New Rotors & Brakes
Discussion in '2nd Gen Tundras (2007-2013)' started by Coba, Dec 2, 2016.
  1. Dec 2, 2016 at 6:18 AM
    Coba
    Coba [OP] New Member
    08 Tundra
    Hello, New to this Site! I just replaced my Front Rotors & Brake Pads, Feels better then before! But When I am Hitting about 60 MPH, and I hit my brakes it still Shakes! any Advice what to check from here... Thank you
    ColoradoTJ likes this.
  2. Dec 2, 2016 at 6:22 AM
    Welcome Frank!
    My Tundra would do the same thing and a wheel balance usually helped that. The Tundra is very sensitive to wheel balance.
    My Tacoma and Lexus are the same way.
    I would also get a road force balance.
  3. Dec 2, 2016 at 6:26 AM
    Coba
    08 Tundra
    Ok, Thanks But wouldn't you feels something without hitting the brakes? If the wheels were out of Balance?
  4. Dec 2, 2016 at 6:46 AM
    Not always. If the wheel balance is off just a little, it makes a big difference.
    Just to verify, what brand rotors/pads did you put on? Was run out checked before installation?
    SouthBoundSteve likes this.
  5. Dec 2, 2016 at 7:02 AM
    Coba
    08 Tundra
    Bosch Rotors, and Duramax Gold Brake pads, Yes Rotors are true! I thinking maybe Lower Control Arm bushings?
  6. Dec 2, 2016 at 7:16 AM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    Do you have damage to any wheels? I agree that it's worth getting your tires rebalanced...
  7. Dec 2, 2016 at 8:34 AM
    Checking runnout
  8. Dec 14, 2016 at 9:32 AM
    bowyer2002
    bowyer2002 New Member
    KIRK
    07 TUNDRA CREWMAX LIMITED
    BEDRUG, LEER SHELL & WEATHERTECH
    Who does "road force balancing"?
    Dobbs? Standard tire shops?
    Thanks!
  9. Dec 14, 2016 at 9:51 AM
    Call your local tire shops. Not all of them have this technology.
    NewImprovedRon likes this.
  10. Dec 14, 2016 at 11:37 AM
    louscrw
    louscrw all jacked up on Mt. Dew
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
  11. Feb 7, 2017 at 4:00 AM
    Coba
    08 Tundra
    Ok, finally get my issue resolved! I ended up putting new rotors and new Dura last gold brake on my rear, still my truck shimmied as I applied the brakes so I went back and took my front rotors off and upgraded to a carbon steel new rotor on the front! I'll be damned if I didn't put them on and everything is back to where it should be! Thank you for all your input but I have learned sometimes buying something brand-new is not actually brand-new or correct, this was a pain in the ass as we all now taken the brakes on and off, but I thank you all for your input
