New Stereo Questions
Discussion in 'Audio & Video' started by LSUTundra, May 18, 2019.
  1. May 18, 2019 at 1:14 PM
    LSUTundra
    LSUTundra [OP] New Member
    Hey guys, I've been going through pages and pages to see what is needed to replace my stereo but had a few questions. I'm going with a Pioneer MVH-2300NEX with a Maestro RR. I see I will need T02 and a UT02. I have a non-JBL unit.
    -Just to verify, the UT02 will retain the USB on the dash?
    -It's been about 10 years since I installed one of these, the T02 will splice into the stereo wiring? Then from the Maestro I connect to the HU?
    -Will I be able to retain the stock mic?
    Anything I missed would be great to know. Thanks
  2. May 19, 2019 at 5:56 PM
    tundraal
    tundraal New Member
    I don't think there is a way to retain the factory mic. Most head units will come with their on mic and you just mount it where ever you want. I just put a Kenwood in mine and just decided to forgo the mic because I never use bluethooth calling or the "hey siri". It will retain the factory USB in the dash with that harness... No splicing. Just remember to flash the Maestro unit when you get it, you can select which steering wheel buttons control which actions etc. Once you flash it, it will give you a page of instructions on how to connect everything. The TO2 is a giant harness that will mostly connect directly to the factory wires on one end. The other end will connect to Maestro and there is a junction towards the middle where you will join the main head unit harness to the Maestro harness.
  3. May 19, 2019 at 7:46 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    The maestro with TO2 makes it all plug and play, lots of wires but it all makes sense once you start to plug everything in. Unfortunately you'll have to install the new mic, I wish someone would make a unit to integrate the OEM mic. My kenwood mic kinda suxks. People say it echos and seems delayed, OEM was perfect. The usb should work fine with that adapter, however its hit or miss if that usb will allow for plug in CarPlay or android auto, some head units require the use of the usb port on the back of the head unit.
  4. May 19, 2019 at 8:57 PM
    jabula_za
    jabula_za New Member
    Shaun
    Sabre Springs, CA
    2017 Tundra SR DC 4x4
    Icon 2.5s with RR & CDCV, 17x8.5 Method MR316 with BFG AT K02 32.6x17x10.5. K&N Filter, Blacked out tailgate emblems.
    I have taken apart the factory mic and it is possible to wire it up to aftermarket wiring, but not worth the effort. The aftermarket mic is way better if u route it to the roof by the sunglasses holder and and thread it out the side there, stick it on the plastic.
    People can hear me better even with big ass MT’s making a noise, with the windows open. I will try take a pic for you to see but similar to what others have done on here.
    ScooterInNV likes this.
  5. May 19, 2019 at 9:01 PM
    Pudge
    CT
    The wire on my mic wasnt nearly long enough to reach my center area. I made it to pretty much right front of my face. Maybe there is a alternate route to run the wire cuz I seem to be the only one with this issue
  6. May 19, 2019 at 9:02 PM
    nvrgvup444
    nvrgvup444 New Member
    KCMO
    2015 Dbl Cab Limited - Blue Ribbon
    Bilstein 5100 all corners, Toytech Shackles, Nitto Ridge Grapplers, Completely new sound system that sounds great but didn't cost an arm and leg, front camera, front receiver hitch
    Agree with others on having to run a new mic. I had to run a new mic however it was with a Kenwood 9903 and not Pioneer. I didn't even bother to give it a second thought.
  7. May 19, 2019 at 9:02 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Like others said, the stock mic won't work with aftermarket head units, at least not easily. I just routed my Pioneer-supplied mic to the overhead console and replace the factory one. Haven't heard complaints on sound quality.
    The only other adapter you may want is the STO2 for the factory XM and GPS antennas if you want to keep those.
  8. May 19, 2019 at 9:04 PM
    jabula_za
    Shaun
    Sabre Springs, CA
    Mine was also a pioneer, I routed it through the dash up the pillar and along above windscreen. It should be a smaller headphone jack port - u might be able to get an extension cable of Amazon or something if u need.
    Pudge likes this.
  9. May 19, 2019 at 9:09 PM
    jabula_za
    Shaun
    Sabre Springs, CA
    Also, I used crutchfield to determine what I needed, than shopped around for the parts - although they were still pretty much the cheapest - unless you don’t mind waiting a week or two for the parts. I recently did the similar install you are doing - pioneer, no amp, usb, steering wheel controls, Sirius xm and antenna etc
  10. Jul 31, 2019 at 11:14 AM
    LSUTundra
    Do I still need the Sirius tuner if I have the T02? That will connect to the factory Sirius antenna correct?
  11. Jul 31, 2019 at 11:25 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Yes, you'll still need a separate tuner. The STO2 adapter just connects the aftermarket tuner to the factory antenna. The aftermarket head unit will not have a built in satellite radio tuner (unless you've got a very specialized model, maybe)
  12. Jul 31, 2019 at 11:26 AM
    LSUTundra
    Thank you, last piece to the puzzle I believe!
  13. Aug 3, 2019 at 4:44 PM
    LSUTundra
    Do I need to connect the blue/white which is system remote control? Guessing that is for the included remote? Also, what about the purple/white which is reverse gear signal input? Is that what triggers the backup camera?
  14. Aug 3, 2019 at 7:46 PM
    Pudge
    CT
    The purple wire, i think, can just be grounded to the head unit with one of the screws on it. I think that's what I did anyway, in had 2 wires in that area and one of them I'm grounded to the headunit, it's possible I'm thinking of the other wire and you'll need to connect the purple to the reverse switch, there should be a purple wire in your adapter harness/maestro harness.
    And the blue wire if it's what I am thinking, is "remote" amp turn on wire, basically it turns the amp on when you turn the stereo on / start the truck, needs to be wired to an aftermarket amp "remote" terminal, usually near the power and ground terminals.
  15. Aug 3, 2019 at 8:16 PM
    Pudge
    CT
    Found a pic. Purple reverse wire got wired to a purple wire in my TO2 harness for maestro
  16. Aug 4, 2019 at 6:21 AM
    LSUTundra
    Awesome, thanks! What about the factory antenna for local FM? The T02 does not seem to have a plug for it?
  17. Aug 4, 2019 at 6:53 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Did the kit you bought not include the antenna adapter? This came in mine:
  18. Aug 4, 2019 at 7:32 AM
    DCB500
    DCB500 New Member
    David
    Oklahoma City
    2019 Tundra SR5 TSS Double Cab
    Wheels, sound system, antenna, tailgate letter inserts, Grill/Hood Bulge, Exhaust, Leather
    These are the items I purchased for my install, the antenna adapter was a separate part from the t02 and maestro. Also a pic of where I mounted the mic.
    BA7F89B2-D423-4EF2-860D-B35BD1CEEFBA.jpg 7F557A3D-6499-4170-B807-C254926E19F0.jpg 4D102F3D-C44A-4580-A332-C7920629B3C4.jpg
  19. Aug 4, 2019 at 7:33 AM
    LSUTundra
    Thanks, I didn't realize it was a separate part.
  20. Aug 4, 2019 at 8:16 AM
    Pudge
    CT
    Yup need separate part metra40lx11
  21. Aug 4, 2019 at 8:29 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Man, I really lucked out by cheaping out in my install :rolleyes:
  22. Aug 4, 2019 at 8:31 AM
    LSUTundra
    I hear that, this is crazy! I miss the old days of a regular wire harness, I can't tell you how many times I changed the stereo out in my Ranger and F150. It was so simple!
