New owner of a 2001 Tundra AC Limited 4WD
Discussion in 'New Member Introductions' started by kulldox, Apr 27, 2024.
  1. Apr 27, 2024 at 4:19 PM
    kulldox
    kulldox [OP] New Member
    Bellevue WA
    2001 Black Tundra AC Limited 4WD TRD
    Hi,
    I'm a newbie with truks in general and with Tundra specifically.
    I'm a decent DIYer, so I thought it would be fun to have some project car. So when I saw a 2001 Tundra AC Limited 4WD with 280k miles on the marketplace, I went and got it.
    It is in crank no run condition. So I had to tow it. Cosmetically it has some bangs here and there, but I'm ok. I can fix that. :)
    Tacoma-Tundra likes this.
  2. Apr 27, 2024 at 7:30 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Just letting you know that a lot of folks on here don't monitor the New Intros forum. Post your questions in the 1st Gen forum and you will get tons of answers and guidance. There are some extremely knowledgeable people in there.
  3. Apr 27, 2024 at 8:07 PM
    kulldox
    Bellevue WA
  4. Apr 27, 2024 at 8:23 PM
    Welcome from NY.
    kulldox[OP] likes this.
  5. Apr 27, 2024 at 8:43 PM
    Markus
    Markus Hermitic Member
    Mark
    Boring, MO
    2 1794 Tundys 2014 and 2023 AG TRD
    A few
    Welcome from West MO
  6. Sep 2, 2024 at 9:59 PM
    kulldox
    Bellevue WA
    Updates so far of what I have done to the truck :)
    Maybe more like a tracking list for me.
    Parts:
    1. Timing belt kit replaced (ASIN kit with everythjin in it from RockAuto)
    2. Spark plug(s) replaced (Denso 3403)
    3. Ignition coil(s) replaced (Denso 6731303)
    4. Thermostat replaced (AISIN THP108, THT015)
    5. Air filter replaced (Denso 1433045)
    6. Wiper Blades (Denso 1603119)
    7. Throttle body cleaned
    8. Radiator replaced (Denso 2210517)
    9. Obviously coolant flush (Toyota Pink)
    10. Bank#2 knock sensor replaced (with OEM)
    11. Lower ball joints replaced (with OEM)
    12. Engine oill flush 2 times after Seafoam treatment + oil filters
    13. Did one treatment with Seafoam for the intake and gastank
    14. Replaced the wheels with 17s from 4Runner (just because of the design I like)
    Other things:
    1. Aftermarket Headlight, Taillights and 3rd Breaklight (AmeriLite)
    2. Amber LED Fog Lights (Alla Lighting)
    3. Installed a 9" Joying Head unit (with front&back cameras)
    4. 30% Ceramic tint all around excepting windshield (precut from "The Tint Effect"). Thinking of doing that eventually, maybe after the windshied replacement?
    5. Wolfbox rear mirror dashcam install
    6. CB Radio and antenna (put in a Uniden Bearcat 980SBB, still learing how to use it) with 4ft antenna
    7. Replaced the wheels with 17s from 4Runner (just because of the design I like) and wrapped them in Yokohama Geolandar A/T tires
    8. LED dash conversion, including the common D selector light :)
    9. Interior LED conversion
    10. Grabbed a free forward center console (the one with side pockets) and installed. More storage for the win :)
    11. Bought the 3D printed cabin filter from the Facebook groups guy (Jose Wong). Very good fit, and way better than without it. It is still not filtering everything like in the usual cars (you can still get some of the dust in), but it is definitely an improvement. Technically nothing stops you from inserting a better (maybe cut out from a real filter) filter in there.
    12. Running boards
    13. Going to install a car alarm (TODO: connect the horn and other options, for now just lock/unlock/remote-start)
    14. Grease the rear leaf spring and shafts (did one 14oz cartridge, which seems is not enough because probably they were neve greased, so bought some additional Valvoline Palladium #2 3% Moly HD cartridges to finish it)
    15. Window rain guards
    16. 3" pods on the hood
    17. Bull bar
    18. Soft bed cover
    19. Bed lights (Nighlight)
    20. 4 amber raptor LED lights DYI (used some standard Nighlight rectangle marker lights)
    21. CoLight H4 Mini-projectors Y16 80000LM
    TODO:
    1. Replace the dash dimmer, for some reason it stopped working (replaced and still doesn't work)
    2. Thinking of geting some "modern" seats from a junk yard (doesn't matter the make) just so they have heating and ventilation/cooling and install them. Maybe even retrofit/weld the brackets....
    3. I like the A/C controlls and buttons from the Sequoia. Thinking maybe to find one and install it. Also get the overhead controll/light with compass&mpg...
    4. Install an aftermarket AMP and a sub.
    5. Install a roof rack
    6. Eventually replace the exhaust cause it is very rusty and I'm afraid it will "catch me by surprise" :)
    7. Maybe later replace the upper controll arms and shocks, and other things on the suspension (I don't like the lifts though)
    8. Either replace with stock or maybe upgrade the brakes, all the piping is fine
    9. If I'll find them for the right price, replace the bumpers with overland ones
    10. Install LED bar. I did hit some local trails and night cought me in the woods. I'll tell you, normal lights don't help in the woods.
    That is about it :)
    texasrho83 likes this.
  7. Sep 11, 2024 at 8:43 AM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    2003 V8 SR5, Access Cab, 4x4, White
    What "kit" did you order from ScAmazon? And, are you happy with it?
  8. Sep 11, 2024 at 9:27 AM
    kulldox
    Bellevue WA
    I like the "Alla Lighting" brand. Usually I have good luck with them and they are responsive and will replace the defective bulb in the 1 year waranty they offer. I use their bulbs in all my cars when possible.
    But they don't have all the needed sizes. The ones which they don't, I just ordered from the links provided by the "JDM Driveway" youtube channel.
    ATBAV8 likes this.
  9. Sep 18, 2024 at 5:51 PM
    kulldox
    Bellevue WA
    An update on how it looks now several month after :)
    texasrho83, Lifer and KNABORES like this.
  10. Feb 19, 2025 at 3:02 PM
    kulldox
    Bellevue WA
    Changed the whels and tires :)
    Before (2017 Snowflake 4Runner and Yokohama Geolandar A/T 255/75/17):
    After (2021 TRD 4Runner and Dunlop AT20 Grandtrek 265/70/17):
    Sirfive and Lifer like this.
  11. Feb 19, 2025 at 4:13 PM
    Lifer
    Lifer New Member
    Vince
    2000 Ltd 4x4 2008 SR5 4x4 LB 2021 SR 4x4 LB
    Fab tech on the 2000
    Looks a hell of a lot better than mine!!!
  12. Feb 19, 2025 at 6:19 PM
    Tacoma-Tundra
    Tacoma-Tundra New Member
    Tony
    06 Tundra SR5 LTD CC 4.7 V8 AT 2WD
    Welcome from NC :hattip:Try Lucas Octane Boost (Walmart) and Gumout as alternates along with the seafoam. A little time + elbow grease and it'll be good as new. Thanks for posting your progress.
    kulldox[QUOTED][OP] likes this.
  13. Mar 5, 2025 at 9:37 PM
    kulldox
    Bellevue WA
    :D all this subjective.... ha-ha
