NEW! Stage Series HitchMount LED Pod Kit | The BEST 5 Minute Mod!
Discussion in 'Lighting' started by Diode Dynamics, Oct 28, 2022.
  1. Oct 28, 2022 at 2:37 PM
    Diode Dynamics
    Diode Dynamics [OP] New Member
    https://youtu.be/bqaGk_mltCU
    Diode Dynamics is proud to introduce our Stage Series HitchMount LED Pod Kit!
    Features:
    • Allows you to mount an SSC1 or C1R LED pod in any 2-inch trailer hitch receiver.
    • Adds a powerful reverse light, 4th brake light, and additional running light.
    • Simple 5-minute installation, with no need for custom wiring or routing wires.
    • Optional SafetyStrobe brake light strobing.
    • Designed and assembled in USA.
    Add significantly more light output when backing up at night with our Stage Series HitchMount Reverse Light Kit! This kit allows you to mount one SSC1 or C1R LED pod in your 2-inch trailer hitch receiver, adding a high-power reverse light, additional running light, and an optional 4th brake light with the C1R option. With the included wiring harness, this kit connects to your vehicle's factory trailer hitch wiring for simple, everyday operation.
    Brighter Backup. Factory reverse bulbs just don't provide enough light output to back up at night confidently. By pairing our patented TIR optics with high-powered LEDs, the SSC1 and C1R included in this kit provide an additional reverse light that's several times brighter than stock bulbs alone. Plus, they automatically come on when the vehicle is put in reverse!
    Additional Running Light. The Stage Series LED pods included with this kit feature a distinctive red backlight that can be used as an additional running light while driving! The backlight fully illuminates the TIR optic, providing a more unique and modern look than the small indicator LEDs found in other products.
    SafetyStrobe 4th Brake Light. The C1R option features a high-power red function to serve as a powerful 4th brake light, along with the low-power running light. The high-power red functionality activates anytime you apply your brakes, adding a 4th brake light to your vehicle.
    The C1R also features optional brake light strobing. By default, the C1R will flash three times anytime the brake lights are applied, for greater visibility. The SafetyStrobe feature can be easily disabled if desired.
    Everyday Operation. This kit is completely plug-and-play with all 7-pin trailer connectors. The included harness plugs right into your factory trailer hitch wiring for easy installation and operation. The kit operates as an additional red running light with your tail lights, and then automatically switches to a high-power backup light when your vehicle is in reverse. The high-power 4th brake light feature included with the C1R will activate anytime you apply your brakes. If you would like to have override functionality to manually turn on the reverse light anytime, you will need to purchase the universal backup harness.
    If your trailer connector is not 7-pin, this kit will still work for you but will require slight modification to the harness.
    Simple Installation. The patent-pending snap-fit design allows you to install this mount in minutes, without any drilling or need for a hitch pin. Simply insert the HitchMount into your trailer hitch receiver and the snap-fit side mounts will snap into place. Installation couldn't be easier and takes less than five minutes!
    This kit is ideal for anyone who uses their trailer hitch often since removal can be done in minutes as well! Simply unplug the harness, press the snap-fit pins and remove the mount. When you're not using your hitch for towing, you can quickly reinstall the HitchMount and plug it back in.
    Focused. Traditional optics like reflectors or simple lenses lose light internally and to glare, so not all of the light shines on target. Instead, the custom-engineered TIR optic in our Stage Series pods collects all of the light from the LED, and directs it only where you need it, drastically reducing glare and improving total efficiency. Click here to learn more: Total Internal Reflection (TIR) Optics | Stage Series Video.
    From there, while other options on the market lose as much as 10% of the light output shining through an outer lens, the custom-molded TIR optic in the Stage Series LED pods serves as both the optic and main lens for greater efficiency and light output (patent pending). Thanks to this innovative feature, when coupled with high-intensity LED chips, the total intensity of our pods is much greater than other LED pods using basic optics or reflectors with a standard outer lens.
    Functional Output. All Stage Series beam patterns were designed with optical simulation modeling, to shape the output in a highly-functional beam pattern.
    • Flood pattern was designed to provide uniform, even illumination with a full 50x50 degree spread of light on the SSC1 LED pod. Unlike generic "flood" lights that are simply a heavily diffused spotlight, our flood pattern uses pillow optics on the outer lens surface, to provide a true optically designed spread, for even illumination throughout.​
    https://www.youtube.com/watch?v=yr3GmX8EFvg
    Security. If you would like to use a locking trailer pin to install this kit instead of the snap-fit pins, you can do so with a quick modification. Check out the YouTube video above!
    Proven Reliability: Stage Series LED lighting has been extensively tested for long-term operation from -40 to 185 degrees F, along with vibration, moisture intrusion, and corrosion testing. All of these tests are completed to SAE standards, just like factory components. They've also been put to the test on-road by racers and enthusiasts alike.
    If you have any questions, please don't hesitate to post, PM, or email contact@diodedynamics.com.
    PM us for the free-shipping code (U.S. forum members only)
    John C.
    Diode Dynamics
  2. Oct 28, 2022 at 3:35 PM
    Taco-Spike
    Two Trucks
    That is a lot of features!
  3. Oct 28, 2022 at 4:57 PM
    808Tunderer
    808Tunderer New Member
    2021 DubCab SR5 4x4 TRD Offroad
    Stock
    This is awesome!!
    Diode Dynamics[OP] likes this.
  4. Oct 29, 2022 at 5:39 AM
    token2k6
    token2k6 New Member
    2021 Tundra CM SR5
    I'm definitely ordering one! I can't keep anything in my hitch bc my garage door closes an inch away from the truck. This will be perfect!!
  5. Oct 29, 2022 at 6:58 AM
    Doxiedad
    Doxiedad Distinguished Member
    James
    Charleston, SC
    2020 Tundra SR5 TRD Off Road Cavalry Blue
    I like it. Will the plug in back stop you from mounting a ball mount in the hitch? Obviously after you pull the light out.
  6. Oct 31, 2022 at 11:55 AM
    Diode Dynamics
    The DT connector fed through the hitch can be removed and stored up and out of the way as you see fit if installing a mounting ball in place. Simple and quick!
  7. Nov 1, 2022 at 1:24 PM
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    '21 Cavalry TRD Sport CM
    That’s freaking awesome! I’ll be treating myself to a birthday present!
  8. Nov 21, 2022 at 6:19 AM
    Asolo
    Asolo New Member
    2020 MGM Platinum CM
    BD Squadron pros,S2 pros, S1, 30” ONX6+, SwitchPros
    Love it! My only questions is how can you secure it to prevent people from stealing it?
  9. Nov 21, 2022 at 7:38 AM
    Diode Dynamics
    In the forum thread, there is a security section with our YouTube video showing how to add a locking pin easily!
    https://youtu.be/yr3GmX8EFvg
    omgboost likes this.
  10. Nov 21, 2022 at 10:11 AM
    Diode Dynamics
    Our Black Friday Sale is LIVE! Visit the website for our BIGGEST savings ever!​
    20% OFF Sitewide
    30% OFF Stage Series Single-Row Lightbars
    15% OFF Elite Series Headlights
    ➡ Free US Shipping on any order with a HitchMount LED Pod, or orders over $300.
    No coupon code is required.
    Click HERE to shop!
    John C.
    Diode Dynamics
    Sale ends 11:59 p.m. CST on Tuesday, 11/29/2022. Cannot be combined with other coupon codes.​
    PermaFrostTRD likes this.
  11. Nov 21, 2022 at 3:53 PM
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    Ohhhhh my
  12. Nov 21, 2022 at 4:20 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Is there an amber option to use as a chase light?
  13. Nov 21, 2022 at 5:31 PM
    ArmygreenTRD
    ArmygreenTRD New Member
    2022 Army Green TRD, SR5 DC
    John C@DD. The only item not on sale is the only item you show in the BF sale???
    Soflo likes this.
  14. Nov 21, 2022 at 5:32 PM
    Soflo
    Soflo New Member
    Tom
    Miami, FL
    2022 Tundra TRD off road
    What’s wrong with stock?
    I went to order but it doesn’t give me the 20% off site wide discount.
  15. Nov 21, 2022 at 5:34 PM
    ArmygreenTRD
    Yup, not included in the sale. Maybe DD will see this and change their minds?
    Soflo likes this.
  16. Nov 22, 2022 at 10:51 AM
    Diode Dynamics
    Unfortunately, our HitchMount LED pod is our most popular release in company history.
    While we aren't offering a price discount due to the pre-order status, we are offering free US shipping with each HitchMount LED pod ordered.
    No product includes free shipping unless a cart is over $300. Sorry for the confusion!
    Additionally, many users have asked about the shipping date moving from early December to January. This is due to the launch unexpectedly being the biggest in company history. We sold out of 1000+ units in the first week and have only gained more traction each day.
    Currently, we are awaiting components for our shipping team here in St.Louis Missouri to begin assembling and re-stocking.
    Thank you all for your support and understanding. If you have placed an order, we assure you that you're going to love the new HitchMount LED pod and are worth the wait!
    Thank you again and Happy Thanksgiving!
  17. Nov 22, 2022 at 1:26 PM
    FitsofRage88
    FitsofRage88 real eyes realize real lies.
    Hill Country, Texas
    2019 FFV CM (3URFBE) 2Gen
    Blackhawk(0CU00) Working on it!
    @DiodeDynamics
    Order Placed Boss!..
  18. Nov 23, 2022 at 7:46 AM
    Diode Dynamics
    We're excited to get this fulfilled as soon as possible for you! :thumbsup:
  19. Nov 29, 2022 at 7:29 AM
    Diode Dynamics
    Our BIGGEST and LAST sale of the year ends TODAY 11/29 at 11:59 pm CST!
    20% OFF Sitewide
    ➡ Plus, orders over $300 receive free US shipping!
    Excluded Products:
    Hitch Mount LED Pods (Includes free US shipping)
    CLICK HERE TO SHOP!
    John C.
    Diode Dynamics
    Sale ends at 11:59 p.m. CST on Tuesday, 11/29/2022. Cannot be combined with other coupon codes.
  20. Dec 15, 2022 at 2:46 PM
    Diode Dynamics
    Our production team here in St.Louis, Missouri is working hard to fulfill C1 and C1R pre-orders!
    Thank you for your support and patience!
  21. Dec 16, 2022 at 12:04 PM
    token2k6
    token2k6 New Member
    2021 Tundra CM SR5
    I just got mine in! If you've never messed with the plug under the vehicle, on my 21 it just slid right off with no locking mechanism or tab. Leave those little grey tabs alone.
    The harness was very firm and rests easily on the spare tire without putting any stress on the original connector. Uses one zip tie for the wire that runs to the pod and that was it.
    I got the C1, was confused it didn't have brake light support, thought the C1R just strobed the brake light and both had it, but oh well. The reverse light nearly blinded me!
    Thanks for a great new product!
  22. Dec 16, 2022 at 2:22 PM
    Diode Dynamics
    We're happy to hear the positive feedback!
    Sorry for any confusion regarding our C1 and C1R configuration.
    We will defiantly add more information to provide a clear distinction between the two models!
  23. Mar 10, 2023 at 2:34 PM
    Diode Dynamics
    https://www.youtube.com/watch?v=QCeS6RDzJ68
    ⌛THE CLOCK IS TICKING... ⌛
    NOW
    is your chance to SAVE up to 15% sitewide on your favorite Diode Dynamics LED lighting products.
    Up to 15% OFF LED Lighting Upgrades
    ➡ 15% OFF Stage Series Rock Lights & HitchMount LED Pods
    10% OFF Elite Series JL/JT Headlights
    ➡ Free US Shipping on any order over $300!
    CLICK HERE TO SHOP NOW
    Did you know?
    You can find all of the products we offer for your vehicle using our vehicle finder tool! Simply enter the year, make, and model.
    SALE EXPIRES 11:59 P.M. MONDAY, MARCH 13TH, 2023.
    Discounts cannot be combined with other offers or any previous orders. Excludes items with pre-order status.
  24. Mar 19, 2023 at 10:45 AM
    Topwhite007
    Topwhite007 New Member
    2023 1794 TRD
    Hello, any Sale/Discounts/promo codes coming up soon?
  25. Mar 19, 2023 at 10:54 AM
    808Tunderer
    Stock
    Was there any issues with your truck thinking you had a trailer hooked up after installing the hitch light? @token2k6
  26. Mar 20, 2023 at 8:28 AM
    Diode Dynamics
    Unfortunately, we just finished up our Spring Sale on 3/13 and don't have another sale period for quite some time. Sorry about that!
  27. May 17, 2023 at 11:23 AM
    Diode Dynamics
  28. May 25, 2023 at 12:57 PM
    Diode Dynamics
    Our Memorial Day Sale is LIVE!!! ​
    ➡ Up to 15% OFF Sitewide
    10% OFF JL/JT Elite Series Headlights
    ➡ Free US Shipping on any orders over $300!
    Excluded: F150 Elite Series Headlights, and F150 Elite Series Fog Lights
    John C.
    Diode Dynamics
    Hours: Monday-Friday 10 a.m. - 5 p.m.
    Email: contact@diodedynamics.com
    Phone: 314-205-3033
    Sale ends 11:59 p.m. CST on Friday, 6/2/2023. Cannot be combined with other coupon codes.
  29. May 25, 2023 at 1:43 PM
    AGTundra
    AGTundra New Member
    Miguel
    North Carolina
    21 CM TRD Off-road
    Someone almost got us otw to school this am…I believe the flash will get their attention! just ordered mine!! Thank you Cameron!
  30. May 27, 2023 at 5:03 PM
    VietGuy
    VietGuy New Member
    Houston
    2019 Tundra CrewMax Cement
    I just installed mine on my 19. Anyone having issues with the safety strobe? My strobe would only work randomly. Maybe 2/10 times I’ve tried the brakes and it’s kinda irritating that i bought it mainly for that feature. I also saw a video of a Tacoma with them and when they turned on their hazards, the c1r would strobe the whole time. But mine doesn’t. I’ve even waited every 10 seconds to step on the brakes to see if there was a reset but that didn’t work. Purple wire seems to be in tacked so I wonder if mine is faulty on arrival. Anyone ran into the same issues?
