New spacers, new noise
Discussion in 'Wheels & Tires' started by TheBubbaDude, Sep 8, 2020.
  1. Sep 8, 2020 at 9:09 PM
    TheBubbaDude
    TheBubbaDude [OP] New Member
    2020 Tundra TRD Pro
    AJT Blackout Kit 1.25" Wheel Spacers NRG 285/70/18 Meso Customs TRD Start Button
    Put 1.25" spacers on yesterday and now hear a weird clicking when I turn the wheel.. bad install or bad spacer?
  2. Sep 8, 2020 at 9:23 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Kind of a vague question, even probably for all of the great minds here. Pics of your install and a vid of the noise would probably help things out if you can.
  3. Sep 9, 2020 at 3:20 AM
    Bad Cow
    Bad Cow GOD Bless The USA
    Georgia USA
    2019 TRD PRO - SUPER WHITE
    Leather Steering Wheel, +1.5" Shackles
    Are you referring to 1.25" strut spring spacers or wheel spacers?
    Black Wolf likes this.
  4. Sep 9, 2020 at 4:16 AM
    TheBubbaDude
    2020 Tundra TRD Pro
    Sorry, wheel spacers.
  5. Sep 9, 2020 at 4:17 AM
    TheBubbaDude
    2020 Tundra TRD Pro
    Not sure if I can get a video of the noise as it is subtle. The best way I can describe it is a minor CV click
  6. Sep 9, 2020 at 4:36 AM
    What type of spacers did you use?
    Are they hub centric?
    Did you torque them down, drive it about 50 / 100 miles then re-torque them?
    TheBubbaDude[OP] likes this.
  7. Sep 9, 2020 at 4:39 AM
    timsp8
    NY
    As long as the lugs are torqued properly, spacer shouldn’t affect anything that would click. Try like said above and check or retighten the lug nuts.
  8. Sep 9, 2020 at 4:47 AM
    TheBubbaDude
    2020 Tundra TRD Pro
    I did not retorque them. I will pull the wheels and do that this morning.
    This is also a rookie question, but should I have used Loctite on the spacers as well? The spacers didn't come with any and I didn't see anything in the instructions that said it was needed.
  9. Sep 9, 2020 at 8:22 PM
    Pitbull410
    Pitbull410 New Member
    2020 TRDPro CM MGM, 2018 LC200 MGM
    No loctite
    Are you sure it's not just the tire rubbing on the bumper or fender liner or something??
  10. Sep 9, 2020 at 8:27 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Not quite true, each manufacturer has their own specification on hoe to install their spacers.
    The answer to you question is "Follow the manufacturer recommendations".
    I also would have guessed your rubbing on the wheel well or mudflaps somehow.
  11. Sep 9, 2020 at 11:02 PM
    TheBubbaDude
    2020 Tundra TRD Pro
    My apologies I meant to.post the follow-up. I retorqued them and all seems well. I'll do some more driving on them and see how they hold up for another 100 miles or so. If they don't loosen I'll chalk it up as a win. Otherwise I'll get the loctite or just bump up to the larger wheel.
