New steering rack bushings ..crooked steering wheel?
Discussion in '1st Gen Tundras (2000-2006)' started by AWilliams, May 30, 2021.
  1. May 30, 2021 at 5:23 PM
    AWilliams
    AWilliams [OP] New Member
    So I just did my Total Chaos steering rack bushings on my 03. Took it for a drive today and noticed that now my steering wheel is about a 1/2- 3/4" off now from being center. I had an alignment done when I had my wheels and tires put on and had my Kings recharged. Is this normal? When I took out my old steering rack bushings they didn't look too bad they were actually acceptable the horizontal driver side was starting to come apart. Thx
  2. May 30, 2021 at 8:20 PM
    Wes_heppy
    Wes_heppy Trucks...Dirtbikes... Guns...
    Weston
    2003 tundra 4x4 4.7
    TC UCA Radflo coilovers Long Tubes LSD
    Hmm don’t see how the bushings would do that. Did you disconnect the steering shaft or replace tie rods or anything?
  3. May 30, 2021 at 8:41 PM
    AWilliams
    nope....
  4. May 30, 2021 at 8:51 PM
    Sirfive
    Sirfive Master Procrastinator
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    On my sequoia the loose rack bushings allow the rack to walk back and forth 1/2” or so. Maybe the alignment show compensated, so with new bushings it put the rack back where its supposed to be?
    Sunnier likes this.
  5. May 30, 2021 at 9:09 PM
    AWilliams
    interesting...
  6. Jun 2, 2021 at 4:45 PM
    nickrick78
    nickrick78 New Member
    Nick
    Pittsburgh PA
    2004 DC
    If it was aligned with the slop in the bushings, it's possible the wheel was slightly off center when the toe was adjusted, which now that the rack is solidly mounted it needs realigned.
    Sunnier likes this.
  7. Jun 2, 2021 at 6:08 PM
    AWilliams
    ok cool...so there's only 1 way this goes in...with it in straight ahead orientation?
  8. Jun 3, 2021 at 11:35 AM
    nickrick78
    Nick
    Pittsburgh PA
    2004 DC
    Yeah, you pretty much can't install them wrong
