunking noise
Discussion in '1st Gen Tundras (2000-2006)' started by stevechumo, Jun 24, 2020.
  1. Jun 24, 2020 at 3:22 PM
    stevechumo
    stevechumo [OP] New Member
    I just replaced the factory inner & outer tie rods with Proforged brand. After the replacement, they make a stiffer ride, and there's a clunking noise when I go over bumps and dips. Does anyone have similar issue after replacing the tie rods?
  2. Jun 24, 2020 at 4:43 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
    2006 Tundra 4.7 AC 2wd
    2006 Tundra: Stock air intake 3 inch catback Magnaflow 13742 2.5 inch front lift 1.5 inch rear blocks 2014 sr5 4Runner wheels (17x7) 1.5 inch hub centric wheel spacers p285/70/17 Nitto Terra Grappler G2 Weathertech floor liners
    How did you narrow it down to the tie rods? Please check and make sure your sway bar end links are good and tight too. I’ve made the mistake of thinking they were tight while up in the air and they really should be snugged down once the truck is back on the ground. I hate noises on my truck too, believe me I’ve had to hunt down noises before. I once had a loose alignment cam that made a horrible clunk (metal on metal) noise.
    MS22 likes this.
  3. Jun 24, 2020 at 4:52 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    ^^^^^^^ This.... I rode for the better part of 5 years trying to figure this same thing out on my Celica... I finally gave in and bought new sway bar end links since they were cheaper I discovered while removing the old ones that the shop who last installed my struts, failed to tightened the end link on the driver side... Made me think I needed ball joints and end links for the longest time... I saved enough to buy everything, but decided to purchase 1 at a time and that is when I discovered that the endlinks were the culprits... Its been a year and its been quiet and smooth.....
    MS22 and revtune[QUOTED] like this.
