New tailights need help!
Discussion in '1st Gen Tundras (2000-2006)' started by KingFreeman, May 13, 2023.
  1. May 13, 2023 at 11:04 AM
    KingFreeman
    KingFreeman [OP] New Member
    anthony
    2002 tundra limited
    I'm trying to but new taillights and i was wondering can all non double cab first gens have interchangeable taillights. I wanna get these taillights on Amazon they look like they'd fit but I'm not sure if they slightly changed the design between the years. i have 2002 tundra limited and I'm trying to see if these fit. https://www.amazon.com/EPIC-LIGHTING-Replacement-815600C060-815500C060/dp/B08BLT9SLL
  2. May 13, 2023 at 2:22 PM
    PenderBen
    PenderBen Forum lurker…
    Gulf Islands, BC Canada
    2003 Tundra AC 4x4
    Yes, access cab and regular cab taillights are compatible across all years.
    I got Depo in the later style (like you posted) for my ‘03 from Rock Auto, they cost more than those but Depo’s a more reputable brand as far as I’m concerned, although those have decent reviews and are super cheap, might be worth trying.
    Of course I shut the tailgate on a bungee cord a couple months later and broke the corner on one :-(
    KingFreeman[OP] likes this.
  3. May 13, 2023 at 6:27 PM
    Second for Depo lights. And you won't find them on scAmazon, becuase scAmazon only feeds you garbage 1-off brands.
    I'd recommend picking your lights up on RockAuto. They'll have a good selection. Buy CAPA certified lights if you can, they'll be clearly marked with the "CAPA" designation. This is just your insurance that they'll last at least 4-5 years without problems. Depo is solid, so are Eagle Eyes and potentially TYC.
    The earlier years have an orange blinker, the ones you show are from a later model RC/AC truck. If you switch up to those, you'll need to make some small wiring changes before it's plug-and-play. I can't recall the changes, I haven't done the swap, but others have.
  4. May 13, 2023 at 7:12 PM
    PenderBen
    2003 Tundra AC 4x4
    I can’t recall for sure, but I think the Depos were plug and play for me going from the older style light to the new one… if there was any change it must have been minor because I didn’t have any issues and the swap went quick.
    If you go to buy from Rock Auto just put in a later model year (like 2005) and it’ll show you the updated styles.
  5. May 13, 2023 at 8:05 PM
    KingFreeman
    anthony
    2002 tundra limited
    thank you all for the replys helps alot. ill be sure to check out rockautos site
