New NVs with 305/65r18
Discussion in 'Wheels & Tires' started by Berettafan, Jun 23, 2017.
  1. Jun 23, 2017 at 2:03 PM
    Berettafan
    Berettafan [OP] New Member
    2017 CM
    Just picked her up. Rides fine, alignment might need a touch toe in. Used two coachbuilder shims on each side. Didn't measure before but height looks fine to me.
    Tires are very quiet. Rubs both flaps turning. The machined NV is a great look with MGM and chrome. Acceleration is a bit less but acceptable. Only real complaint is 25 offset sticks out too far in the rear and highlights the stupid axle alignment Toyota uses on these trucks. Considering flares. ca61f651eacc34f9d1b9b9a51909298a_ff9ae1939a6729a5e5d2ee3fad443116b8d19440.jpg
  2. Jun 23, 2017 at 2:47 PM
    Berettafan
    2017 CM
    looks a lot more aggressive in person. tires have a great look. ideally I'd want a 40 offset and 295/65 Falkens but such a thing doesn't exist right now.
  3. Jun 23, 2017 at 2:50 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    I like it :thumbsup:
  4. Jun 23, 2017 at 3:21 PM
    Flyinryank
    Flyinryank New Member
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    I have the same wheels and tires :thumbsup:
    I am running 6112s at 2" of lift. I did the bmc just in case. Removed the mini mud flaps between the front bumper and tires. I also did the front bumper mod I think I found on TT to scoot it forward about 3/4". Zero rubbing now.
  5. Feb 20, 2018 at 11:50 AM
    Lggque
    Lggque New Member
    Is the suspension stock.
  6. Feb 20, 2018 at 11:56 AM
    Awesome sauce wheels!!!
  7. Feb 20, 2018 at 1:20 PM
    [DELETED]
    [DELETED] New Member
    Jeff
    Any pics to show the poke.
  8. Mar 2, 2018 at 1:38 PM
    Big J
    Big J New Member
    2020 4x4 crewmax
    Looks great! :thumbsup:
